11-10-2018, 15:16 | #1052 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Redmi 5A MCG3B micloud Unlocked by MRTKey Credited to : irvan |
The Following 4 Users Say Thank You to .::ARD::. For This Useful Post: |
11-11-2018, 07:53 | #1055 (permalink) |
Junior Member Join Date: Mar 2006
Member: 248435 Status: Offline Thanks Meter: 0 | good work for me, thanks bro >>> Device driver identification: MediaTek USB VCOM (Android) Version:PD1813F_EX_A_1.9.21 IMEI:861933044798031 Flash ID:90014a484347386134a221a8ccd085d7 >>>>doing factory reset... >>>>doing factory reset2... all is done!!! |
11-11-2018, 10:01 | #1056 (permalink) |
Freak Poster Join Date: Feb 2004 Location: BY Age: 49
Member: 52495 Status: Offline Thanks Meter: 25 | Meizu M810H FRP remove done >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x5D5CD1A9 MSM_ID: 0x000560E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>read mobile GPT data...Success Eraseing Block frp ADD:0x0156180000 Size:0x0000008000 Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
11-15-2018, 18:04 | #1057 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2125922 Status: Offline Sonork: 1601402 Thanks Meter: 112 | Mi4i Account remove done with MRT Connecting Mobile Phone... please connect your phone as fastboot... Clear Mobile data... Creating filesystem with parameters: Size: 28655464448 Block size: 4096 Blocks per group: 32768 Inodes per group: 8176 Inode size: 256 Journal blocks: 32768 Label: Blocks: 6995963 Block groups: 214 ed block group size: 1024 Created filesystem with 11/1749664 inodes and 153850/6995963 blocks Creating filesystem with parameters: Size: 402653184 Block size: 4096 Blocks per group: 32768 Inodes per group: 8192 Inode size: 256 Journal blocks: 1536 Label: Blocks: 98304 Block groups: 3 Reserved block group size: 23 Created filesystem with 11/24576 inodes and 3131/98304 blocks target reported max download size of 268435456 bytes erasing 'userdata'... KAY [ 6.910s] sending 'userdata' (139073 KB)... OKAY [ 4.923s] writing 'userdata'... OKAY [ 2.008s] erasing 'cache'... OKAY [ 0.083s] sending 'cache' (8336 KB)... OKAY [ 0.297s] writing 'cache'... OKAY [ 0.120s] 42s Clear Mobile account data... erasing 'persist'... OKAY [ 0.041s] finished. total time: 0.041s reboot mobile set... rebooting... finished. total time: 0.001s |
The Following User Says Thank You to Bmszone For This Useful Post: |
11-25-2018, 08:31 | #1060 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Motorola XT1663 frp done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM11 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom... สึป๚ืดฬฌฮช: preloader Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524331344D Flash Name: Samsung_Unknow Flash symbol: RC14MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM44 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
The Following User Says Thank You to wsmobile For This Useful Post: |
11-26-2018, 12:36 | #1061 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Huawei Nxt-al10 ID done. >>>>Searching mobile phones... Get Hisi cpu Mobile Phones... >>> Get Mobile Port: COM6 >>>>Device identification : Android Adapter PCUI >>>>Switch Mobile to Auth Mode System Version:System 8.0.0.046(0IYH) Read information timeout.... PCB SN: o permission Mobile SN: no permission Mobile Code: mission >>>>Ersaeing Mobile accoutn data... >>>>Doing Factory Reset...Success All is done |
11-27-2018, 12:23 | #1062 (permalink) |
Major Poster Join Date: May 2005 Age: 46
Member: 143173 Status: Offline Thanks Meter: 10 | Vivo V7 1716 clean pass and bypass frp done ! Clean Pass : >>>Try connect to mobile...Success CPU_SN: 0xEDF55CA1 MSM_ID: 0x0009A0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>read mobile GPT data...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x0145482000 Size:0x0D4A379E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal ************************************************** ***** Bypass frp: >>>Try connect to mobile...Success CPU_SN: 0xEDF55CA1 MSM_ID: 0x0009A0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>read mobile GPT data...Success Eraseing Block frp ADD:0x0128180000 Size:0x0000008000 Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
The Following User Says Thank You to thimobile For This Useful Post: |
11-28-2018, 09:26 | #1063 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | MEIZU PRO 6 M570H MEIZU ACCOUNT UNLOCK DONE Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM10 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6797 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom...Success Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100424A4E4234 Flash Name: Samsung_Unknow Flash symbol: BJNB4R >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM7 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Geting Mobile info data... ADD(HEX):0x002A200000 Size(HEX):0x0000700000 >>>>Writeing Mobile info data... SN has Change to :80HBEPJ224JX >>>>Formating Mobile USER Data... ADD(HEX):0x00EB000000 Size(HEX):0x065BBF8000 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
