08-06-2019, 12:35 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Redmi Note 5 is always in Mi recovery, unbrick via MRT Via https://www.imei.info check it: IMEI.INFO: REDMI NOTE 5 (MET7S) ARB - 4 Try flash it via MiFlashPro (miui_HMNote5Global_V10.3.1.0.PEIMIXM_d4d2c9f2aa_9 .0), flash Ok, but phone load in Mi Recovery Try flash it via MiFlashPro (miui_HMNote5_V10.3.4.0.PEICNXM_f9c9e6de7d_9.0), not flash - error Try flash via XiaoMiFlash in edl mode, but need authorized account Try flash via MRT in edl mode (whyred_images_V10.3.4.0.PEICNXM_20190711.0000.00_ 9.0_cn_41832361d1), but - error Only when replaced this files in folder with FW prog_emmc_firehose_Sdm660_ddr.elf prog_emmc_firehose_Sdm660_lite.elf MRT flash it completely Code: >>>>Auto Identify 9008 Port... Get 9008 Port;Is:COM95 >>>>Reading Mobile Hardware Info...Succes CPU_SN: 0x58BED76B MSM_ID: 0x000CC0E1 >>>Trying Connect Mobile...Success >>>Initialize Connect Mobile...Success >>>Downloading Boot...Success >>>Switch Mobile to ReWr ModeSuccess Flash Type: UFS >>>>Start Erase storsec Data... ADD:0x0000040000 Size0x000000C010 Success >>>>Start Erase storsecbak Data... ADD:0x0000040000 Size0x000000C010 Success >>>>Start Erase rpm Data... ADD:0x0000200000 Size0x0000036E28 Success >>>>Start Erase rpmbak Data... ADD:0x0000200000 Size0x0000036E28 Success >>>>Start Erase hyp Data... ADD:0x0000300000 Size0x0000044000 Success >>>>Start Erase hypbak Data... ADD:0x0000300000 Size0x0000044000 Success >>>>Start Erase pmic Data... ADD:0x0000400000 Size0x0000009B48 Success >>>>Start Erase pmicbak Data... ADD:0x0000400000 Size0x0000009B48 Success >>>>Start Erase cmnlib Data... ADD:0x0000500000 Size0x00000363E8 Success >>>>Start Erase cmnlibbak Data... ADD:0x0000500000 Size0x00000363E8 Success >>>>Start Erase cmnlib64 Data... ADD:0x0000700000 Size0x0000042EB8 Success >>>>Start Erase cmnlib64bak Data... ADD:0x0000700000 Size0x0000042EB8 Success >>>>Start Erase abl Data... ADD:0x0000900000 Size0x0000025000 Success >>>>Start Erase ablbak Data... ADD:0x0000900000 Size0x0000025000 Success >>>>Start Erase devcfgbak Data... ADD:0x0000E00000 Size0x000000BFAC Success >>>>Start Erase devcfg Data... ADD:0x0000E00000 Size0x000000BFAC Success >>>>Start Erase tz Data... ADD:0x0001000000 Size0x00001E1000 Success >>>>Start Erase tzbak Data... ADD:0x0001000000 Size0x00001E1000 Success >>>>Start Erase mdtpsecapp Data... ADD:0x0001800000 Size0x0000108648 Success >>>>Start Erase mdtpsecappbak Data... ADD:0x0001800000 Size0x0000108648 Success >>>>Start Erase keymaster Data... ADD:0x0002000000 Size0x0000058410 Success >>>>Start Erase keymasterbak Data... ADD:0x0002000000 Size0x0000058410 Success >>>>Start Erase bluetooth Data... ADD:0x0002200000 Size0x000008B000 Success >>>>Start Erase xbl Data... ADD:0x0002500000 Size0x0000272129 Success >>>>Start Erase xblbak Data... ADD:0x0002500000 Size0x0000272129 Success >>>>Start Erase dsp Data... ADD:0x0005800000 Size0x0001000000 Success >>>>Start Erase mdtp Data... ADD:0x0008000000 Size0x00010FBBB2 Success >>>>Start Erase splash Data... ADD:0x000C000000 Size0x00019F895C Success >>>>Start Erase modem Data... ADD:0x0018000000 Size0x0006950600 Success >>>>Start Erase boot Data... ADD:0x002C000000 Size0x0001A7154A Success >>>>Start Erase recovery Data... ADD:0x0030000000 Size0x000205154E Success >>>>Write cache data... Add:0x0034000000 Size0x0000020094 >>>>Write system data... Add:0x0044000000 Size0x00A8C20118 >>>>Write vendor data... Add:0x0104000000 Size0x002D4B7100 >>>>Write cust data... Add:0x0184000000 Size0x000AE370DC >>>>Write userdata data... Add:0x01B8000000 Size0x00017AF1CC >>>>Start Erase PrimaryGPT Data... ADD:0x0000000000 Size0x0000004400 Success >>>>Making Mobile factory reset... >>>>Rebooting... Flash it via MiFlashPro (miui_HMNote5_V10.3.4.0.PEICNXM_f9c9e6de7d_9.0) Phone power on and work Then unlock bootloader, flash it to global via fastboot |
