Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 02-06-2018, 18:12   #226 (permalink)
applestorebd's Avatar
Member: 1659078
Sonork: Mahidi Munna
Thanks Meter: 199
Arrow hey mrt team
download speed is so slow fix it team please...
Old 02-10-2018, 20:43   #227 (permalink)
Member: 1150575
Hello.Need global firmware for Mi5S with removed mi services.May you make this?China version work fine. But need another language for client. Thanks
Old 03-01-2018, 08:50   #228 (permalink)
Member: 2367218
Thanks Meter: 20
Hello all i cant find this driver :Exynos5430 USB_Drivers. Thanks.
Old 03-01-2018, 14:26   #229 (permalink)
Member: 2804518
Sonork: 100.1597111
Thanks Meter: 18
Meizu M3 Note "M".
Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
Get Mobile Port is: COM6
>>> Device driver identification:
MediaTek USB Port
>>> Mobile Has Connect...
CPU_NAME: MT6755
>>> Reading Mobile Hardware Info...Success
HW_Inf: 8A00 SW_Inf: CB00
>>> Initialization Mobile ...
>>> Sending Auth File To Mobile...Success
>>>>Trying Connect to Service verification data...
Success
>>> Downloading Boot1 To Mobile Phone...Success
Mobile phone status:SYNC...
Mobile phone status swtich to :brom...Success
Success
Make sure Mobile status has in :brom...
Init Mobile BOOT2 ...
=====================Flash Type(eMMC)==============
Flash Size: 0x0000000747C00000 -> 29820M
Flash ID: 0x150100525831424D
Flash Name: Samsung_Unknow
Flash symbol: RX1BMB
>>> Swich Mobile to Hight Speed Re\Wr Port...
Get Mobile Port is: COM14
MediaTek DA USB VCOM (Android)
>>> Reading Mobile Map Data...Fail
>>>>BMT Not exit;auto Creat BMT Block...
>>>>Flashing recovery Block data to Moblile Phone...
Start: 0x0000008000 Size: 0x0000CE0E50
>>>>Flashing custom Block data to Moblile Phone...
Start: 0x0001088000 Size: 0x000D8292D4
>>>>Flashing md1img Block data to Moblile Phone...
Start: 0x0029800000 Size: 0x0000F3EDD0
>>>>Flashing md1dsp Block data to Moblile Phone...
Start: 0x002B000000 Size: 0x00000E9970
>>>>Flashing md1arm7 Block data to Moblile Phone...
Start: 0x002B400000 Size: 0x0000031100
>>>>Flashing md3img Block data to Moblile Phone...
Start: 0x002B700000 Size: 0x00004481E0
>>>>Flashing lk Block data to Moblile Phone...
Start: 0x002C100000 Size: 0x000005C5D0
>>>>Flashing lk2 Block data to Moblile Phone...
Start: 0x002C200000 Size: 0x000005C5D0
>>>>Flashing boot Block data to Moblile Phone...
Start: 0x002C300000 Size: 0x000093FE50
>>>>Flashing logo Block data to Moblile Phone...
Start: 0x002D300000 Size: 0x00000845D0
>>>>Flashing tee1 Block data to Moblile Phone...
Start: 0x002DB00000 Size: 0x000006C4A0
>>>>Flashing tee2 Block data to Moblile Phone...
Start: 0x002E000000 Size: 0x000006C4A0
>>>>Flashing secro Block data to Moblile Phone...
Start: 0x002E500000 Size: 0x0000021000
>>>>Flashing devinfo Block data to Moblile Phone...
Start: 0x002F800000 Size: 0x0000100000
>>>>Flashing system Block data to Moblile Phone...
Start: 0x0030000000 Size: 0x00568E3FFC
>>>>Flashing cache Block data to Moblile Phone...
Start: 0x00D0000000 Size: 0x00008A0130
>>>>Flashing userdata Block data to Moblile Phone...
Start: 0x00EB000000 Size: 0x00100D849C
Corresponding operation completed!!!
After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
Mistakes critical-there is no.
V2.33. The firmware is repeatedly checked.
Result = 0. What am I doing wrong? The phone remains dead.
2.12 coping with this easily and quickly.
The Following User Says Thank You to bbv62 For This Useful Post:
Old 03-01-2018, 15:40   #230 (permalink)
Member: 2804518
Sonork: 100.1597111
Thanks Meter: 18
Sorry, not in the theme wrote.
Old 03-05-2018, 22:27   #231 (permalink)
Member: 117432
Thanks Meter: 6
same problem !
please check program
The Following User Says Thank You to mobisvit For This Useful Post:
Old 03-05-2018, 23:26   #232 (permalink)
Member: 1095589
Thanks Meter: 2
Meizu M3 Note "L". same problem !
The Following User Says Thank You to Maliy30 For This Useful Post:
Old 03-06-2018, 06:44   #233 (permalink)
kjava's Avatar
Member: 846616
Sonork: 100.1675590
Thanks Meter: 581
meizu m6 cpu MTK6755 flashtool firmware
Old 03-15-2018, 08:05   #234 (permalink)
Member: 1809124
Sonork: Kwam
Thanks Meter: 26
Please post Tecno ca6,k8 custom loader DA and fero pace 2.
Thanks
Old 03-15-2018, 10:49   #235 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
LeEco Le S3 X622/X626
Need fw for repair via MRT or Flashtool
Old 03-19-2018, 01:11   #236 (permalink)
Member: 1950427
Old 03-19-2018, 02:28   #237 (permalink)
Member: 2233264
Thanks Meter: 14
Hello َAll
I have a problem
After giving the order
He will go astray forever
Huawei Account Remove Tool not working!
When press button Remove google frp, app not answer
>>>>Searching mobile phones...
Get Hisi cpu Mobile Phones...
>>> Get Mobile Port: COM65
>>>>Device identification :
Android Adapter PCUI
>>>>Switch Mobile to Auth Mode
PCB SN: DU4RAH*******
Mobile SN: H3XDU*******
Mobile Code mission ...............................
and fastboot
>>>>search android fastboot devices...
>>>>Get android fastboot devices...
Mobile Name: WAS-LX1A
Mobile Set BL Lock state:FB LockState: LOCKED
Trying First Way for Get the Unlock code
Dynamic unlock code:5d68796e1af799cc ....................................
The process is not completed in all cases
And does not show any interaction
Please help
Old 03-24-2018, 12:32   #238 (permalink)
Member: 2284869
help....!!! XiaoMi Max 2 firmware please
Old 03-29-2018, 16:06   #239 (permalink)
Member: 76522
Thanks Meter: 30
Need help whis some meizu.
1st I need global flah file for MRT for M3s mini. All flashes on support are chineese versions.
2nd How to remove flame account on M3E? I flash phone with 20160924133550_intl_prd_stable_5.2.1.0 and got "phone locked" at start up. even before wifi was connected. When i try option remove account it goes reboots on logo. after i try remove account 2 option it say all ok but still phone locked. If i flash it loke M1E, no code is asked but screen is turned at 180 degreece. Any help?
Thx in advance!
Old 03-30-2018, 08:59   #240 (permalink)
Member: 76522
Thanks Meter: 30
Any help from support?
Page generated in 0.23839 seconds with 9 queries
