01-28-2018, 10:14 | #781 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Nepal
Member: 1370803 Status: Offline Sonork: ma341032 Thanks Meter: 36 | Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM382 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:NQ2J96 >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x13014E51324A3936 Flash Name: UNKNOWN Flash symbol: NQ2J96 >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM384 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM384 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0009B20000 Size(HEX):0x0000100000 Corresponding operation completed!!! |
01-28-2018, 10:39 | #782 (permalink) |
No Life Poster Join Date: Aug 2008 Location: PhnomPenh Cambodia
Member: 846616 Status: Offline Sonork: 100.1675590 Thanks Meter: 581 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM437 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM272 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00E1000000 Size(HEX):0x0665BFBE00 Corresponding operation completed!!! |
01-29-2018, 12:22 | #783 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | MEIZU done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM54 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6752 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:R821MB >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100523832314D Flash Name: Samsung_KMR820001M_B609 Flash symbol: R821MB >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM87 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>> Analysis of mobile phone data... >>>>Reading Mobile Org Info.... Success >>>>Moving Mobile Info... SN has Change to :71UBDL62228V >>>>Formating Mobile USER Data... ADD(HEX):0x008F000000 Size(HEX):0x0313D80000 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
01-29-2018, 23:09 | #784 (permalink) |
Freak Poster Join Date: Jun 2008 Location: COLOMBIA
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | HUAWEI G735-L03 IN LOGO FULL FLASH SUCCESS...... >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: :G735-L03 Mobile Set BL Lock statemmand not allowe Trying First Way for Get the Unlock code Read Mobile Dynamic unlock code Fail Trying Second Way for Get the Unlock code Dynamic unlock code:30fccf258a1f4e89 Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>search android fastboot devices... >>>>Get android fastboot devices... Write Flash To Block efi...Fail FAILpartition does not exist Write Flash To Block modemimage...Success Write Flash To Block modemnvm1...Success Write Flash To Block mcuimage...Success Write Flash To Block hifi...Success Write Flash To Block dsp...Success Write Flash To Block dtimage...Success Write Flash To Block fastboot1...Success Write Flash To Block fastboot...Success Write Flash To Block recovery...Success Write Flash To Block recovery2...Success Write Flash To Block boot...Success Write Flash To Block cache...Success Write Flash To Block userdata...Success Creat Temp File system... Write Flash To Block system... tip:software is runing please wait;it will take about 5 min... target reported max download size of 524288000 bytes sending sparse 'system' (505849 KB)... OKAY [ 23.337s] writing 'system'... OKAY [ 12.027s] sending sparse 'system' (503427 KB)... OKAY [ 23.710s] writing 'system'... OKAY [ 11.961s] rse 'system' (492484 KB)... OKAY [ 23.158s] writing 'system'... OKAY [ 11.718s] sending sparse 'system' (222442 KB)... OKAY [ 10.361s] writing 'system'... OKAY [ 5.279s] finished. total time: 121.551s Creat Temp File system... Write Flash To Block cust... tip:software is runing please wait;it will take about 5 min... target reported max download size of 524288000 bytes sending 'cust' (195451 KB)... OKAY [ 7.636s] writing 'cust'... OKAY [ 4.641s] finished. total time: 12.278s >>>>Rebooting Mobile Phone rebooting... finished. total time: 0.000s tip: if mobile hand on logo... disconnect mobile and hold vol up+power key,then factory reset will ok |
The Following User Says Thank You to Hacker84 For This Useful Post: |
01-30-2018, 08:15 | #785 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] LUA-U22 boot loop 1000% SOLVED BY MRT ( Credited to : Rudy Hartono ) |
01-30-2018, 08:43 | #786 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | symphony p9 (MT6753) secure boot frp remove done symphony p9 (MT6753) secure boot frp remove done [IMG][/IMG] Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM57 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:RX1BMB >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525831424D Flash Name: Samsung_Unknow Flash symbol: RX1BMB >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM78 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM78 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0006A00000 Size(HEX):0x0000100000 Corresponding operation completed!!! great mrt dongle |
The Following 3 Users Say Thank You to pintu_das For This Useful Post: |
01-30-2018, 18:36 | #787 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Erth Age: 40
Member: 1497980 Status: Offline Thanks Meter: 1,266 | Huawei Honor 8 FRD-L09 HW ID REOMOVE DONE WITH SNIPER TOOL MRT Huawei Honor 8 FRD-L09 HW ID REOMOVE DONE WITH SNIPER TOOL MRT |
The Following User Says Thank You to rizwankhan8670 For This Useful Post: |
01-31-2018, 05:52 | #788 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVO V5s done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM54 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524836344D Flash Name: Samsung_Unknow Flash symbol: RH64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM87 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
01-31-2018, 06:56 | #789 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO F5 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM55 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM173 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! |
The Following User Says Thank You to wsmobile For This Useful Post: |
01-31-2018, 07:29 | #790 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO A71 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM55 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100474536424D Flash Name: Samsung_Unknow Flash symbol: GE6BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM173 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x013D000000 Size(HEX):0x0265DFBE00 Corresponding operation completed!!! |
02-06-2018, 09:18 | #792 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO A83 CPH1729 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM20 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM139 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... >>>>Formating Mobile USER Data... ADD(HEX):0x0170800000 Size(HEX):0x05D63FBE00 Corresponding operation completed!!! |
02-08-2018, 06:13 | #795 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO A71 (CPH1717) done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100474536424D Flash Name: Samsung_Unknow Flash symbol: GE6BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM21 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x013D000000 Size(HEX):0x0265DFBE00 Corresponding operation completed!!! |
