05-07-2018, 06:56 | #901 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x88B939C8 MSM_ID: 0x0009A0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>ีิฺถมศกสึป๚ทึว๘สพ...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x0145482000 Size:0x0D4A379E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
The Following User Says Thank You to wsmobile For This Useful Post: |
05-08-2018, 10:01 | #902 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | OPPO F7 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100444836444D Flash Name: Samsung_Unknow Flash symbol: DH6DMB >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM6 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100444836444D Flash Name: Samsung_Unknow Flash symbol: DH6DMB >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
05-10-2018, 05:39 | #903 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Vivo X7 Account done. >>>Try connect to mobile...Success CPU_SN: 0x03B42CC6 MSM_ID: 0x009900E1 CPUะอบล: MSM8976 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>ีิฺถมศกสึป๚ทึว๘สพ...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x00F0E82000 Size:0x0D9E979E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
05-10-2018, 13:54 | #904 (permalink) |
Freak Poster Join Date: May 2007 Location: BetaMax Tester
Member: 516470 Status: Offline Thanks Meter: 70 | Oppo A83 passcode and FRP removed Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM55 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM4 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM55 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x90014A4842473461 Flash Name: Hynix_Unknow Flash symbol: HBG4a2 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM4 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
05-14-2018, 07:48 | #905 (permalink) | |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | oppo f7 remove user lock done oppo f7 remove user lock done with great mrt dongle [IMG][/IMG] Quote:
good work mrt team | |
05-14-2018, 07:53 | #906 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | oppo f7 remove google account done oppo f7 remove google account done with mrt dongle [IMG][/IMG] Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM383 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6763 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525836344D Flash Name: Samsung_Unknow Flash symbol: RX64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM8 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! thanks mrt team |
05-14-2018, 09:18 | #907 (permalink) |
Insane Poster Join Date: May 2010 Location: kepri
Member: 1310144 Status: Offline Thanks Meter: 15 | OPPO CPH1819 Format & FRP Done Code: Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM63 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100444836444D Flash Name: Samsung_Unknow Flash symbol: DH6DMB >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! Code: Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM63 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100444836444D Flash Name: Samsung_Unknow Flash symbol: DH6DMB >>> Reading Mobile Map Data...Success >>>>Formating Mobile account data... Corresponding operation completed!!! |
05-18-2018, 09:41 | #908 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Viet Nam (VFS)
Member: 1822938 Status: Offline Sonork: 100.1656339 Thanks Meter: 63 | Oppo R15 format success Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM9 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6771 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000001D1EC00000 -> 119276M Flash ID: 0x150100335636434D Flash Name: Samsung_Unknow Flash symbol: 3V6CMB >>> Reading Mobile Map Data...Success >>>>Writeing Mobile data userdata ... Corresponding operation completed!!! |
05-23-2018, 07:25 | #910 (permalink) | |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | My first operation done with mrt dongle Techno IN3 Quote:
The Following User Says Thank You to 4G Telecom For This Useful Post: |
05-24-2018, 15:23 | #911 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Remove Pattern Lock Oppo A71-QLLM Cph1801 2018 Done Remove Pattern Lock Oppo A71-QLLM Cph1801 2018 Done [IMG][/IMG] >>>Try connect to mobile...Success CPU_SN: 0xF56FE328 MSM_ID: 0x0009A0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>Reading Mobile IMEI Info...Success org imei:868836039687817 >>>>Erasing Userdata... Corresponding operation completed!!! Thanks mrt team |
The Following User Says Thank You to pintu_das For This Useful Post: |
05-25-2018, 04:28 | #912 (permalink) |
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVO Y71 done. >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0xE5AD3E67 MSM_ID: 0x000560E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>ีิฺถมศกสึป๚ทึว๘สพ...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x0167882000 Size:0x023C579E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
05-30-2018, 07:32 | #913 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Pakistan. D.I.Khan
Member: 1190993 Status: Offline Sonork: 100.1622640 Thanks Meter: 72 | Huawei Mate 10 Lite RNE-L21 (8.0)FRP Remove Done WITH MRT Dongle Huawei Mate 10 Lite RNE-L21 (8.0)FRP Remove Done WITH MRT Dongle Only One Click |
06-03-2018, 16:22 | #914 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Redmi note 5A MIUI 9 remove relock mi account done with great mrt dongle Redmi note 5A MIUI 9 remove relock mi account done with great mrt dongle [IMG][/IMG] Thanks mrt team |
06-08-2018, 08:20 | #915 (permalink) | ||
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Hauwei Honor Model LLD-AL10 Frp remove done Quote:
