07-26-2017, 11:13 | #421 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | |
The Following User Says Thank You to .::ARD::. For This Useful Post: |
07-26-2017, 14:22 | #422 (permalink) |
Insane Poster Join Date: Nov 2014
Member: 2296229 Status: Offline Thanks Meter: 35 | redmi note 4x mi account done redmi note 4x remove account very easy.. just a single click by mrt thanks om >>>Try connect to mobile...Success CPU_SN: 0xCD89CF28 MSM_ID: 0x000460E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>> Reading Mobile Map Data...Success >>>>Downloading Unlock File... Unlock File Download Finish >>>>Writing Unlock Date... Start: 0x0x00F4000000 Size: 0x0x0002000000 Success Corresponding operation completed!!! |
07-26-2017, 14:22 | #423 (permalink) |
Member: 2296229 Status: Offline Thanks Meter: 35 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] redmi note 4x remove account very easy.. just a single click by mrt thanks om >>>Try connect to mobile...Success CPU_SN: 0xCD89CF28 MSM_ID: 0x000460E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>> Reading Mobile Map Data...Success >>>>Downloading Unlock File... Unlock File Download Finish >>>>Writing Unlock Date... Start: 0x0x00F4000000 Size: 0x0x0002000000 Success Corresponding operation completed!!! |
The Following User Says Thank You to v1ckr For This Useful Post: |
07-27-2017, 12:49 | #424 (permalink) |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Opp A37f pattern Remove done Just a Single Click Code: >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x20A6649D MSM_ID: 0x007050E1 CPU型号: MSM8916 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>正在读取手机分区数据...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x00E2788000 Size:0x02C1673E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
The Following User Says Thank You to VC_INDIA For This Useful Post: |
07-27-2017, 14:09 | #425 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Moskva
Member: 2739449 Status: Offline Thanks Meter: 185 | Redmi 4 16/2 Remove ACCOUNT DONE!!! >>>Try connect to mobile...Success CPU_SN: 0xB75A31F3 MSM_ID: 0x0004F0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>> Reading Mobile Map Data...Success >>>>Downloading Unlock File... Unlock File Download Finish >>>>Writing Unlock Date... Start: 0x0x000E000000 Size: 0x0x0002000000 Success Corresponding operation completed!!! |
The Following User Says Thank You to Faruxchik For This Useful Post: |
07-28-2017, 06:25 | #426 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,364 | Redmi 3 mi account (relock) complete remove done Redmi 3 mi account (relock) complete remove done with mi_account_unlock_tool [IMG][/IMG] CPU_SN: 0x090DD293 MSM_ID: 0x0090B0E1 CPU Name: MSM8939 >>>>Try connect to mobile...Success >>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>> Reading Mobile Map Data...Success >>>>Downloading Unlock File... Unlock File Download Finish >>>>Writing Unlock Date... Start: 0x0x009E18C000 Size: 0x0x0002000000 Success Corresponding operation completed!!! |
07-28-2017, 13:27 | #427 (permalink) |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] motorola xt1709 frp reset done Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM7 >>> Device driver identification: MediaTek PreLoader USB VCOM Port >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:QE13MB >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100514531334D Flash Name: Samsung_Unknow Flash symbol: QE13MB >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM12 >>> Device driver identification: DA USB VCOM Port >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM12 >>> Device driver identification: DA USB VCOM Port >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0009A80000 Size(HEX):0x0000100000 Corresponding operation completed!!! |
08-01-2017, 11:25 | #428 (permalink) |
Major Poster Join Date: Oct 2014
Member: 2268654 Status: Offline Thanks Meter: 0 | REDMI NOTE 3 PRO REMOVE MICLOUD >>>Try connect to mobile...Success CPU_SN: 0x01F7A7F3 MSM_ID: 0x009B00E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>> Reading Mobile Map Data...Success >>>>Downloading Unlock File... Unlock File Download Finish >>>>Writing Unlock Date... Start: 0x0x00D4000000 Size: 0x0x0002000000 Success Corresponding operation completed!!! |
08-01-2017, 11:31 | #429 (permalink) |
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Vivo V5S DEMO LIVE + FRP REMOVED [ 1 $hot 2 Kill by MRT DONGLE ] Credited to : haqisan Last edited by VC_INDIA; 08-02-2017 at 08:56. |
08-01-2017, 14:49 | #430 (permalink) |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | MI 5 done, no relock Code: >>>Try connect to mobile...Success CPU_SN: 0x8A0A4407 MSM_ID: 0x009470E1 >>>Try connect to mobile...Success >>> Initialization Mobile ...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: UFS CPU Type: MSM8996 >>> Reading Mobile Map Data...Success >>>>Downloading Unlock File... Unlock File Download Finish >>>>Writing Unlock Date... Start: 0x0002000000 Size: 0x0002000000 >>>>Flashing Mobile data...Success Corresponding operation completed!!! WBR |
08-02-2017, 08:38 | #431 (permalink) |
Freak Poster Join Date: Aug 2016 Location: out of world
Member: 2609423 Status: Offline Sonork: 1660954:2007 Thanks Meter: 360 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM43 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525831424D Flash Name: Samsung_Unknow Flash symbol: RX1BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM44 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00EB000000 Size(HEX):0x065BBFBE00 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
08-02-2017, 11:10 | #432 (permalink) |
Banned Join Date: Jan 2015 Location: EARTH Age: 40
Member: 2332823 Status: Offline Sonork: 100.1662161:modern-mobile Thanks Meter: 463 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] oppo f3 cph1609 frp lock done MRT DONGLE Regards, ___________ modern-mobile |
08-02-2017, 14:08 | #433 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Vancouver BC & Kathmandu Nepal
Member: 538410 Status: Offline Sonork: 100.1590750 Thanks Meter: 193 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] Last edited by .::ARD::.; 08-02-2017 at 18:18. Reason: Showing image |
08-02-2017, 15:52 | #434 (permalink) |
Member: 2332823 Status: Offline Sonork: 100.1662161:modern-mobile Thanks Meter: 463 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] World first Karbonn K9 Viraat 4G erase frp done by ***(MRT DONGLE)*** Regards,, ..::modern-mobile::.. |
08-03-2017, 09:27 | #435 (permalink) |
Freak Poster Join Date: May 2017 Location: Manila/Philippine
Member: 2714943 Status: Offline Thanks Meter: 94 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] Acer Z630 (T03) FRP Done By MRT Procedure 1: Open MRT Soft. 2: MTK Tab 3: Check Erase FRP 4: Click Start Then Follow the Instructions |
