02-17-2018, 12:02 | #811 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Erth Age: 40
Member: 1497980 Status: Offline Thanks Meter: 1,266 | Huawei Y7 Prime 7.0 Frp Lock Done With Mrt Tool Code: >>>>search android fastboot devices... >>>>Get android fastboot devices... Mobile Name: TRT-L21A Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:48b1b221a040063b >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:48949308844a3032 Try Qualcomm temp Bootloader unlock new function... >>>>try temp unlock bootloader function 2... Mobile Set BL Lock state:ser Lock state is lock Trying First Way for Get the Unlock code Dynamic unlock code:48f79031e4cc4469 Bootloader Temporary Unlock Done tip:Bootloader Temporary after reboot will lock again >>>>Clear Frp Block ... (bootloader) Erase success , the device will reboot and factory reset OKAY [ 0.091s] finished. total time: 0.091s >>>>Rebooting Mobile Phone rebooting... finished. total time: 0.000s |
The Following User Says Thank You to rizwankhan8670 For This Useful Post: |
02-17-2018, 12:19 | #812 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | REDMI 4A done. >>>Try connect to mobile...Success CPU_SN: 0xF9782E5D MSM_ID: 0x000560E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC CPU Type: 8917" / >>> Reading Mobile Map Data...Success >>>>Writing Unlock Date... Start: 0x0x00F4000000 Size: 0x0x0002000000 Success Get Ext File system.... kill apk 3...Success kill apk 2...Success kill apk 1...Success Corresponding operation completed!!! |
02-20-2018, 05:44 | #813 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | redmi note3 kenzo done. >>>Try connect to mobile...Success CPU_SN: 0x015F7EC7 MSM_ID: 0x009B00E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC CPU Type: 8976" / >>> Reading Mobile Map Data...Success >>>>Writing Unlock Date... Start: 0x0x00D4000000 Size: 0x0x0002000000 Success Get Ext File system.... kill apk 3...Success kill apk 2...Success kill apk 1...Success Corresponding operation completed!!! |
02-21-2018, 08:10 | #814 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVI 1716 done. >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0xBAD50A87 MSM_ID: 0x0009A0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>ีิฺถมศกสึป๚ทึว๘สพ...Success Eraseing Block frp ADD:0x0128180000 Size:0x0000008000 Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
The Following User Says Thank You to wsmobile For This Useful Post: |
02-21-2018, 08:14 | #815 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | mi 5s plus(natrium) done. >>>Try connect to mobile...Success CPU_SN: 0x9FBB445B MSM_ID: 0x0005F0E1 >>>Try connect to mobile...Success >>> Initialization Mobile ...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: UFS CPU Type: MSM8996 >>> Reading Mobile Map Data...Success >>>>Writing Unlock Date... Start: 0x0002000000 Size: 0x0002000000 >>>>Flashing Mobile data...Success Corresponding operation completed!!! |
The Following 2 Users Say Thank You to wsmobile For This Useful Post: |
02-21-2018, 10:29 | #816 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Meitu M6 mp1503 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM76 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom... สึป๚ืดฬฌฮช: preloader Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524331424D Flash Name: Samsung_Unknow Flash symbol: RC1BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM139 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
02-22-2018, 09:49 | #817 (permalink) | ||
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO F5 YOUTH CPH1725 MT6763 PATTERN LOCK REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK(OPPO F5 YOUTH CPH1725 MT6763) Usb READ INFO Quote:
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
02-22-2018, 10:21 | #818 (permalink) | ||
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO F5 YOUTH CPH1725 MT6763 FRP REMOVE Done SUCCESSFULLY REMOVE FRP(OPPO F5 YOUTH CPH1725 MT6763) Usb SELLECT OPPO F5 ONLY READ INFO Quote:
02-23-2018, 06:07 | #820 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVO V7+ (1716) done. >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0xD1225D76 MSM_ID: 0x0009A0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>ีิฺถมศกสึป๚ทึว๘สพ...Success Eraseing Block frp ADD:0x0128180000 Size:0x0000008000 Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
02-24-2018, 06:11 | #821 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | MEIZU m1 mote done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6752 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:R821MB >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100523832314D Flash Name: Samsung_KMR820001M_B609 Flash symbol: R821MB >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM21 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>> Analysis of mobile phone data... >>>>Reading Mobile Org Info.... Success >>>>Moving Mobile Info... SN has Change to :71UBDLE22NQW >>>>Formating Mobile USER Data... ADD(HEX):0x008F000000 Size(HEX):0x0313D80000 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
02-24-2018, 06:48 | #822 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Penang/Malaysia
Member: 8752 Status: Offline Thanks Meter: 26 | done format and FRP Oppo F1S Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM7 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM8 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00E1000000 Size(HEX):0x0665BFBE00 Corresponding operation completed!!! |
02-26-2018, 12:01 | #824 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Oppo F5 (CPH1723) done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525836344D Flash Name: Samsung_Unknow Flash symbol: RX64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM21 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
02-26-2018, 15:23 | #825 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | meizu m6 note usercode remove done >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x034DC0D6 MSM_ID: 0x000460E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>正在读取手机分区数据...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x0174000000 Size:0x0D1B7FBE00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success Eraseing Block 激活锁数据分区... ADD:0x0050000000 Size:0x0000700000 Success >>>>正在重启手机 重启手机完成 After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
The Following User Says Thank You to unlockmachine44 For This Useful Post: |
