Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 01-21-2019, 09:43   #1 (permalink)
Member: 580100
Thanks Meter: 16
OPPO F5 new security dead after frp pinout (need help)
need your help mates
i formatted OPPO f5 cph1723 new security with mrt using TP
after formatting everything seems ok but it still has FRP
so I decided to remove the FRP with TP using MRT
but unluckily it wont boot anymore
the pc still can detect it as MediaTek usb port
does anyone experienced it
I would highly appreciate
any workaround
for this one
The Following User Says Thank You to liera For This Useful Post:
Old 01-21-2019, 10:21   #2 (permalink)
Member: 177381
Sonork: 100.162218
Thanks Meter: 16
press emergency dialler write *#812# code frp will reset
The Following 2 Users Say Thank You to nabeel_7152077 For This Useful Post:
Old 01-21-2019, 10:46   #3 (permalink)
Member: 580100
Thanks Meter: 16
how can press anything if the phone itself wont boot
anyway thanks for the advice
Old 01-21-2019, 10:49   #4 (permalink)
Member: 199355
Thanks Meter: 19
better use remote server coz your pin-out is grounded
Old 01-21-2019, 11:03   #5 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
Post mrt screenshot report
Old 01-21-2019, 11:22   #6 (permalink)
Member: 580100
Thanks Meter: 16
I have'nt taken a screen shot, what I remembered is that it has error in removing FRP, but all is well in fiormat(unlock)
Old 01-21-2019, 11:24   #7 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
http://forum.gsmhosting.com/vbb/f492...-read-2271688/
Old 01-21-2019, 11:35   #8 (permalink)
Member: 580100
Thanks Meter: 16
Originally Posted by .::ARD::. View Post
yes sir, Its just that I've been out of my mind forgetting to take the screenies after it wont boot anymore
I already have oppo phones with new security succesful in removing frp using tP with mrt but maybe I just didnt get lucky in this one.
Old 01-21-2019, 11:46   #9 (permalink)
Member: 784847
Thanks Meter: 45
I had also the same problem
dead f5 after tp unlock
phone was connecting with pc but not power on
solution...
Simply clean tp soldering area with good liquid there is must some kind of shortage with tp....
Every thing will be fine
good luck
Old 01-21-2019, 12:11   #10 (permalink)
Member: 580100
Thanks Meter: 16
solution...
good luck
I'll try it sir
if it would work
Old 01-21-2019, 12:27   #11 (permalink)
Member: 580100
Thanks Meter: 16
already cleaned the area with cleaning solution but still wont boot, any other remedy/solution for this?
The Following 2 Users Say Thank You to liera For This Useful Post:
Old 01-22-2019, 13:16   #12 (permalink)
robean's Avatar
Member: 538410
Sonork: 100.1590750
Thanks Meter: 193
now u should fully flashed the phone via vip auth account.
and for future reference the best option is only to do format any oppo mtk model with testpoint never do the reset frp after format just power on the phone and connect to the wifi do the rest step there should not be frp even if u get frp locked after that too try the code *#812#
The Following 3 Users Say Thank You to robean For This Useful Post:
Old 01-22-2019, 19:56   #13 (permalink)
Member: 2280979
Pleasee check resistor( CLK )
make sure still good or not missing or u can try change the resistor
Old 01-23-2019, 12:54   #14 (permalink)
Member: 580100
Thanks Meter: 16
thanks sir but I tried the online flashing for oppo but they said that it was due to TP and it was to be repaired thru hardware, I dont even think that it was because of TP since I didnt soldered the resistor to have it touched the ground, I use twizzer to connect it to ground and the resistor isn't damaged at all.
Old 01-24-2019, 06:52   #15 (permalink)
robean's Avatar
Member: 538410
Sonork: 100.1590750
Thanks Meter: 193
Did u flash via online with lastest version and did the online flashing is complete or not
The Following User Says Thank You to robean For This Useful Post:
Page generated in 0.24879 seconds with 8 queries
