03-14-2019, 07:13 | #1 (permalink) |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | LG Q6 frp done by MRT-O-KEY Code: Searching Android Mobile... need power off your mobile and enaled usb debug please check mobile has tick enab auth... Get the Android Deivers Reading Mobile Device Info * daemon not running. starting it now on port 5037 * * daemon started successfully * LG-M700 Remove frp by usb debug... usage: am [subcommand] [options] usage: am start [-D] [-N] [-W] [-P <FILE>] [--start-profiler <FILE>] [--sampling INTERVAL] [-R COUNT] [-S] [--track-allocation] [--user <USER_ID> | current] <INTENT> [--user <USER_ID> | current] <INTENT> am stopservice [--user <USER_ID> | current] <INTENT> am force-stop [--user <USER_ID> | all | current] <PACKAGE> am kill [--user <USER_ID> | all | current] <PACKAGE> am kill-all am broadcast [--user <USER_ID> | all | current] <INTENT> am instrument [-r] [-e <NAME> <VALUE>] [-p <FILE>] [-w] [--user <USER_ID> | current] [--no-window-animation] [--abi <ABI>] <COMPONENT> rt [--user <USER_ID> current] [--sampling INTERVAL] <PROCESS> <FILE> am profile stop [--user <USER_ID> current] [<PROCESS>] am dumpheap [--user <USER_ID> current] [-n] <PROCESS> <FILE> am clear-debug-app am set-watch-heap <PROCESS> <MEM-LIMIT> am clear-watch-heap am bug-report [--progress] am monitor [--gdb <port>] am hang [--allow-restart] am restart am idle-maintenance am screen-compat [on|off] <PACKAGE> am package-importance <PACKAGE> am to-uri [INTENT] am to-intent-uri [INTENT] am to-app-uri [INTENT] am switch-user <USER_ID> am start-user <USER_ID> ck-user <USER_ID> [TOKEN_HEX] am stop-user [-w] [-f] <USER_ID> am stack start <DISPLAY_ID> <INTENT> am stack movetask <TASK_ID> <STACK_ID> [true|false] am stack resize <STACK_ID> <LEFT,TOP,RIGHT,BOTTOM> ize-animated <STACK_ID> <LEFT,TOP,RIGHT,BOTTOM> am stack resize-docked-stack <LEFT,TOP,RIGHT,BOTTOM> [<TASK_LEFT,TASK_TOP,TASK_RIGHT,TASK_BOTTOM>] am stack size-docked-stack-test: <STEP_SIZE> <l|t|r|b> [DELAY_MS] activity-to-pinned-stack: <STACK_ID> <LEFT,TOP,RIGHT,BOTTOM> am stack positiontask <TASK_ID> <STACK_ID> <POSITION> am stack list am stack info <STACK_ID> am stack remove <STACK_ID> am task lock <TASK_ID> task lock stop am task resizeable <TASK_ID> [0 (unresizeable) | 1 (crop_windows) | 2 (resizeable) | 3 (resizeable_and_pipable)] am task resize <TASK_ID> <LEFT,TOP,RIGHT,BOTTOM> ] am task size-task-test <TASK_ID> <STEP_SIZE> [DELAY_MS] am get-config am suppress-resize-config-changes <true|false> am set-inactive [--user <USER_ID>] <PACKAGE> true|false CKAGE> am send-trim-memory [--user <USER_ID>] <PROCESS> [HIDDEN|RUNNING_MODERATE|BACKGROUND|RUNNING_LOW|MODERATE|RUNNING_CRITICAL|COMPLETE] am get-current-user am start: start an Activity. Options are: ebugging -N: enable native debugging -W: wait for launch to complete --start-profiler <FILE>: start profiler and send results to <FILE> --sampling INTERVAL: use sample profiling with INTERVAL microseconds with --start-profiler) -P <FILE>: like above, but profiling stops when app goes idle -R: repeat the activity launch <COUNT> times. Prior to each repeat, the top activity will be finished. ing the activity --track-allocation: enable tracking of object allocations --user <USER_ID> | current: Specify which user to run as; if not specified then run as the current user. the activity be put. am startservice: start a Service. Options are: --user <USER_ID> | current: Specify which user to run as; if not specified then run as the current user. am stopservice: stop a Service. Options are: R_ID> | current: Specify which user to run as; if not specified then run as the current user. am force-stop: force stop everything associated with <PACKAGE>. --user <USER_ID> | all | current: Specify user to force stop; if not specified. am kill: Kill all processes associated with <PACKAGE>. Only kills. processes that are safe to kill -- that is, will not impact the user experience. --user <USER_ID> | all | current: Specify user whose processes to kill; all users if not specified. am kill-all: Kill all background processes. am broadcast: send a broadcast Intent. Options are: --user <USER_ID> | all | current: Specify which user to send to; if not rs. --receiver-permission <PERMISSION>: Require receiver to hold permission. am instrument: start an Instrumentation. Typically this target <COMPONENT> is the form <TEST_PACKAGE>/<RUNNER_CLASS> or only <TEST_PACKAGE> if there nstrumentation. Options are: -r: print raw results (otherwise decode REPORT_KEY_STREAMRESULT). Use with [-e perf true] to generate raw output for performance measurements. unners a common form is [-e <testrunner_flag> <value>[,<value>...]]. -p <FILE>: write profiling data to <FILE> -w: wait for instrumentation to finish before returning. Required for test runners. : Specify user instrumentation runs in; current user if not specified. --no-window-animation: turn off window animations while running. --abi <ABI>: Launch the instrumented process with the selected ABI. rocess supports the selected ABI. am trace-ipc: Trace IPC transactions. start: start tracing IPC transactions. stop: stop tracing IPC transactions and dump the results to file. to. am profile: start and stop profiler on a process. The given <PROCESS> argument may be either a process name or pid. Options are: --user <USER_ID> | current: When supplying a process name, current user if not specified. am dumpheap: dump the heap of a process. The given <PROCESS> argument may be either a process name or pid. Options are: -n: dump native heap instead of managed heap g a process name, specify user of process to dump; uses current user if not specified. am set-debug-app: set application <PACKAGE> to debug. Options are: -w: wait for debugger when application starts am clear-debug-app: clear the previously set-debug-app. am set-watch-heap: start monitoring pss size of <PROCESS>, if it is at or above <HEAP-LIMIT> then a heap dump is collected for the user to report ly set-watch-heap. am bug-report: request bug report generation; will launch a notification when done to select where it should be delivered. Options are: --progress: will launch a notification right away to show its progress. start monitoring for crashes or ANRs. --gdb: start gdbserv on the given port at crash/ANR am hang: hang the system. --allow-restart: allow watchdog to perform normal system restart am restart: restart the user-space system. tenance: perform idle maintenance now. am screen-compat: control screen compatibility mode of <PACKAGE>. am package-importance: print current importance of <PACKAGE>. am to-uri: print the given Intent specification as a URI. print the given Intent specification as an intent: URI. am to-app-uri: print the given Intent specification as an android-app: URI. am switch-user: switch to put USER_ID in the foreground, starting d. am start-user: start USER_ID in background if it is currently stopped, use switch-user if you want to start the user in foreground. am stop-user: stop execution of USER_ID, not allowing it to run any tch to it. -w: wait for stop-user to complete. -f: force stop even if there are related users that cannot be stopped. am stack start: start a new activity on <DISPLAY_ID> using <INTENT>. to the top (true) or bottom (false) of <STACK_ID>. am stack resize: change <STACK_ID> size and position to <LEFT,TOP,RIGHT,BOTTOM>. am stack resize-docked-stack: change docked stack to <LEFT,TOP,RIGHT,BOTTOM> task bounds indicated by <TASK_LEFT,TOP,RIGHT,BOTTOM> am stack size-docked-stack-test: test command for sizing docked stack by <STEP_SIZE> increments from the side <l>eft, <t>op, <r>ight, or <b>ottom n each step. am stack move-top-activity-to-pinned-stack: moves the top activity from <STACK_ID> to the pinned stack using <LEFT,TOP,RIGHT,BOTTOM> for the bounds of the pinned stack. SITION> am stack list: list all of the activity stacks and their sizes. am stack info: display the information about activity stack <STACK_ID>. am stack remove: remove stack <STACK_ID>. other tasks to run. am task lock stop: end the current task lock. am task resizeable: change resizeable mode of <TASK_ID>. 0 (unresizeable) | 1 (crop_windows) | 2 (resizeable) | 3 (resizeable_and_pipable) is in a stack with the specified bounds. Forces the task to be resizeable and creates a stack if no existing stack has the specified bounds. am task drag-task-test: test command for dragging/moving <TASK_ID> by the screen applying the optional [DELAY_MS] between each step. am task size-task-test: test command for sizing <TASK_ID> by <STEP_SIZE> increments within the screen applying the optional [DELAY_MS] between each step. ve the configuration and any recent configurations of the device. am suppress-resize-config-changes: suppresses configuration changes due to user resizing an activity/task. am set-inactive: sets the inactive state of an app. returns the inactive state of an app. am send-trim-memory: send a memory trim event to a <PROCESS>. am get-current-user: returns id of the current foreground user. <INTENT> specifications include these flags and arguments: d <DATA_URI>] [-t <MIME_TYPE>] [-c <CATEGORY> [-c <CATEGORY>] ...] [-e|--es <EXTRA_KEY> <EXTRA_STRING_VALUE> ...] [--esn <EXTRA_KEY> ...] [--ez <EXTRA_KEY> <EXTRA_BOOLEAN_VALUE> ...] [--ei <EXTRA_KEY> <EXTRA_INT_VALUE> ...] --el <EXTRA_KEY> <EXTRA_LONG_VALUE> ...] [--ef <EXTRA_KEY> <EXTRA_FLOAT_VALUE> ...] [--eu <EXTRA_KEY> <EXTRA_URI_VALUE> ...] [--ecn <EXTRA_KEY> <EXTRA_COMPONENT_NAME_VALUE>] [--eia <EXTRA_KEY> <EXTRA_INT_VALUE>[,<EXTRA_INT_VALUE...]] (mutiple extras passed as Integer[]) [--eial <EXTRA_KEY> <EXTRA_INT_VALUE>[,<EXTRA_INT_VALUE...]] (mutiple extras passed as List<Integer>) [--ela <EXTRA_KEY> <EXTRA_LONG_VALUE>[,<EXTRA_LONG_VALUE...]] ssed as Long[]) [--elal <EXTRA_KEY> <EXTRA_LONG_VALUE>[,<EXTRA_LONG_VALUE...]] (mutiple extras passed as List<Long>) [--efa <EXTRA_KEY> <EXTRA_FLOAT_VALUE>[,<EXTRA_FLOAT_VALUE...]] (mutiple extras passed as Float[]) l <EXTRA_KEY> <EXTRA_FLOAT_VALUE>[,<EXTRA_FLOAT_VALUE...]] (mutiple extras passed as List<Float>) [--esa <EXTRA_KEY> <EXTRA_STRING_VALUE>[,<EXTRA_STRING_VALUE...]] escape it using "\,") [--esal <EXTRA_KEY> <EXTRA_STRING_VALUE>[,<EXTRA_STRING_VALUE...]] (mutiple extras passed as List<String>; to embed a comma into a string, escape it using "\,") [--f <FLAG>] ri-permission] [--grant-write-uri-permission] [--grant-persistable-uri-permission] [--grant-prefix-uri-permission] [--debug-log-resolution] [--exclude-stopped-packages] [--include-stopped-packages] vity-clear-top] [--activity-clear-when-task-reset] [--activity-exclude-from-recents] [--activity-launched-from-history] [--activity-multiple-task] [--activity-no-animation] [--activity-no-history] y-previous-is-top] [--activity-reorder-to-front] [--activity-reset-task-if-needed] [--activity-single-top] [--activity-clear-task] [--activity-task-on-home] [--receiver-registered-only] [--receiver-replace-pending] eground] [--selector] [<URI> | <PACKAGE> | <COMPONENT>] Error: Bad component name: com.google.android.gsf.login/ usage: am [subcommand] [options] usage: am start [-D] [-N] [-W] [-P <FILE>] [--start-profiler <FILE>] [--sampling INTERVAL] [-R COUNT] [-S] [--track-allocation] [--user <USER_ID> | current] <INTENT> [--user <USER_ID> | current] <INTENT> am stopservice [--user <USER_ID> | current] <INTENT> am force-stop [--user <USER_ID> | all | current] <PACKAGE> am kill [--user <USER_ID> | all | current] <PACKAGE> am kill-all am broadcast [--user <USER_ID> | all | current] <INTENT> am instrument [-r] [-e <NAME> <VALUE>] [-p <FILE>] [-w] [--user <USER_ID> | current] [--no-window-animation] [--abi <ABI>] <COMPONENT> rt [--user <USER_ID> current] [--sampling INTERVAL] <PROCESS> <FILE> am profile stop [--user <USER_ID> current] [<PROCESS>] am dumpheap [--user <USER_ID> current] [-n] <PROCESS> <FILE> am clear-debug-app am set-watch-heap <PROCESS> <MEM-LIMIT> am clear-watch-heap am bug-report [--progress] am monitor [--gdb <port>] am hang [--allow-restart] am restart am idle-maintenance am screen-compat [on|off] <PACKAGE> am package-importance <PACKAGE> am to-uri [INTENT] am to-intent-uri [INTENT] am to-app-uri [INTENT] am switch-user <USER_ID> am start-user <USER_ID> ck-user <USER_ID> [TOKEN_HEX] am stop-user [-w] [-f] <USER_ID> am stack start <DISPLAY_ID> <INTENT> am stack movetask <TASK_ID> <STACK_ID> [true|false] am stack resize <STACK_ID> <LEFT,TOP,RIGHT,BOTTOM> ize-animated <STACK_ID> <LEFT,TOP,RIGHT,BOTTOM> am stack resize-docked-stack <LEFT,TOP,RIGHT,BOTTOM> [<TASK_LEFT,TASK_TOP,TASK_RIGHT,TASK_BOTTOM>] am stack size-docked-stack-test: <STEP_SIZE> <l|t|r|b> [DELAY_MS] activity-to-pinned-stack: <STACK_ID> <LEFT,TOP,RIGHT,BOTTOM> am stack positiontask <TASK_ID> <STACK_ID> <POSITION> am stack list am stack info <STACK_ID> am stack remove <STACK_ID> am task lock <TASK_ID> task lock stop am task resizeable <TASK_ID> [0 (unresizeable) | 1 (crop_windows) | 2 (resizeable) | 3 (resizeable_and_pipable)] am task resize <TASK_ID> <LEFT,TOP,RIGHT,BOTTOM> ] am task size-task-test <TASK_ID> <STEP_SIZE> [DELAY_MS] am get-config am suppress-resize-config-changes <true|false> am set-inactive [--user <USER_ID>] <PACKAGE> true|false CKAGE> am send-trim-memory [--user <USER_ID>] <PROCESS> [HIDDEN|RUNNING_MODERATE|BACKGROUND|RUNNING_LOW|MODERATE|RUNNING_CRITICAL|COMPLETE] am get-current-user am start: start an Activity. Options are: ebugging -N: enable native debugging -W: wait for launch to complete --start-profiler <FILE>: start profiler and send results to <FILE> --sampling INTERVAL: use sample profiling with INTERVAL microseconds with --start-profiler) -P <FILE>: like above, but profiling stops when app goes idle -R: repeat the activity launch <COUNT> times. Prior to each repeat, the top activity will be finished. ing the activity --track-allocation: enable tracking of object allocations --user <USER_ID> | current: Specify which user to run as; if not specified then run as the current user. the activity be put. am startservice: start a Service. Options are: --user <USER_ID> | current: Specify which user to run as; if not specified then run as the current user. am stopservice: stop a Service. Options are: R_ID> | current: Specify which user to run as; if not specified then run as the current user. am force-stop: force stop everything associated with <PACKAGE>. --user <USER_ID> | all | current: Specify user to force stop; if not specified. am kill: Kill all processes associated with <PACKAGE>. Only kills. processes that are safe to kill -- that is, will not impact the user experience. --user <USER_ID> | all | current: Specify user whose processes to kill; all users if not specified. am kill-all: Kill all background processes. am broadcast: send a broadcast Intent. Options are: --user <USER_ID> | all | current: Specify which user to send to; if not rs. --receiver-permission <PERMISSION>: Require receiver to hold permission. am instrument: start an Instrumentation. Typically this target <COMPONENT> is the form <TEST_PACKAGE>/<RUNNER_CLASS> or only <TEST_PACKAGE> if there nstrumentation. Options are: -r: print raw results (otherwise decode REPORT_KEY_STREAMRESULT). Use with [-e perf true] to generate raw output for performance measurements. unners a common form is [-e <testrunner_flag> <value>[,<value>...]]. -p <FILE>: write profiling data to <FILE> -w: wait for instrumentation to finish before returning. Required for test runners. : Specify user instrumentation runs in; current user if not specified. --no-window-animation: turn off window animations while running. --abi <ABI>: Launch the instrumented process with the selected ABI. rocess supports the selected ABI. am trace-ipc: Trace IPC transactions. start: start tracing IPC transactions. stop: stop tracing IPC transactions and dump the results to file. to. am profile: start and stop profiler on a process. The given <PROCESS> argument may be either a process name or pid. Options are: --user <USER_ID> | current: When supplying a process name, current user if not specified. am dumpheap: dump the heap of a process. The given <PROCESS> argument may be either a process name or pid. Options are: -n: dump native heap instead of managed heap g a process name, specify user of process to dump; uses current user if not specified. am set-debug-app: set application <PACKAGE> to debug. Options are: -w: wait for debugger when application starts am clear-debug-app: clear the previously set-debug-app. am set-watch-heap: start monitoring pss size of <PROCESS>, if it is at or above <HEAP-LIMIT> then a heap dump is collected for the user to report ly set-watch-heap. am bug-report: request bug report generation; will launch a notification when done to select where it should be delivered. Options are: --progress: will launch a notification right away to show its progress. start monitoring for crashes or ANRs. --gdb: start gdbserv on the given port at crash/ANR am hang: hang the system. --allow-restart: allow watchdog to perform normal system restart am restart: restart the user-space system. tenance: perform idle maintenance now. am screen-compat: control screen compatibility mode of <PACKAGE>. am package-importance: print current importance of <PACKAGE>. am to-uri: print the given Intent specification as a URI. print the given Intent specification as an intent: URI. am to-app-uri: print the given Intent specification as an android-app: URI. am switch-user: switch to put USER_ID in the foreground, starting d. am start-user: start USER_ID in background if it is currently stopped, use switch-user if you want to start the user in foreground. am stop-user: stop execution of USER_ID, not allowing it to run any tch to it. -w: wait for stop-user to complete. -f: force stop even if there are related users that cannot be stopped. am stack start: start a new activity on <DISPLAY_ID> using <INTENT>. to the top (true) or bottom (false) of <STACK_ID>. am stack resize: change <STACK_ID> size and position to <LEFT,TOP,RIGHT,BOTTOM>. am stack resize-docked-stack: change docked stack to <LEFT,TOP,RIGHT,BOTTOM> task bounds indicated by <TASK_LEFT,TOP,RIGHT,BOTTOM> am stack size-docked-stack-test: test command for sizing docked stack by <STEP_SIZE> increments from the side <l>eft, <t>op, <r>ight, or <b>ottom n each step. am stack move-top-activity-to-pinned-stack: moves the top activity from <STACK_ID> to the pinned stack using <LEFT,TOP,RIGHT,BOTTOM> for the bounds of the pinned stack. SITION> am stack list: list all of the activity stacks and their sizes. am stack info: display the information about activity stack <STACK_ID>. am stack remove: remove stack <STACK_ID>. other tasks to run. am task lock stop: end the current task lock. am task resizeable: change resizeable mode of <TASK_ID>. 0 (unresizeable) | 1 (crop_windows) | 2 (resizeable) | 3 (resizeable_and_pipable) is in a stack with the specified bounds. Forces the task to be resizeable and creates a stack if no existing stack has the specified bounds. am task drag-task-test: test command for dragging/moving <TASK_ID> by the screen applying the optional [DELAY_MS] between each step. am task size-task-test: test command for sizing <TASK_ID> by <STEP_SIZE> increments within the screen applying the optional [DELAY_MS] between each step. ve the configuration and any recent configurations of the device. am suppress-resize-config-changes: suppresses configuration changes due to user resizing an activity/task. am set-inactive: sets the inactive state of an app. returns the inactive state of an app. am send-trim-memory: send a memory trim event to a <PROCESS>. am get-current-user: returns id of the current foreground user. <INTENT> specifications include these flags and arguments: d <DATA_URI>] [-t <MIME_TYPE>] [-c <CATEGORY> [-c <CATEGORY>] ...] [-e|--es <EXTRA_KEY> <EXTRA_STRING_VALUE> ...] [--esn <EXTRA_KEY> ...] [--ez <EXTRA_KEY> <EXTRA_BOOLEAN_VALUE> ...] [--ei <EXTRA_KEY> <EXTRA_INT_VALUE> ...] --el <EXTRA_KEY> <EXTRA_LONG_VALUE> ...] [--ef <EXTRA_KEY> <EXTRA_FLOAT_VALUE> ...] [--eu <EXTRA_KEY> <EXTRA_URI_VALUE> ...] [--ecn <EXTRA_KEY> <EXTRA_COMPONENT_NAME_VALUE>] [--eia <EXTRA_KEY> <EXTRA_INT_VALUE>[,<EXTRA_INT_VALUE...]] (mutiple extras passed as Integer[]) [--eial <EXTRA_KEY> <EXTRA_INT_VALUE>[,<EXTRA_INT_VALUE...]] (mutiple extras passed as List<Integer>) [--ela <EXTRA_KEY> <EXTRA_LONG_VALUE>[,<EXTRA_LONG_VALUE...]] ssed as Long[]) [--elal <EXTRA_KEY> <EXTRA_LONG_VALUE>[,<EXTRA_LONG_VALUE...]] (mutiple extras passed as List<Long>) [--efa <EXTRA_KEY> <EXTRA_FLOAT_VALUE>[,<EXTRA_FLOAT_VALUE...]] (mutiple extras passed as Float[]) l <EXTRA_KEY> <EXTRA_FLOAT_VALUE>[,<EXTRA_FLOAT_VALUE...]] (mutiple extras passed as List<Float>) [--esa <EXTRA_KEY> <EXTRA_STRING_VALUE>[,<EXTRA_STRING_VALUE...]] escape it using "\,") [--esal <EXTRA_KEY> <EXTRA_STRING_VALUE>[,<EXTRA_STRING_VALUE...]] (mutiple extras passed as List<String>; to embed a comma into a string, escape it using "\,") [--f <FLAG>] ri-permission] [--grant-write-uri-permission] [--grant-persistable-uri-permission] [--grant-prefix-uri-permission] [--debug-log-resolution] [--exclude-stopped-packages] [--include-stopped-packages] vity-clear-top] [--activity-clear-when-task-reset] [--activity-exclude-from-recents] [--activity-launched-from-history] [--activity-multiple-task] [--activity-no-animation] [--activity-no-history] y-previous-is-top] [--activity-reorder-to-front] [--activity-reset-task-if-needed] [--activity-single-top] [--activity-clear-task] [--activity-task-on-home] [--receiver-registered-only] [--receiver-replace-pending] eground] [--selector] [<URI> | <PACKAGE> | <COMPONENT>] Error: Bad component name: com.google.android.gsf.login.LoginActivity Rebooting |
