03-17-2018, 14:21 | #122 (permalink) |
Insane Poster Join Date: May 2012
Member: 1757310 Status: Offline Thanks Meter: 8 | Does not flash Meizu M2 note CPU MT6735. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM3 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:R821MB >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100523832314D Flash Name: Samsung_KMR820001M_B609 Flash symbol: R821MB >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM9 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success Initialization Write Flash Parameter Fail After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
The Following User Says Thank You to Wolfen13 For This Useful Post: |
03-17-2018, 17:37 | #124 (permalink) |
Major Poster Join Date: Aug 2014 Location: maroc
Member: 2233264 Status: Offline Thanks Meter: 14 | Hello َAll I have a problem After giving the order He will go astray forever >>>>Searching mobile phones... Get Hisi cpu Mobile Phones... >>> Get Mobile Port: COM65 >>>>Device identification : Android Adapter PCUI >>>>Switch Mobile to Auth Mode PCB SN: DU4RAH******* Mobile SN: H3XDU******* Mobile Code mission ............................... and fastboot >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: WAS-LX1A Mobile Set BL Lock state:FB LockState: LOCKED Trying First Way for Get the Unlock code Dynamic unlock code:5d68796e1af799cc .................................... The process is not completed in all cases And does not show any interaction Please help Last edited by AGHELA1; 03-17-2018 at 17:46. |
The Following User Says Thank You to AGHELA1 For This Useful Post: |
03-18-2018, 06:40 | #126 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2822016 Status: Offline Thanks Meter: 1 | is there any new tutorial how to instal MRT dongle? i can't get my oppo F5 done. always failed open file.. |
The Following User Says Thank You to darrenyu For This Useful Post: |
03-19-2018, 00:57 | #131 (permalink) |
Junior Member Join Date: May 2013
Member: 1950427 Status: Offline Thanks Meter: 0 | [ SERIOUSLY PROBLEM ] About flashing Meizu M3 Note L681H / L91 All phone my customer is bricked after flashing using MRT Tool V2.16 - V2.33 • M3 Note L681H / L91 (16GB) - selecting "Meilan 3s/3/note3" • M3 Note L681H / L91 (32GB) - selecting "Meilan Max" Usually I'm using MRT To V2.12 by selecting "Meilan 3" all work fine : • Unlock Password : ✓ • Erase Userdata : ✓ • Remove Account : ✓ • Write Flash : ✓ Need solution.. • How can i run MRT Tool V2.12 now ?... • How to Flash Meizu M3 Note L681H / L91 (16GB or 32GB) in MRT Tool New Version ?... |
