01-10-2019, 15:09 | #16 (permalink) | |
Junior Member Join Date: May 2017
Member: 2719085 Status: Offline Thanks Meter: 14 | Quote:
Sent from my LLD-AL20 using Tapatalk | |
The Following User Says Thank You to Gouseshaik For This Useful Post: |
01-14-2019, 10:17 | #17 (permalink) |
Junior Member Join Date: Jun 2006
Member: 286307 Status: Offline Thanks Meter: 6 | y81 vivo 1808 frp done Device driver identification: MediaTek USB VCOM (Android) Version:PD1732DF_EX_A_2.1.15 IMEI:861565043144377 Flash ID:150100474536424d4203eb6a067c55f9 >>>>doing factory reset... >>>>doing factory reset2... all is done!!! |
01-14-2019, 11:32 | #18 (permalink) |
Member: 286307 Status: Offline Thanks Meter: 6 | y81 vivo 1808 google account Searching Android Mobile... need power off your mobile and enaled usb debug please check mobile has tick enab auth... Get the Android Deivers Reading Mobile Device Info * daemon not running. starting it now on port 5037 * * daemon started successfully * vivo 1808 Remove frp by usb debug... Exception occurred while executing: java.lang.IllegalArgumentException: Bad component name: com.google.android.gsf.login/ at android.content.Intent.parseCommandArgs(Intent.jav a:6540) ctivityManagerShellCommand.java:287) at com.android.server.am.ActivityManagerShellCommand. runStartActivity(ActivityManagerShellCommand.java: 337) at com.android.server.am.ActivityManagerShellCommand. onCommand(ActivityManagerShellCommand.java:150) android.os.ShellCommand.exec(ShellCommand.java:96) at com.android.server.am.ActivityManagerService.onShe llCommand(ActivityManagerService.java:17635) at android.os.Binder.shellCommand(Binder.java:595) at android.app.IActivityManager$Stub.onTransact(IActi vityManager.java:4472) at com.android.server.am.ActivityManagerService.onTra nsact(ActivityManagerService.java:3508) at android.os.Binder.execTransact(Binder.java:708) Exception occurred while executing: java.lang.IllegalArgumentException: Bad component name: com.google.android.gsf.login.LoginActivity at android.content.Intent.parseCommandArgs(Intent.jav a:6540) .makeIntent(ActivityManagerShellCommand.java:287) at com.android.server.am.ActivityManagerShellCommand. runStartActivity(ActivityManagerShellCommand.java: 337) va:150) at android.os.ShellCommand.exec(ShellCommand.java:96) at com.android.server.am.ActivityManagerService.onShe llCommand(ActivityManagerService.java:17635) at android.os.Binder.shellCommand(Binder.java:595) er.java:493) at android.app.IActivityManager$Stub.onTransact(IActi vityManager.java:4472) at com.android.server.am.ActivityManagerService.onTra nsact(ActivityManagerService.java:3508) at android.os.Binder.execTransact(Binder.java:708) Rebooting |
01-19-2019, 10:26 | #19 (permalink) |
Freak Poster Join Date: Feb 2018
Member: 2814900 Status: Offline Thanks Meter: 15 | vivo y81 pattern lock remove done with selected model y83 first you need to run mrt key software and now select mtk special tool than select BBK(VIVO)ONLY and select recovery mode and selcet advance and selcet restart adb mode model y83 or click format(unlock) now you click start |
The Following User Says Thank You to mobilemaster33 For This Useful Post: |
