08-04-2017, 04:51 | #436 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Searching Android Mobile... Get the Android Deivers Mobile Info: INFO Device style: PD1510_C_4.15.0 Try Unlock Bootload with algorithm 1 algorithm 1 Info: FAILunknown command or device is lock Try Unlock Bootload with algorithm 2 algorithm 2 Info: FAILunknown command or device is lock Eraseing Block userdata ================================================ Creating filesystem with parameters: Size: 11785973760 Block size: 4096 Blocks per group: 32768 Inodes per group: 8176 Inode size: 256 Journal blocks: 32768 Label: Blocks: 2877435 Block groups: 88 d block group size: 703 Created filesystem with 11/719488 inodes and 84965/2877435 blocks Creating filesystem with parameters: Size: 157286400 Block size: 4096 Blocks per group: 32768 Inodes per group: 4800 Inode size: 256 Journal blocks: 1024 Label: Blocks: 38400 Block groups: 2 Reserved block group size: 15 Created filesystem with 11/9600 inodes and 1665/38400 blocks target reported max download size of 268435456 bytes erasing 'userdata'... 0.392s] sending 'userdata' (136726 KB)... OKAY [ 4.299s] writing 'userdata'... OKAY [ 2.182s] erasing 'cache'... OKAY [ 0.041s] sending 'cache' (5400 KB)... OKAY [ 0.172s] writing 'cache'... OKAY [ 0.071s] finished. total time: 7.230s rebooting... finished. total time: 0.001s Open Com Port Fail,Please Try Again!!! |
08-04-2017, 07:02 | #437 (permalink) |
No Life Poster Join Date: Jul 2008 Location: indonesia
Member: 804772 Status: Offline Thanks Meter: 129 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] f1s phone lock succes and vivo v5 succes unbrick https://ibb.co/kMfX6a and https://ibb.co/hHpaRa thanks before |
08-04-2017, 08:32 | #438 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO R9s plus done. >>>Try connect to mobile...Success CPU_SN: 0x026DDC9D MSM_ID: 0x009900E1 CPUะอบล: MSM8976 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>ีิฺถมศกสึป๚ทึว๘สพ...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x00D5482000 Size:0x0DBA379E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
The Following User Says Thank You to wsmobile For This Useful Post: |
08-04-2017, 13:34 | #439 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Russia, Ivanovo city
Member: 2006990 Status: Offline Thanks Meter: 540 | Xaomi Redmi 4 markw miu 8.2.4 remowe account done >>>Try connect to mobile...Success CPU_SN: 0xFCE2DCD7 MSM_ID: 0x000460E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>> Reading Mobile Map Data...Success >>>>Downloading Unlock File... Unlock File Download Finish >>>>Writing Unlock Date... Start: 0x0x00F4000000 Size: 0x0x0002000000 Success Corresponding operation completed!!! Thanks MRT Team!!!! |
08-05-2017, 00:10 | #440 (permalink) |
Junior Member Join Date: Jun 2010 Location: morocco
Member: 1320807 Status: Offline Thanks Meter: 2 | Redmi 5s Remove ACCOUNT DONE! >>> Initialization Mobile ...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: UFS CPU Type: MSM8996 >>> Reading Mobile Map Data...Success >>>>Downloading Unlock File... Unlock File Download Finish >>>>Writing Unlock Date... Start: 0x0002000000 Size: 0x0002000000 >>>>Flashing Mobile data...Success Corresponding operation completed!!! |
The Following User Says Thank You to djou22 For This Useful Post: |
08-05-2017, 15:33 | #442 (permalink) | |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] Vivo Y66 Demo Remove Done Only Single Click Quote:
VC_INDIA | |
08-08-2017, 17:13 | #444 (permalink) |
Junior Member Join Date: Jun 2017
Member: 2731011 Status: Offline Thanks Meter: 5 | Remove account m3 note done choose m3s, not m3note. pls fix it Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM3 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x00000002A5000000 -> 10832M Flash ID: 0x7001004548414345 Flash Name: Kingston_Unknow Flash symbol: EHACEA >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM9 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Geting Mobile info data... ADD(HEX):0x0023BC8000 Size(HEX):0x0000700000 >>>>Writeing Mobile info data... This Phone Support CDMA SN has Change to :91QEBPJ62RYP SN has Change to :91QEBPJ62RYP >>>>Formating Mobile USER Data... ADD(HEX):0x00EB000000 Size(HEX):0x02B8FFBE00 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
The Following User Says Thank You to thanhdatpd For This Useful Post: |
08-09-2017, 05:57 | #445 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO A59S done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM55 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525831344D Flash Name: Samsung_Unknow Flash symbol: RX14MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM59 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00A0800000 Size(HEX):0x06A63FBE00 Corresponding operation completed!!! |
08-10-2017, 09:20 | #447 (permalink) |
Freak Poster Join Date: Oct 2016 Location: World
Member: 2635143 Status: Offline Thanks Meter: 166 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] >>>Try connect to mobile...Success CPU_SN: 0x03C03C89 MSM_ID: 0x009900E1 CPU Name: MSM8976 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>> Reading Mobile Map Data...Success >>>>Downloading Unlock File... Unlock File Download Finish >>>>Writing Unlock Date... Start: 0x0x0010000000 Size: 0x0x0002000000 Success Corresponding operation completed!!! Xiaomi Mi Max - MI Account Unlock Done !!!!! |
08-10-2017, 10:42 | #448 (permalink) |
Freak Poster Join Date: Aug 2015 Location: asdfsdf
Member: 2439634 Status: Offline Sonork: logimon999 Thanks Meter: 188 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] 1. edl mode same note 4x 2. run mi account unlock tool 3. choose note 4x 4. start >>>Try connect to mobile...Success CPU_SN: 0x4264B2BA MSM_ID: 0x000460E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>> Reading Mobile Map Data...Success >>>>Downloading Unlock File... Unlock File Download Finish >>>>Writing Unlock Date... Start: 0x0x00F4000000 Size: 0x0x0002000000 Success Corresponding operation completed!!! Thanks teacher Zhulianqi and MRT team |
The Following User Says Thank You to logimon999 For This Useful Post: |
08-11-2017, 08:42 | #449 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | MEIZU M5 UNLOCK DONE !!!!!!!!! credited to : lasergsm Nice Jockey !!! |
The Following User Says Thank You to .::ARD::. For This Useful Post: |
