03-23-2011, 09:15 | #31 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1527286 Status: Offline Sonork: 100.1602625 Thanks Meter: 34 | post by Vijay GSM LEPHONE S6233 HANG ON LOGO FORMAT NOT SUPPORTED AFTER RESET SET IS FINE Code: Initializing... DA_LIB_VER_3.2.0.7 It is sensing the pinout fast... D-=8 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM5 Connected...sending boot... FDL test...OK ArmBootMode: 6600700000005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_ST_M58WR064HU setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. BR, VIJAY-GSM |
The Following User Says Thank You to smallreseller For This Useful Post: |
05-07-2011, 08:08 | #32 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | SPD chip flashed Analysis the file... It is sensing the pinout fast... RXD=9 TXD=6 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_S29GL064A_T setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... All Done. |
05-20-2011, 07:25 | #33 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | LAwow F800 SPD FORMATE DONE !!! Initializing... DA_LIB_VER_3.2.2.7 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM82 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x007A0000, Size=0x00050000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
05-22-2011, 10:14 | #34 (permalink) |
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | Suny Ericssom W598 formate done !!! nitializing... DA_LIB_VER_3.2.2.7 It is sensing the pinout fast... D-=4 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM82 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_ST_M30L0T7000T0 setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. |
05-22-2011, 10:15 | #35 (permalink) |
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | micromax gravity tracker read sucsess by super doctor box 3 Initializing... DA_LIB_VER_3.2.2.7 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the ON/OFF key... BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0001 Code=0000 Code=885801 |
05-26-2011, 08:24 | #36 (permalink) |
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | MICROMAX Q2i FORMATE DONE !!! Initializing... DA_LIB_VER_3.2.2.22 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=1 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0001227E22202200 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: E505E_MP_F2_INDIA_V5.6_BT Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x001F0000 All Done |
05-26-2011, 08:29 | #37 (permalink) |
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | Another LAwow F800 SPD FORMATE DONE !!! Initializing... DA_LIB_VER_3.2.2.22 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM6 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x007A0000, Size=0x00050000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
05-30-2011, 08:03 | #38 (permalink) |
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | Spice s-590 no incoming call done !!! Initializing... DA_LIB_VER_3.2.2.22 It is sensing the pinout fast,please hold on the phone Power key RXD=5 TXD=6 Connecting...Please hold on the POWER key until the red gauge is going... BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EC257E25082501 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: KAC3506FM_INA_EN_HI_1.13.430 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
05-30-2011, 08:45 | #39 (permalink) |
Freak Poster Join Date: Feb 2010 Location: karachi pakistan
Member: 1237819 Status: Offline Sonork: [email protected] Thanks Meter: 148 | plz any one give me this same file. HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090905.BIN i flash this set flash area support file. now set on but white lcd show b4 flash display ok and still on shakhands. |
06-14-2011, 08:03 | #40 (permalink) |
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | BASSOON FORMATE DONE !! Initializing... DA_LIB_VER_3.2.2.22 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM6 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x007A0000, Size=0x00050000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
06-14-2011, 08:32 | #41 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | BASSOON F800 FORMATING Code: Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM10 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x007A0000, Size=0x00050000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
08-06-2011, 16:49 | #44 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Code: Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM10 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_EN71GL064 setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. |
03-05-2012, 16:33 | #45 (permalink) |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | symphony d25 flashing done Code: Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key D-=2 D+=3 Done. Detecting USB device... USB mass storage device found[ J:] Loading bootloader... Done. Reading H/W Info... RamSize=0x00400000 BB: MSW85xx Flash: NUMONYX_M58LR128KC Read information has been completed. Erasing Flash... Done. Programming... All Done. |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
