03-28-2011, 05:46 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ## MTK BOX-3 ## Tips>Problem>Solution>Help ## "SPD USB TO SERIAL NOT FOUND" Solution: You need to install the USB drivers for SpreadTrum. If already install than uninstall it first again install SPD the driver. Last edited by VIJAY2U2; 04-28-2011 at 19:56. |
03-28-2011, 05:51 | #2 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. Solution Try "Reset" option, If still problem than search 4 a same handset read the flashfile from that working set again write it back to the faulty set. |
03-28-2011, 05:54 | #3 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 Nor Flash not found. Solution First try to shake the flash ic at middle heat if still same then replace cpu. |
03-28-2011, 05:57 | #4 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR Read info is done. CPU: SC6600R Flash: NOR_K5L6331CAA Set FLASH Parameters... Settings have been completed! Reading FileSystem info... Failed to read FS info. Solution Flash the set with same file or read flash from a working handset and then flash it to faulty handset. |
03-28-2011, 06:01 | #5 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR FAILED TO RUN BOOTLOADER Solution Press and hold the * button and keep pressed untill all completed if still same shake the flash ic at middle heat. |
03-28-2011, 06:08 | #7 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR Code: Nor Flash ID: 007F22F600000000 Nand Flash ID: 0000000000000000 Read Hardware Information is Get Project ID from phone... ProjectID Not Found Solution Change the boot type to 3.952 if still same than shake the CPU at middle heat or change CPU |
03-28-2011, 11:04 | #8 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR ERROR: MTK_DA_GET_FAT_INFO_NOT_FOUND Solution Try Boot "Ver. 3.952" from Boot options, if still same than shake the flash ic at middle heat. |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
03-28-2011, 11:12 | #9 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR Code: Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 Failed to format Flash... Solution Try with different Boots from list if still same then rehot flash chip than CPU |
03-28-2011, 11:24 | #10 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR Code: Initializing... DA_LIB_VER_3.2.0.7 It is sensing the pinout fast... D-=4 D+=3 Searching commport...please wait... Check connection with phone or connect from RX TX points from board if still same than rehot the CPU |
03-28-2011, 12:51 | #11 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR NOR FLASH NOT FOUND Solution There is NAND flash Plz select NAND from Mode and use Boot 3.952 |
04-28-2011, 19:40 | #12 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR Code: Initializing... DA_LIB_VER_3.2.1.3 It is sensing the pinout fast... D-=3 D+=0 BOOT set failure, continue to scan... Sense failure Press and hold 0+Power button of your handset until process |
04-28-2011, 19:54 | #13 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR Selected collating sequence not supported by the operating system Solution You need windows XP DISC Go to Control Panel > Regional Language> Language> Install East language Last edited by VIJAY2U2; 05-27-2011 at 04:28. |
05-27-2011, 04:42 | #14 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | ERROR "Conjuction Error" while updating your box SOLUTION To fix this. you need to upgrade the firmware by using "Emmergency UpGrade" feature. Disconnect MTK BOX-3 Box from USB, connect the main cable to MTK BOX-3. Now short the "+" and "-" wires of the main cable Connect computer with USB to MTK BOX-3. Open the latest Box firmware Updater software for MTK BOX-3. Press "ScanPort", Select your MTK BOX-3 comm port number, tick the "Exigency UpGrade" and press "UpGrade-BOX" |
