Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 12-01-2018, 15:22   #1066 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,233
Smile HUAWEI HONOR 7A AUM-AL20 AND:8.0 Qualcomm Snapdragon 430 BRUSH FRP Done
SUCCESSFULLY BRUSH FRP(HUAWEI HONOR 7A AUM-AL20 AND:8.0 Qualcomm Snapdragon 430 )USB
>>>>search android fastboot devices...
>>>>Get android fastboot devices...
Mobile Name: AUM-AL20
Mobile Set BL Lock state:ser Lock state is lock
Trying First Way for Get the Unlock code
Dynamic unlock code:XXXXXXXXXXXX
>>>>try temp unlock bootloader function 2...
Try Qualcomm temp Bootloader unlock new function...
Bootloader Temporary Unlock Done
tip:Bootloader Temporary after reboot will lock again
>>>>Clear Frp Block
(bootloader) Erase success , the device will reboot and factory reset
OKAY [ 0.000s]
finished. total time: 0.000s
>>>>Rebooting Mobile Phone
rebooting...
finished. total time: -0.000s
THANKS MRT-TOOL TEAM
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Old 12-03-2018, 11:54   #1067 (permalink)
Member: 2131081
Sonork: 76543322223
Thanks Meter: 36
redmi4 prime mi account remove
>>>Try connect to mobile...Success
CPU_SN: 0xEC38A78F
MSM_ID: 0x000460E1
>>>init mobile...Success
>>>Downloading boot...Success
>>>Switch mobile to RE\WR ...Success
Flasy type: eMMC
CPU Type: 8953" /
>>> Reading Mobile Map Data...Success
>>>>Writing Unlock Date...
Start: 0x0x00F4000000 Size: 0x0x0002000000
Success
Corresponding operation completed!!!
Old 12-04-2018, 10:15   #1068 (permalink)
Crazy Poster
Member: 2767980
Thanks Meter: 24
Huawei DRA-LX2 8.1.0 FRP Resetting Done Using MRT Dongle
Huawei DRA-LX2 Android 8.1.0 Security Patch Level March 2018
https://imgur.com/a/H4Ul6y4
The Following User Says Thank You to atyhicham For This Useful Post:
Old 12-07-2018, 06:45   #1069 (permalink)
Member: 488790
Thanks Meter: 16
infinix x608 format and frp
>>>>Auto search Mobile port...
CPU_SN: 0x53849130
MSM_ID: 0x000560E1
Flasy type: eMMC
>>>>read mobile GPT data...Success
Clear Moblile Lock data...
After Click Mobile userdata will be lost...
Format add: ADD:0x018C000000 Size:0x0217DFBE00
Erase Userdata.. Success
Erase Userdata Block 2...
Erase Userdata Block 3...
Erase Userdata Block 4...
>>>all is done
Please disconnect mobile set,and hold vol up and power key
Mobile will be into recovery
Click Restart
if mobile hand on logo or auto restart...
You can in recovery erase data
After ease data in recovery mobile will working normal
The Following User Says Thank You to mostafaafrotoo For This Useful Post:
Old 12-08-2018, 22:04   #1070 (permalink)
Member: 2750401
Thanks Meter: 124
meizu m6 note account remove edl mode EDL 9008 mode
1. Turn off the phone
2. Hold the volume + volume - and the power button, the screen will flicker and go out, release the buttons and connect to the computer
CPU_SN: 0x14AC8D04
MSM_ID: 0x000460E1
>>>Downloading boot... User aborted; the program was interrupted
Success
Flasy type: eMMC
Format add: ADD:0x0174000000 Size:0x05D3BFBE00
Eraseing Block Activation lock...
ADD:0x0050000000 Size:0x0000700000
Success
>>>>rebooting mobile phones
reboot mobile success
After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
The Following User Says Thank You to dimasc For This Useful Post:
Old 12-10-2018, 16:01   #1071 (permalink)
localizator's Avatar
Member: 2550141
Thanks Meter: 970
Smile Meizu M2 Mini Write Firmware Done with MRT KEY
>>> Searching Mobile Port...
    Get Mobile Port is:  COM148
>>> Device driver identification:
    MediaTek USB Port
>>> Mobile Has Connect...
    CPU_NAME: MT6735
>>> Reading Mobile Hardware Info...Success
    HW_Inf:  8A00    SW_Inf:  CA00
>>> Initialization Mobile ...
>>> Sending Auth File To Mobile...Success
>>>>Trying Connect to Service verification data...
Success
>>> Downloading Boot1 To Mobile Phone...Success
    The Flash Hardware Info:Q823MB
>>> Downloading Boot2 To Mobile Phone...
>>> Initializationing Mobile Hardware Parameter...Success
    =====================Flash Type(eMMC)==============
    Flash   Size: 0x00000003A3E00000 -> 14910M
    Flash     ID: 0x150100513832334D
    Flash   Name: Samsung_Unknow
    Flash symbol: Q823MB
>>> Software Auto Switch Hight Speed Has Enable...
>>> Swich Mobile to Hight Speed Re\Wr Port...
    Get Mobile Port is:  COM149
    MediaTek DA USB VCOM (Android)
    Writeing Mobile Initialization 1...Success
    正在写入块校验   lk.... 成功!!!
    正在写入块校验   boot.... 成功!!!
    正在写入块校验   recovery.... 成功!!!
    正在写入块校验   logo.... 成功!!!
    正在写入块校验   secro.... 成功!!!
    正在写入块校验   tee1.... 成功!!!
    正在写入块校验   tee2.... 成功!!!
    正在写入块校验   custom.... 成功!!!
    正在写入块校验   system.... 成功!!!
    正在写入块校验   cache.... 成功!!!
    正在写入块校验   userdata.... 成功!!!
    Writeing Block  6  lk....Success
    Writeing Block  8  boot....Success
    Writeing Block  9  recovery....Success
    Writeing Block  10  logo....Success
    Writeing Block  14  secro....Success
    Writeing Block  16  tee1....Success
    Writeing Block  17  tee2....Success
    Writeing Block  18  custom....Success
    Writeing Block  22  system....Success
    Writeing Block  23  cache....Success
    Writeing Block  24  userdata....Success
Old 12-13-2018, 11:48   #1072 (permalink)
Member: 2750401
Thanks Meter: 124
Xiaomi Redmi 4x account mui 10 done
CPU_SN: 0x5CB7C844
MSM_ID: 0x0006B0E1
Flasy type: eMMC
CPU Type: 8937" /
Success
Old 12-13-2018, 12:52   #1073 (permalink)
Member: 2123463
Sonork: 100.1652545
Thanks Meter: 21
MT7-TL10 bootloader unlock done
>>>>Searching mobile phones...
Get Hisi cpu Mobile Phones...
>>> Get Mobile Port: COM77
>>>>Device identification :
Android Adapter PCUI
>>>>Switch Mobile to Auth Mode
System Version:MT7-TL10C900B326_SYSTEM
PCB SN: 022VJL14AF000720
Mobile SN: Q8U0214A16002125
Mobile Code: ORT
>>>>Unlocking Bootloader...Success
All is done
Old 12-14-2018, 04:42   #1074 (permalink)
allen128's Avatar
Member: 277327
Thanks Meter: 33
Oppo R11 unlock done
Sent from my iPhone using Tapatalk
The Following 3 Users Say Thank You to allen128 For This Useful Post:
Old 12-16-2018, 14:08   #1075 (permalink)
Member: 216446
Thanks Meter: 172
XIAOMI REDMI NOTE 4 MTK
IMEI REPAIR SUCESS
Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
Get Mobile Port is: COM141COM141
MediaTek PreLoader USB VCOM (Android)
Set Port To COM141Success
Into Meta Mode...Success
Switch Moile to Repair IMEI Port...
Get Mobile Port is: COM91COM91
Gadget CDC VCOM Driver
>>> Into META Repair IMEI Mode...Success
reading the relevant parameters of the phone information...
CPU_TYPE:mt6797,S01
Bulid_Time:Tue Oct 18 16:45:14 CST 2016
Base_Ver:alps-mp-m0.mp9-V1.64_lcsh6797.6c.lw.m_P101
Soft_Ver:MRA58K
Software Has be change to IMEI algorithm 2...
Original_IMEI 1:
New_IMEI 1: 862963035300041
Original_IMEI 2:
New_IMEI 2: 632963035300041
The Following User Says Thank You to jseyedanas For This Useful Post:
Old 12-16-2018, 14:41   #1076 (permalink)
Member: 216446
Thanks Meter: 172
Get Mobile Port is: COM92COM92
CPU_TYPE:mt6797,S01
Soft_Ver:MRA58K
Original_IMEI 1:
New_IMEI 1: 863248****251
Original_IMEI 2:
New_IMEI 2: 6332480******251
The Following 2 Users Say Thank You to jseyedanas For This Useful Post:
Old 12-18-2018, 05:39   #1077 (permalink)
Leo B.'s Avatar
Member: 2864653
Thanks Meter: 46
Vivo V9 format and FRP:
less customer for me this days...
you guys search for test point guidance by yourself,it's common for Vivo
The Following User Says Thank You to Leo B. For This Useful Post:
Old 12-19-2018, 22:34   #1078 (permalink)
Member: 488790
Thanks Meter: 16
HWAWEI LDN-L21 FORMAT AND FRP
Mobile Name: LDN-L21
Dynamic unlock code:376f60cdb5a303b6
Dynamic unlock code:3756a1038da0a7b8
Dynamic unlock code:375ac16081a82dbb
>>>>Clear Frp Block
Old 12-21-2018, 23:55   #1079 (permalink)
-=C.J.S=-'s Avatar
Member: 669596
Sonork: 1657504
Thanks Meter: 124
Cherry Mobile Flare J6 "FRP" Done...
    Get Mobile Port is:  COM15
    MediaTek PreLoader USB VCOM Port
    CPU_NAME: MT6580
>>> Initialization Mobile ...Success
    The Flash Hardware Info:EH8EE8
>>> Downloading Boot2 To Mobile Phone...Success
    Flash   Size: 0x00000001C8000000 -> 7296M
    Flash     ID: 0x7001004548384545
    Flash   Name: Kingston_Unknow
    Flash symbol: EH8EE8
    Get Mobile Port is:  COM19
    MediaTek DA USB VCOM Port
>>> Extracting valid data from partition data...
>>>>Formating Mobile USER Data...
    ADD(HEX):0x0018C00000    Size(HEX):0x0000100000
The Following User Says Thank You to -=C.J.S=- For This Useful Post:
Old 12-22-2018, 11:20   #1080 (permalink)
Leo B.'s Avatar
Member: 2864653
Thanks Meter: 46
Xiaomi Redmi 5A MIUI 9 account and frp
use wxxx tool to prevent relock though error message sometimes pop up
Page generated in 0.48688 seconds with 8 queries
