10-28-2017, 11:57 | #16 (permalink) |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Last edited by VC_INDIA; 10-28-2017 at 12:30. |
10-28-2017, 12:02 | #17 (permalink) | |
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Quote:
Will Update Next Time malware Free Update | |
The Following 3 Users Say Thank You to VC_INDIA For This Useful Post: |
10-28-2017, 12:22 | #20 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: around
Member: 595864 Status: Offline Thanks Meter: 163 | Quote:
10-28-2017, 12:32 | #21 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Quote:
Code: Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM51COM51 >>> Device driver identification: MTK USB Port Set Port To COM51Success Into Meta Mode...Fail | |
10-28-2017, 12:48 | #23 (permalink) |
No Life Poster Join Date: Mar 2010 Location: bhubaneswar
Member: 1267573 Status: Offline Thanks Meter: 144 | Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:QE13MB >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100514531334D Flash Name: Samsung_Unknow Flash symbol: QE13MB >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM16 >>> Device driver identification: DA USB VCOM Port >>> Reading Mobile Map Data...Success Initialization Write Flash Parameter Fail |
10-28-2017, 14:38 | #24 (permalink) |
No Life Poster Join Date: Jul 2008 Location: china guangzhou Age: 35
Member: 812359 Status: Offline Sonork: 100.1597111 Thanks Meter: 6,791 | http://forum.gsmhosting.com/vbb/f492...-boot-2277616/ read this post,it support all the mtk cpu change imei OPPO A71 not need select auth file,just click start and input imei,then hold vol up + down connect it |
The Following User Says Thank You to zhulianqi For This Useful Post: |
10-28-2017, 14:39 | #25 (permalink) | |
Member: 812359 Status: Offline Sonork: 100.1597111 Thanks Meter: 6,791 | Quote:
read this post,not need select auth file,just input imei after hold vol up +down connect mobile then ok sure it will support it | |
10-28-2017, 14:47 | #26 (permalink) | |
this is not Viruses;we are use the VMProtect and some time it give the error info in the Security software,but we are sure is 100% safe | |
10-28-2017, 14:51 | #27 (permalink) |
Junior Member Join Date: Aug 2017 Location: Ukraine. Vinnytsa city
Member: 2752135 Status: Offline Thanks Meter: 3 | Hello! When i try to remove account on meizu m3s i see this: Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM28 >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom... КЦ»ъЧґМ¬ОЄ: preloader Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525831424D Flash Name: Samsung_Unknow Flash symbol: RX1BMB >>> Swich Mobile to Hight Speed Re\Wr Port... and it's stuck... Please help. |
10-28-2017, 14:55 | #29 (permalink) | |
in here is mtk-usb port close and new the MTK da port come check your Device manager when software coming here sure will be have a driver come if not ,check mobile have power or not try to use the good quality usb cable for repair mobile software | |
10-28-2017, 14:57 | #30 (permalink) | |
I think this is flash the perload block error,i will try to find some moto device and check ,and fix it soon as soon | |
