04-02-2019, 00:33 | #4 (permalink) |
Freak Poster Join Date: Jul 2012
Member: 1787478 Status: Offline Thanks Meter: 22 | >>>>Reading Mobile parameter information... make sure has adb driver in the Device manager... Searching android devices... List of devices attached * daemon not running. starting it now on port 5037 * * daemon started successfully * reading mobile name... error: device unauthorized. This adbd's $ADB_VENDOR_KEYS is not set; try 'adb kill-server' if that seems wrong. Otherwise check for a confirmation dialog on your device. reading cpu type... error: device unauthorized. This adbd's $ADB_VENDOR_KEYS is not set; try 'adb kill-server' if that seems wrong. Otherwise check for a confirmation dialog on your device. reading andorid system version... error: device unauthorized. This adbd's $ADB_VENDOR_KEYS is not set; try 'adb kill-server' if that seems wrong. Otherwise check for a confirmation dialog on your device. reading mobile software version... error: device unauthorized. This adbd's $ADB_VENDOR_KEYS is not set; try 'adb kill-server' if that seems wrong. Otherwise check for a confirmation dialog on your device. >>>>bypass the account id and frp... error: device unauthorized. This adbd's $ADB_VENDOR_KEYS is not set; try 'adb kill-server' if that seems wrong. Otherwise check for a confirmation dialog on your device. error: device unauthorized. This adbd's $ADB_VENDOR_KEYS is not set; try 'adb kill-server' if that seems wrong. Otherwise check for a confirmation dialog on your device. bypass done,go to mobile setting login new id and factory reset!!! |
04-02-2019, 03:02 | #5 (permalink) |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | 1)first of all check is device is with latest security if no you can directly remove frp using our mrt 2.60 hw tool, 2) if security is on latest version then check chipset if chipset is in our latest new mrt hw tool list then yes remove backpanel use testpoint to ground for com 1.0 and patch the boot select proper chipset next after boot patch complete, device will automatically in fastboot mode then next only remove frp using frp tab |
