12-26-2016, 05:56 | #136 (permalink) |
Junior Member Join Date: Oct 2016 Location: BASVAN BAGEWADI Bijapur Age: 33
Member: 2636357 Status: Offline Thanks Meter: 13 | http://forum.gsmhosting.com/vbb/f492/story-success-mrt-product-read-write-format-unlo |
12-28-2016, 08:35 | #138 (permalink) |
Registered User Join Date: Mar 2010
Member: 1260168 Status: Offline Thanks Meter: 62 | MI 5 MI Account remove Success >>>>Get the Qualcomm 9008 Driver... HS-USB Diagnostics 9008 (COM7) >>>>Init Device and Connect it...Success >>>>Set Boot Filerog_ufs_firehose_8996_ddr.elf >>>>Set Flash File:rawprogram0.xml >>>>Reading Mobile Info... Version 2.15 SerialNumber: 0x34ab6f43 MSM_HW_ID: 0x009470e1 OEM_PK_HASH: 0x355d47f912fea0af1f46c007c6dc22c43544fb9359e30aa7 db5f4734d18fbd74 SBL SW Version: 0x00000000 Status: 0 The operation completed successfully. >>>>Writing Unlock Date... Corresponding operation completed!!! tip: after unlock,If Connect network,maybe it will lock again Then you need unlock again,and Remove the cloud apk After Remove Cloud,Some Xiaomi APK will not wroking This is a beta function;not sure can working will all Some Set Mobile Phone need flash MIUI7.5 or > 7.5 first |
12-30-2016, 10:15 | #139 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | When all other tool fail ....... Spice Xlife 364 3G+ ( NAND ) Phone was dead by a leading tool during format Fail to recover by Flashing ( Result Flash fail ) .... Finally by MRT Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM57 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6572 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success >>> Initializationing Mobile Hardware Parameter...Success >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(NAND)============== Flash Size: 0x20000000 -> 512M Flash ID: 0x009800BC00900066 Flash symbol: NAND_TOSHIBATYBC0A111236KC10 >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM58 >>> Device driver identification: DA USB VCOM Port >>> Reading Mobile Map Data...Success Writeing Mobile Initialization 1...Success >>> Creating Mobile PMT Data Table...Success Writeing Block6....Success Writeing Block7....Success Writeing Block8....Success Writeing Block9....Success Writeing Block11....Success Writeing Block13....Success Writeing Block15....Success Corresponding operation completed!!! |
The Following 3 Users Say Thank You to srinibas For This Useful Post: |
01-04-2017, 06:33 | #141 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Oppo F1s only solved by MRT Dongle show me which tool can do it case passcode try unlock with other tool but the device is dead Bring to other service centre facing problem Emmc config not found and Finally and Lucky him who have MRT Dongle in his hand Make Money again with MRT Dongle ! MRT DONGLE Make it alive !! Have a nice day ! |
