02-08-2018, 07:14 | #796 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Tamilnadu
Member: 2749644 Status: Offline Sonork: 100.1678692 Thanks Meter: 47 | >>>Try connect to mobile...Success CPU_SN: 0x213EEF38 MSM_ID: 0x007050E1 CPU型号: MSM8916 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>正在读取手机分区数据...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x00E5600000 Size:0x02BE7FBE00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal Y21 L format done |
02-08-2018, 09:51 | #797 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Erth Age: 40
Member: 1497980 Status: Offline Thanks Meter: 1,266 | Lava A3 Mini Frp Lock Secure Boot Done With MRT Dongle Just Format Lava A3 Mini Frp Lock Secure Boot Done With MRT Dongle Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM23 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:JHAG4a >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x90014A4841473461 Flash Name: Hynix_Unknow Flash symbol: JHAG4a >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM24 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM24 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0124000000 Size(HEX):0x0286380000 Corresponding operation completed!!! |
The Following User Says Thank You to rizwankhan8670 For This Useful Post: |
02-09-2018, 08:53 | #798 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO CPH1727 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM20 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100334836434D Flash Name: Samsung_Unknow Flash symbol: 3H6CMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM139 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM20 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100334836434D Flash Name: Samsung_Unknow Flash symbol: 3H6CMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM139 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
02-09-2018, 12:01 | #799 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO CPH1723 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM20 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525836344D Flash Name: Samsung_Unknow Flash symbol: RX64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM139 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM20 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525836344D Flash Name: Samsung_Unknow Flash symbol: RX64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM139 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
02-10-2018, 06:30 | #800 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2760239 Status: Offline Thanks Meter: 5 | Success Unlock Bootloader Huawei CAM-L21 >>>>Searching mobile phones... Get Hisi cpu Mobile Phones... >>> Get Mobile Port: COM46 >>>>Device identification : Android Adapter PCUI >>>>Switch Mobile to Auth Mode PCB SN: DU3SGD16B8027785 Mobile SN: LHTFG16B21012141 Mobile Code: mission >>>>Setting Bootloader Unlock Key...Success Success Setting Bootloader Unlock Key To: 0000000000000000 Tip after connect mobile to computer;Hold Vol down+Power Key To fastboot in the cmd windows input fastboot oem unlock 0000000000000000;You can unlock Bootloader after Unlock Bootloader,Mobile will lost all the data All is done |
The Following User Says Thank You to febriancaraka For This Useful Post: |
02-10-2018, 14:05 | #801 (permalink) |
Member: 2760239 Status: Offline Thanks Meter: 5 | CPH1725 Reset Pattern Lock Done by MRT!! Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM62 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM63 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! |
02-13-2018, 12:04 | #802 (permalink) |
Member: 1497980 Status: Offline Thanks Meter: 1,266 | Lava A3 Mini Frp Lock Secure Boot Done With MRT Dongle Lava A3 Mini Frp Lock Secure Boot Done With MRT Dongle Code: Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM53 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:QE13MB >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100514531334D Flash Name: Samsung_Unknow Flash symbol: QE13MB >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM24 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM24 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0006A00000 Size(HEX):0x0000100000 Corresponding operation completed!!! |
02-14-2018, 06:43 | #803 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO CPH1717 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100474536424D Flash Name: Samsung_Unknow Flash symbol: GE6BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM21 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100474536424D Flash Name: Samsung_Unknow Flash symbol: GE6BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM21 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x013D000000 Size(HEX):0x0265DFBE00 Corresponding operation completed!!! |
The Following User Says Thank You to wsmobile For This Useful Post: |
02-14-2018, 07:07 | #804 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVO V5 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM20 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525831344D Flash Name: Samsung_Unknow Flash symbol: RX14MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM139 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Writeing Mobile info data... >>>>Writeing Mobile info data... >>>>Formating Mobile USER Data... ADD(HEX):0x00F9800000 Size(HEX):0x064D3FBE00 Corresponding operation completed!!! |
02-14-2018, 13:20 | #805 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO F5 YOUTH CPH1725 PATTERN LOCK REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK (OPPO F5 YOUTH CPH1725)USB Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM62 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM63 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! THANKS MRT-TOOL TEAM |
02-14-2018, 13:21 | #806 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MEIZU PRO 6S ACCOUNT REMOVE Done SUCCESSFULLY ACCOUNT REMOVE(MEIZU PRO 6S)USB Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM11 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6797 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom...Success Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100434A4E4234 Flash Name: Samsung_Unknow Flash symbol: CJNB4R >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek DA USB VCOM Port >>> Reading Mobile Map Data...Success >>>>Geting Mobile info data... ADD(HEX):0x002A200000 Size(HEX):0x0000700000 >>>>Writeing Mobile info data... SN has Change to :80SQDDQ822FR >>>>Formating Mobile USER Data... ADD(HEX):0x00EB000000 Size(HEX):0x0DA37F8000 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! THANKS MRT-TOOL TEAM |
02-14-2018, 13:22 | #807 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | HUAWEI CHM-U01 Honor 4C WRITE FLASH Done SUCCESSFULLY WRITE FLASH(HUAWEI CHM-U01 Honor 4C)USB >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: :CHM-U01 Mobile Set BL Lock statemmand not allowe Trying First Way for Get the Unlock code Read Mobile Dynamic unlock code Fail Trying Second Way for Get the Unlock code Dynamic unlock code:62b1c11e08d7a6b7 Connecting To Service... Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>search android fastboot devices... >>>>Get android fastboot devices... Writeing Block sha256rsa...Fail FAILpartition does not exist Writeing Block crc...Fail FAILpartition does not exist Writeing Block efi...Fail FAILpartition does not exist Writeing Block modemimage...Success Writeing Block modemnvm1...Success Writeing Block mcuimage...Success Writeing Block hifi...Success Writeing Block dsp...Success Writeing Block dtimage...Success Writeing Block fastboot1...Success Writeing Block fastboot...Success Writeing Block recovery...Success Writeing Block recovery2...Success Writeing Block boot...Success Writeing Block cache...Success Writeing Block userdata...Success updating temp file form flash file... Writeing Block system... tip:software is runing,maybe it will take 2~5 Minute target reported max download size of 524288000 bytes sending sparse 'system' (511577 KB)... OKAY [ 18.201s] writing 'system'... OKAY [ 8.411s] sending sparse 'system' (497290 KB)... OKAY [ 18.259s] writing 'system'... OKAY [ 8.180s] rse 'system' (511418 KB)... OKAY [ 18.619s] writing 'system'... OKAY [ 8.410s] sending sparse 'system' (117606 KB)... OKAY [ 4.320s] writing 'system'... OKAY [ 1.942s] finished. total time: 86.344s updating temp file form flash file... Writeing Block cust... tip:software is runing,maybe it will take 2~5 Minute target reported max download size of 524288000 bytes sending 'cust' (119700 KB)... OKAY [ 4.081s] writing 'cust'... OKAY [ 1.970s] finished. total time: 6.051s >>>>Rebooting Mobile Phone rebooting... THANKS MRT-TOOL TEAM |
02-14-2018, 13:26 | #808 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO A77 CPH1715 PATTERN LOCK REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK(OPPO A77 CPH1715)USB Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM482 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524836344D Flash Name: Samsung_Unknow Flash symbol: RH64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM269 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x0137000000 Size(HEX):0x0D577FBE00 Corresponding operation completed!!! THANKS MRT-TOOL TEAM |
The Following User Says Thank You to gracy_elec For This Useful Post: |
02-14-2018, 13:27 | #809 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | VIVO V5 USER LOCK REMOVE Done SUCCESSFULLY REMOVE USER LOCK(VIVO V5)USB Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM481 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525831424D Flash Name: Samsung_Unknow Flash symbol: RX1BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM122 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00F9800000 Size(HEX):0x064D3FBE00 Corresponding operation completed!!! THANKS MRT-TOOL TEAM |
