Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 03-08-2017, 03:34   #16 (permalink)
A^A
Member: 573800
Thanks Meter: 31
Agree with you ARD !
People just need to be more grateful, that's it
Old 01-02-2018, 08:32   #17 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
How to reset an account request Meizu M6
How to reset an account request Meizu M6 not suported?
Old 01-02-2018, 09:15   #18 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
Step-by-step instruction
Supported since version 2.22
-select "Meilan M6"
-select "Remove account"
-connect the switched off phone with the volume+ button held down to the cable
If after this the phone will be constantly rebooted
-go into the recovery and press 5 times the volume+ button up and then 5 times the volume- button
-You will enter the special reset menu, select the "Clear"
-If this does not help update the phone in recovery via update.zip
You will be able to log in with a new account.
The Following 4 Users Say Thank You to Mishel For This Useful Post:
Old 01-19-2018, 15:08   #19 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
Meizu M6 Note remove account
1) Load the phone into the download mode:
-Turn off the phone.
-Press the volume keys + and - and connect the USB cable. Qualcomm HS-USB QDLoader 9008 port should appear on the system.
2) Select "Delete Account" or another operation.
3) Click "Start"
After performing the operation, the phone will only boot into the recovery menu, select "Reset data" in it, if it did not help update the phone with update.zip.
Perhaps you can help reset through a special menu (in recovery, press the volume + key 5 times, then 5 times volume -).
The Following 2 Users Say Thank You to Mishel For This Useful Post:
Old 03-10-2018, 11:51   #20 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
Xiaomi Redmi Note 4X Mido bypass Mi account for MUIU 9
1) Load the phone into the download mode via testpoint. Qualcomm HS-USB QDLoader 9008 port should appear on the system.
2) Start MRT Mi Tool
3)Check and run "Remove account"
4)Сompletely turn on the phone and go through all the settings, Wi-Fi should be on.
5)Load the phone into the download mode via testpoint. Qualcomm HS-USB QDLoader 9008 port should appear on the system.
6)Check and run "MUIU 9 disable account apk"
7)Сompletely turn on the phone on.
8)If desired, repair non-working proximity and rotation sensors using a special file
You can not use Mi services and update your phone without re-blocking
Page generated in 0.27507 seconds with 8 queries
