Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MRT - Mobile repair tool
Old 12-06-2016, 12:49   #1 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 689
redmi note3 mi account always filed
cant remove mi account from redmi note3 always error
writing date
pls give me slution
Old 12-06-2016, 13:26   #2 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 6,776
Give screenshot ... And make sure driver has installed
Old 12-07-2016, 12:18   #3 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
same problem, driver installed, Miflash work fine
Old 12-07-2016, 12:47   #4 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 6,776
Better use depth flash cable or change with other cable
Old 12-07-2016, 13:10   #5 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
used deep Flash cable, fastboot reboot to edl and different driver, same result
Old 12-07-2016, 18:29   #6 (permalink)
Member: 2234291
Thanks Meter: 227
Uninstal all driver and instal again
Think fast no need asking fast bro
Old 12-07-2016, 23:33   #7 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
Explained to please the sequence of actions to remove the Mi account. Which phone mode should be in operation? 9008, fastboot. normal?
To zbilqis: very useful answer you will soon have 100 posts
Old 12-08-2016, 05:18   #8 (permalink)
A^A
Member: 573800
Thanks Meter: 30
Quite simple step actually:
I assume all drivers are installed properly
1. Don't open MRT yet, keep it close
2. Plug the cable into the phone, and put it on EDL mode
3. Make sure it's properly detected in device manager
4. Open MRT, pick Redmi Note 3 from drop down list
5. Finally click Remove Account
Done, turn it on, enable adb, and proceed Remove APK steps.
Hope that helps
The Following User Says Thank You to A^A For This Useful Post:
Old 12-08-2016, 09:01   #9 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
windows 10 64 bit suported?
Old 12-08-2016, 10:10   #10 (permalink)
A^A
Member: 573800
Thanks Meter: 30
off course, i'm using it right now
Old 12-08-2016, 10:33   #11 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
Your guide is correct, it worked! To remove the APK need Root?
Old 12-08-2016, 10:46   #12 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
when removing .apk i got an error
Old 12-08-2016, 11:00   #13 (permalink)
A^A
Member: 573800
Thanks Meter: 30
No need root at all.
If looking at your screenshot, seems MRT failed to get user permissions from phone.
I already explain this issue in another thread.
Nevermind, I will repeat here:
1. Make sure adb driver that installed in your system is the latest one.
2. Don't open MRT yet
3. Enable ADB in the phone (you know how to do this one)
4. Plug the cable into the phone, make sure phone properly detected in the device manager
5. Open ADB CMD prompt, and type adb devices, look at your phone screen, there should be an ADB notification ask for manual permission
6. Dont forget to TICK (always give) and click OK to allow it
7. Open MRT, finally click Remove APK
It should be okay by now
Old 12-08-2016, 11:33   #14 (permalink)
Mishel's Avatar
Member: 74053
Thanks Meter: 61
Thank you for your patience, I'll try. How many time it takes to delete APK? Firmware Version matter?
Old 12-08-2016, 12:53   #15 (permalink)
A^A
Member: 573800
Thanks Meter: 30
Should be quick, a minute or two, better using version 7.3.2 for higher success rate, especially for Note 3 Pro
Page generated in 0.39001 seconds with 8 queries
