oppo a7 allwys error with mrt ae tool |
If you not ready become technician, don't do this job Isp long time ago is for expert skill |
For you both , don't too much talked over here Show me your skill are good !! This is a proof ! |
please provide the .clear video i can,t understand |
>>>>Searching EMMC Devices.... MAE ToolSN 032A TS37 >>>>Testing EMMC disk read status.... Reading EMMC Capacity Info... Capacity Size:0Byte/0MB/0.00GB;(Hex:0x0000000000) Wrong EMMC disk data; this may be an empty Flash IC!!! The Green light is not swithching ON in my Unit. What is the Problem? Pls help. Br jackle123 |
You can check connection like this |
IT WORKED But getting this error >>>>Searching EMMC Devices.... MAE ToolSN 032A TS37 >>>>Testing EMMC disk read status.... Reading EMMC Capacity Info... Capacity Size:15634268160Byte/14910MB/14.91GB;(Hex:0x03A3E00000) >>>>Reading EMMC GPT Data... File Size: 0x00C0000000--->3072MB Flash Add: 0x015B800000 verification Write Page Error... Error Add:0x000000000000 verification Write Page Error... Error Add:0x000000100000 You Has Stop It!!! All is Done Model 1853, probem was Password/FRP Br jackle123 |
Now only 9008 port and not switching ON |
Select format and repeat operation |
2 Attachment(s) Check again your isp also |
What is the Usual time it take to Format? As in my case it is taking a very long time, approx 20mts for the procedure to complete. Br jackle123 |
Check ur isp I already uploaded And don't use long wire |
@.::ARD::. Thanks a lot, sorry for reporting late. Successful log here >>>>Searching EMMC Devices.... MAE ToolSN 032A TS37 >>>>Testing EMMC disk read status.... Reading EMMC Capacity Info... Capacity Size:15634268160Byte/14910MB/14.91GB;(Hex:0x03A3E00000) >>>>Reading EMMC GPT Data... >>>>Reading EMMC Mobile System Version Info... Start Add:0x0042800000 Size:0x00D6900000 Ext4 File System Found.... ro.build.id=OPM1.171019.026 ro.build.version.release=8.1.0 ro.product.manufacturer=OPPO >>>>Searching EMMC Devices.... MAE ToolSN 032A TS37 >>>>Testing EMMC disk read status.... Reading EMMC Capacity Info... Capacity Size:15634268160Byte/14910MB/14.91GB;(Hex:0x03A3E00000) >>>>Reading EMMC GPT Data... File Size: 0x00C0000000--->3072MB Flash Add: 0x015B800000 All is Done After this, I had the phone in 9008 port only! I tried again read Info and found the log as follows Reading EMMC Capacity Info... Capacity Size:15634268160Byte/14910MB/14.91GB;(Hex:0x03A3E00000) >>>>Reading EMMC GPT Data... >>>>Reading EMMC Mobile System Version Info... Start Add:0x0042800000 Size:0x00D6900000 Ext4 File System Found.... ro.build.id=OPM1.171019.026 ro.build.version.release=8.1.0 ro.product.manufacturer=OPPO Then Found the CLK rsistor to be defective. Just shorted it and the phone is Alive. Br jackle123 |
