06-10-2019, 07:11 | #1216 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | VIVO Y69 Password Unlock & FRP Reset Done !! MRT Wbr, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
06-15-2019, 17:17 | #1217 (permalink) |
No Life Poster Join Date: Dec 2013 Location: ecuador
Member: 2078045 Status: Offline Thanks Meter: 151 | LENOVO PAD QUALCOMM REMOVE FRP BY MRT >>>>Connecting Port:COM20 >>>>Reading Mobile Hardware Info...Succes CPU_SN: 0x2F291E9A MSM_ID: 0x000550E1 >>>Initialize Boot Mobile...Success >>>>Download Boot1 to Mobile...Success >>>>Downloading Boot2 to Mobile...Success >>>>Switch Mobile to re/wr mode...Success >>>>Connecting Mobile...Success Flash Type:eMMC CPU Type: 8917 >>>>Reading Mobile GPT Block Data...Success Eraseing Block frp ADD:0x0136180000 Size:0x0000008000 Success Rebooting Mobile... all is done!!! |
06-16-2019, 08:46 | #1218 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Oppo R15 (PACM00) done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM7 >>> Device driver identification: MediaTek USB Port_V1632 >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000001D1EC00000 -> 119276M Flash ID: 0x150100335636434D Flash Name: Samsung_Unknow Flash symbol: 3V6CMB >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! |
The Following User Says Thank You to wsmobile For This Useful Post: |
06-17-2019, 08:37 | #1219 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | Oppo A5s dOne Disconnect Mobile... re-input Mobile Battery... then connect usb to computer.... Make Sure your Mobie have power... >>> Searching Mobile Com Port... Get Mobile Port: COM11 >>> Driver Identifying name: MediaTek USB Port >>> 手机连接正常... CPU_NAME: MT6765 >>> Reading Mobile Hardware info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Searching Mobile Com Port... Get Mobile Port: COM143 >>> try into Meta Mode...success Reading Mobile Base Info... CPU_TYPE:mt6765,S01 Bulid_Time:Fri Mar 22 12:05:10 CST 2019 Base_Ver:CPH1909_11_A.18_190322_34570289 Soft_Ver: factory reseting... rebooting... all is done!!! br, |
The Following User Says Thank You to buffer2k11 For This Useful Post: |
06-17-2019, 14:52 | #1221 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | huawei y5 prime frp Mobile Name: DRA-LX2 Mobile Set BL Lock state:nknown comman Trying First Way for Get the Unlock code Dynamic unlock code:15fe9dc50e8d8226 >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:nknown comman Trying First Way for Get the Unlock code Dynamic unlock code:152c3b33db0850d6 Try Qualcomm temp Bootloader unlock new function... >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:nknown comman Trying First Way for Get the Unlock code Dynamic unlock code:15199a9eef037edb Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... (bootloader) Erase success , the device will reboot and factory reset OKAY [ 0.013s] finished. total time: 0.013s >>>>Rebooting Mobile Phone rebooting... finished. total time: 0.001s |
The Following User Says Thank You to nadim electro For This Useful Post: |
06-17-2019, 14:56 | #1222 (permalink) |
Major Poster Join Date: May 2005 Age: 46
Member: 143173 Status: Offline Thanks Meter: 10 | OPPO F7 CPH1819 remove password ok. >>> Searching Mobile Port... Get Mobile Port is: COM21 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x90014A4843473861 Flash Name: Hynix_Unknow Flash symbol: HCG8a4 >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! |
The Following User Says Thank You to thimobile For This Useful Post: |
06-17-2019, 15:02 | #1223 (permalink) |
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | oppo a71 format done Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM219 >>> Device driver identification: Preloader And Gadget Serial >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom... 手机状态为: preloader Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100474536424D Flash Name: Samsung_Unknow Flash symbol: GE6BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM226 >>> Device driver identification: DA USB VCOM Port >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x013D000000 Size(HEX):0x0265DFBE00 Corresponding operation completed!!! |
06-19-2019, 12:46 | #1225 (permalink) |
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | oppo f1s frp+format done Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM225 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524836344D Flash Name: Samsung_Unknow Flash symbol: RH64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM226 >>> Device driver identification: DA USB VCOM Port >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00E1000000 Size(HEX):0x0DAD7FBE00 Corresponding operation completed!!! frp done Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM225 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524836344D Flash Name: Samsung_Unknow Flash symbol: RH64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM226 >>> Device driver identification: DA USB VCOM Port >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
06-23-2019, 16:57 | #1227 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | huawei Can L11 Done. Code: >>> Get Mobile Port: COM19 >>>>Device identification : DBAdapter Reserved Interface Try Qualcomm Unlock Frp function Connect Mobile success... Try Qualcomm Unlock Frp function Connect Mobile success... >>>>Connecting Unlock Service... Connect Service Success.... >>>>Sending Auth Data to Service... >>>>Sending 2ed time Auth Data to Server... verification data success.... >>>>Writing Mobile IMEI2 Data... Update success >>>>Reading Mobile data after move... IMEI2: 35******** >>>>Updateing IMEI1 Data... Update Success >>>>Readback Mobile data after update... IMEI: 35********** >>>>Remove Mobile version restrictions... >>>>Write Facotry Reset Data... Factory Reset Success |
06-29-2019, 12:28 | #1228 (permalink) |
No Life Poster Join Date: Aug 2014
Member: 2233266 Status: Offline Thanks Meter: 252 | vivo 1814 formate done >>> Device driver identification: MediaTek USB VCOM (Android) Version:PD1818DF_EX_A_1.9.15 IMEI:865682046360839 Flash ID:150100475036424d42012ac5d828a579 >>>>doing factory reset... >>>>doing factory reset2... all is done!!! |
06-30-2019, 04:55 | #1229 (permalink) |
Major Poster Join Date: Oct 2015 Location: Vietnams
Member: 2478964 Status: Offline Sonork: Zalo:0932606079 Thanks Meter: 24 | Vivo Y97 Fomat + FRP OK THANKS MRT TEAM Disconnect Mobile... re-input Mobile Battery... then connect usb to computer.... Make Sure your Mobie have power... >>> Searching Mobile Com Port... Get Mobile Port: COM33 >>> Driver Identifying name: MediaTek USB Port_V1632 >>> 手机连接正常... CPU_NAME: MT6771 >>> Reading Mobile Hardware info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initializing Mobile Phone...>>> Sending AUTH file...Success >>> Downloading boot1 to Mobile...Success 手机状态:SYNC... 手机状态切换为 :brom...成功 确认手机状态为 :brom... Initializationing BOOT2 ... =====================Flash 类型(eMMC)============== Flash Size: 0x0000001D1EC00000 -> 119276M Flash ID: 0x150100445636444D Flash Name: Samsung_Unknow Flash Code: DV6DMB >>> Reading Mobile GPT data...Success >>>>Write Data to Mobile userdata ... all is done!!! >>> Searching Mobile Com Port... Get Mobile Port: COM33 >>> Driver Identifying name: MediaTek USB Port_V1632 >>> 手机连接正常... CPU_NAME: MT6771 >>> Reading Mobile Hardware info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initializing Mobile Phone...>>> Sending AUTH file...Success >>> Downloading boot1 to Mobile...Success 手机状态:SYNC... 手机状态切换为 :brom...成功 确认手机状态为 :brom... Initializationing BOOT2 ... =====================Flash 类型(eMMC)============== Flash Size: 0x0000001D1EC00000 -> 119276M Flash ID: 0x150100445636444D Flash Name: Samsung_Unknow Flash Code: DV6DMB >>> Reading Mobile GPT data...Success >>>>Get Mobile Account data... Add:05588000 all is done!!! |
06-30-2019, 17:18 | #1230 (permalink) |
Junior Member Join Date: Oct 2017 Location: Ukraine/Kiev
Member: 2772355 Status: Offline Thanks Meter: 2 | >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: JMM-L22 Mobile Set BL Lock state:nknown comman Trying First Way for Get the Unlock code Dynamic unlock code:5ca60f5134c05f17 >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:nknown comman Trying First Way for Get the Unlock code Dynamic unlock code:5ca60f5134c05f17 Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... (bootloader) Erase success , the device will reboot and factory reset OKAY [ 0.052s] finished. total time: 0.052s >>>>Rebooting Mobile Phone |
