Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 12-16-2018, 00:51   #46 (permalink)
Member: 2320311
Sonork: www.sonork.com
Thanks Meter: 3
Originally Posted by jbbasha View Post
when before u connect usb to phone short that point to froudn and insert see on device manager u get new type mtk comport if u done right phone wont vibrate if not short correctly phone will vibrate and on DM normal comport of mtk arrive and goes in a 10 sec
1-short testpoint /see gogle search
2-disconnect battary & hold vol up
3-connect usb cable shows boot
4-disconnect instant testpoint sort
4-instant connect battary
then operation Done
Old 12-16-2018, 07:55   #47 (permalink)
Member: 593235
Thanks Meter: 6
then operation Done
gr8. ive done with these way
but i didnt hold any button
the key is.. time u connect the battery
Old 01-02-2019, 03:26   #48 (permalink)
Member: 2404246
Thanks Meter: 10
plz help , oppo a83 A22 can not boot with testpoint
Old 01-07-2019, 10:18   #49 (permalink)
Member: 2570960
https://www.youtube.com/watch?v=X99GuIFygOg&t=577s This link helps you
Old 01-07-2019, 17:02   #50 (permalink)
s a dot com's Avatar
Member: 1779651
Sonork: 100.1603336
Thanks Meter: 93
oppo a83 2018 new boot succes full read firmware by mrt
here is logs:-
Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
Get Mobile Port is: COM578
>>> Device driver identification:
MediaTek USB Port_V1632
>>> Mobile Has Connect...
CPU_NAME: MT6763
>>> Reading Mobile Hardware Info...Success
HW_Inf: 8A00 SW_Inf: CA01
>>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success
>>> Downloading Boot1 To Mobile Phone...Success
Mobile phone status:SYNC...
Mobile phone status swtich to :brom...Success
Make sure Mobile status has in :brom...
Init Mobile BOOT2 ...
=====================Flash Type(eMMC)==============
Flash Size: 0x0000000747C00000 -> 29820M
Flash ID: 0x90014A4842473461
Flash Name: Hynix_Unknow
Flash symbol: HBG4a2
>>> Swich Mobile to Hight Speed Re\Wr Port...
Get Mobile Port is: COM10
MediaTek DA USB VCOM Port
>>> Reading Mobile Map Data...Success
>>>>Back Up Preloader Data...
Start: 0x00000800 Size: 0x003FF800
+page=0x00200000
+page=0x001FF800
>>>>Backup Backup Mobile boot_para Block Data...
Start: 0x0000008000 Size: 0x0000100000
>>>>Backup Backup Mobile recovery Block Data...
Start: 0x0000108000 Size: 0x0002000000
>>>>Backup Backup Mobile para Block Data...
Start: 0x0002108000 Size: 0x0000080000
>>>>Backup Backup Mobile reserve1 Block Data...
Start: 0x0002188000 Size: 0x0000200000
>>>>Backup Backup Mobile reserve2 Block Data...
Start: 0x0002388000 Size: 0x0001000000
>>>>Backup Backup Mobile reserve3 Block Data...
Start: 0x0003388000 Size: 0x0000200000
>>>>Backup Backup Mobile reserve4 Block Data...
Start: 0x0003588000 Size: 0x0001000000
>>>>Backup Backup Mobile oppo_custom Block Data...
Start: 0x0004588000 Size: 0x0000100000
>>>>Backup Backup Mobile expdb Block Data...
Start: 0x0004688000 Size: 0x0001400000
>>>>Backup Backup Mobile frp Block Data...
Start: 0x0005A88000 Size: 0x0000100000
>>>>Backup Backup Mobile nvcfg Block Data...
Start: 0x0005B88000 Size: 0x0002000000
>>>>Backup Backup Mobile nvdata Block Data...
Start: 0x0007B88000 Size: 0x0004000000
>>>>Backup Backup Mobile metadata Block Data...
Start: 0x000BB88000 Size: 0x0002000000
>>>>Backup Backup Mobile protect1 Block Data...
Start: 0x000DB88000 Size: 0x0000800000
>>>>Backup Backup Mobile protect2 Block Data...
Start: 0x000E388000 Size: 0x0000C78000
>>>>Backup Backup Mobile seccfg Block Data...
Start: 0x000F000000 Size: 0x0000800000
>>>>Backup Backup Mobile persist Block Data...
Start: 0x000F800000 Size: 0x0003000000
>>>>Backup Backup Mobile sec1 Block Data...
Start: 0x0012800000 Size: 0x0000200000
>>>>Backup Backup Mobile proinfo Block Data...
Start: 0x0012A00000 Size: 0x0000300000
>>>>Backup Backup Mobile md1img Block Data...
Start: 0x0012D00000 Size: 0x0004000000
>>>>Backup Backup Mobile md1dsp Block Data...
Start: 0x0016D00000 Size: 0x0001000000
>>>>Backup Backup Mobile spmfw Block Data...
Start: 0x0017D00000 Size: 0x0000100000
>>>>Backup Backup Mobile sspm_1 Block Data...
Start: 0x0017E00000 Size: 0x0000100000
>>>>Backup Backup Mobile sspm_2 Block Data...
Start: 0x0017F00000 Size: 0x0000100000
>>>>Backup Backup Mobile gz1 Block Data...
Start: 0x0018000000 Size: 0x0001000000
>>>>Backup Backup Mobile gz2 Block Data...
Start: 0x0019000000 Size: 0x0001000000
>>>>Backup Backup Mobile nvram Block Data...
Start: 0x001A000000 Size: 0x0004000000
>>>>Backup Backup Mobile lk Block Data...
Start: 0x001E000000 Size: 0x0000100000
>>>>Backup Backup Mobile lk2 Block Data...
Start: 0x001E100000 Size: 0x0000100000
>>>>Backup Backup Mobile boot Block Data...
Start: 0x001E200000 Size: 0x0002000000
>>>>Backup Backup Mobile logo Block Data...
Start: 0x0020200000 Size: 0x0000800000
>>>>Backup Backup Mobile tee1 Block Data...
Start: 0x0020A00000 Size: 0x0000500000
>>>>Backup Backup Mobile tee2 Block Data...
Start: 0x0020F00000 Size: 0x0000500000
>>>>Backup Backup Mobile reserve_exp1 Block Data...
Start: 0x0021400000 Size: 0x0000400000
>>>>Backup Backup Mobile system Block Data...
Start: 0x0021800000 Size: 0x013E800000
>>>>Backup Backup Mobile reserve_exp2 Block Data...
Start: 0x0160000000 Size: 0x0000400000
>>>>Backup Backup Mobile reserve_exp3 Block Data...
Start: 0x0160400000 Size: 0x0000400000
>>>>Backup Backup Mobile cache Block Data...
Start: 0x0160800000 Size: 0x0010000000
You Has Select ReadBack All Flash....
BR.
USMAN
SOFTWARE
Old 01-09-2019, 17:29   #51 (permalink)
Member: 1827058
Thanks Meter: 2
MediaTek USB Port
CPU_NAME: MT6763
Flash Size: 0x0000000000000000 -> 0M
Flash ID: 0x0000000000000000
Flash Name: UNKNOWN_UNKNOWN
Flash symbol: >>> Swich Mobile to Hight Speed Re\Wr Port...
Get Mobile Port is: COM7
MediaTek DA USB VCOM (Android)
>>> Reading Mobile Map Data...Fail
HELP
Old 01-09-2019, 20:29   #52 (permalink)
Member: 2641692
Thanks Meter: 10
Get Mobile Port is: COM176
MTK USB Port
CPU_NAME: MT6763
Get Mobile Port is: COM179
Unlock Failed !!!
Please Help Me to Fix This Error!
How To Fix This Error??!!
[tp methode] last sec A.22 working
Sent from my Redmi Note 6 Pro using Tapatalk
Old 01-10-2019, 10:12   #53 (permalink)
Member: 2641692
Thanks Meter: 10
OPPO A83 CPH 1729 A_22 last sec game over
welldone,... tested!!!
check this [TP Methode]
The Following User Says Thank You to parkirsek For This Useful Post:
Old 01-12-2019, 04:35   #54 (permalink)
Member: 1128603
update kab tak aayega mrt ka
Old 01-12-2019, 18:30   #55 (permalink)
Member: 1282744
Sonork: 100.1655388
Thanks Meter: 64
i am also waiting too for the update
Old 01-15-2019, 10:14   #56 (permalink)
Member: 2690385
yes thanks to you guys and mrt team oppo a83 new security done
Page generated in 0.48360 seconds with 8 queries
