Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 12-07-2016, 12:53   #1 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
MRT FAQ (Beta version)
I offer users a MRT themselves to create a practical guide on how to use.
I ask all to correct and supplement this manual, the only proven solution!
Start.
1.MRT work requires an internet connection, all the errors at startup are related to his lack of or poor quality.
2. The dongle does not require any special driver, the system is defined as a basic disk. The program requires no installation.
3. .....
Work.
1. Xiomi Note 3 Pro (kenzo)
User Lock.
a) Select Xiaomi tab / Unlock password BL Lock phones
b) Enter phone in recovery mode.
Power off. Press volume + and Power key, after the logo appears release the power button, after entering the recovery release the volume + button, if not, check the connection, the command "adb devices" answer should be "adb sideload"
Remove Account (Acc)
MTK Tool.
How to use MRT MTK Tools<ex:huawei mtk phone>User's Manual
The Following 5 Users Say Thank You to Mishel For This Useful Post:
Old 12-08-2016, 04:31   #2 (permalink)
A^A
Member: 573800
Thanks Meter: 31
why dont you create a wiki page for this, isnt that much more useful for all?
Old 12-08-2016, 08:22   #3 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
MRT team said "World First All Of Xiaomi New Device 2015 up to 2016
MRT Dongle Supported for Password Removal". So you need a detailed description of the algorithm in the performance, it will help promote the program and release the support of the need to respond to basic questions.
And who reads WIKI
The Following 2 Users Say Thank You to Mishel For This Useful Post:
Old 12-09-2016, 07:56   #4 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
Thank you for your endless patience and correct English Mr. A^A
Step 1
Quite simple step actually:
I assume all drivers are installed properly (CHECK!)
1. Don't open MRT yet, keep it close
2. Plug the cable into the phone, and put it on EDL mode
3. Make sure it's properly detected in device manager
4. Open MRT, pick Redmi Note 3 from drop down list
5. Finally click Remove Account
Done, turn it on, enable adb, and proceed Remove APK steps.
Step 2
No need root at all. Windows 10 suported.
Better using version 7.3.2 for higher success rate, especially for Note 3 Pro
Enable USB debuging, get user permissions from phone .
1. Make sure adb driver that installed in your system is the latest one.
2. Don't open MRT yet
3. Enable ADB in the phone (you know how to do this one)
4. Plug the cable into the phone, make sure phone properly detected in the device manager
5. Open ADB CMD prompt, and type adb devices, look at your phone screen, there should be an ADB notification ask for manual permission
6. Dont forget to TICK (always give) and click OK to allow it
7. Open MRT, finally click Remove APK
Screenshots and original thread redmi note3 mi account always filed
To be continued....
The Following 4 Users Say Thank You to Mishel For This Useful Post:
Old 12-09-2016, 09:29   #5 (permalink)
A^A
Member: 573800
Thanks Meter: 31
Glad can help others...
cheers !
Old 12-19-2016, 09:39   #6 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
If you get errors when removing phone code Meizu M3 Note select M3s model, it works!
M3 Note L91 not support for operations. [ ANSWERED ]
The Following User Says Thank You to Mishel For This Useful Post:
Old 01-02-2017, 19:12   #7 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
If you get an error
" >>> Sending Auth File To Mobile ... Success
>>>> Trying Connect to Service verification data ...
Connect to Service Fail, Please re-run the software and try again ...
Fail"
server based authentication service is off-line, try again later, perhaps Mr. zhulianqi shut own laptop
Good news:
Date: 22nd Dec 2016
Service 2 and move the service, now run the software faster.
Support MTK remove FRP <OLD CPU and new CPU all are support.
Support oppo r9s a57 and more <qualcomm CPU>.
Adjust Oppo R7 full <like r7s r7p....> all the Oppo form R7 start MTK chip
Support Vivo X9 Y55a and others new mobile
Support Meizu note5 5 6s x and more
MTK CPU support MT6757
Old 01-06-2017, 21:06   #8 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
Xiaomi M3s Mi account deleted (ver. 1.55)
1. Downgrade to land_global_images_V7.5.8.0.MALMIDE_20160712.0000. 26_6.0_global
2. Enable USB debugging in developer options and OEM unlock (optional)
3. Enable instaliations from unknown sourses
4. Connect phone and allow debugging autorisations, disconect!
5. Run MRT
6. Click "Remove APP"
7. Connect phone
The Following 3 Users Say Thank You to Mishel For This Useful Post:
Old 01-11-2017, 11:29   #9 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
Schematic for EDL cable
Old 01-11-2017, 11:39   #10 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
comprehensive guide to flashing Redmi Note 3 (MTK) via Flash tool
mi note3 mtk how to flash
Old 01-27-2017, 19:20   #11 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 976
5. Run MRT
7. Connect phone
In my case it not work:
Old 01-28-2017, 15:27   #12 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
try again, try again.......
Old 01-31-2017, 18:39   #13 (permalink)
sahip's Avatar
Member: 2063130
Thanks Meter: 139
Hello.reseller Russia? how to buy
Old 02-01-2017, 15:33   #14 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 976
5. Run MRT
7. Connect phone
Finally!
After flashing china 7.3 from support MRT was removed two apk as on screenshot from post 13:
But:
- now I can't reset phone,
- can't update phone,
- no market,
- no any languages except English and China.
Is it really solution that cost 100$?
The Following 2 Users Say Thank You to Dr_Wolodya For This Useful Post:
Old 03-07-2017, 19:24   #15 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,841
Its just need to fix ! let me know which tool can do like MRT Dongle for redmi note 4 and redmi 3/3x/ etc
As long as is ok...MRT Have many success report!
Which tool can do safe format ? like this mi note 4 mtk format done by mrt { SUCCESS REPORT }
no tool have a brave doing like this
i never see like this in my section
MRT Dongle well done !!
You can make money every day with mrt dongle ...
Do format without dead device and safe imei in oppo set ...etc ( its world first ) you can see in success report this section
http://forum.gsmhosting.com/vbb/f492...k-etc-2067525/.
World 1st FLASHING OPPO F1s Boot Loop with MRT OK! ★ MRT Leading The Pack ★
World Ist Huwaei 6x Frp Lock Removed Done ✔ MRT Leading The Pack
World First All Of Xiaomi New Device 2015 up to 2016 MRT Dongle UNLOCK PASS Supported
Huawei P9 frp remove done !! all other box failed .... { SUCCESS REPORT }
http://forum.gsmhosting.com/vbb/f492...umang-2177800/
Micloud MI5 Completed Remove ★ MRT Leading The Pack ★
World 1st FLASHING OPPO F1s Boot Loop with MRT OK! ★ MRT Leading The Pack ★ - which one can do this?
World First Meizu M2 Imei Gone!!!, but SUCCESS repair with MRT ★MRT Leading The Pack★
http://forum.gsmhosting.com/vbb/f492...-done-2186054/ - Which one can do this?
...and many more !!!
Unlock password just one click is our world first and Many other world first features in other brand
As you can see..In Every features of MRT other product will following us
Be grateful people...have a nice day
The Following 2 Users Say Thank You to .::ARD::. For This Useful Post:
Page generated in 0.46522 seconds with 8 queries
