Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 03-07-2017, 03:47   #16 (permalink)
Member: 2543456
Thanks Meter: 37
A little clarification and I'm silent.
Here I made a mistake with the selection and selected 'RX1BMB' and called it not supported. Here so it will be correct:
Found 6 supported eMMC CID:
name = 'HAG2e' hex = 0x484147326505 [SKHYNIX]
name = 'QE13MB' hex = 0x514531334D42 [SAMSUNG]
name = 'HBG4a2' hex = 0x484247346132 [SKHYNIX]
name = 'RX1BMB' hex = 0x525831424D42 [SAMSUNG]
name = 'HAG4a2' hex = 0x484147346132 [SKHYNIX]
name = 'Q3J97V' hex = 0x51334A393756 [Unknown vendor]
winx7000 now I understand why you all worked.
I was less fortunate than you and I got a phone with 'HAG4a2'.
In order to flash a phone I had to select "MeilanM3s"
winx7000 once again sorry for this post
Thanks MRT team !!!
The Following User Says Thank You to bma37 For This Useful Post:
Old 03-08-2017, 12:38   #17 (permalink)
Member: 2541944
Thanks Meter: 23
i flash my L681H with this firmware now my phone is dead !! pls any help
Old 03-08-2017, 12:43   #18 (permalink)
Member: 2496440
Thanks Meter: 5
[QUOTE=winx7000;12381759]i am use backup dump emmc,and ekstrack with Emmc Tool and write with MRT
What is Emmc Tool?
Old 03-15-2017, 09:55   #19 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,777
Originally Posted by bma37 View Post
Good. Where then can I download the firmware for L681H?
You can link please?
Firmware Meizu m3 note L681H backup
Old 03-15-2017, 13:08   #20 (permalink)
Member: 2543456
Thanks Meter: 37
Originally Posted by .::ARD::. View Post
My problem solved long ago and I do not need a dump (backup).
Thanks MRT team!!!
Old 03-17-2017, 03:20   #21 (permalink)
Member: 2144559
please help with m681Q RX1BMB. it s blue screen after update. any help
Old 03-17-2017, 15:01   #22 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 7,777
There are have on page 1 , you can download it
Old 03-18-2017, 01:46   #23 (permalink)
Member: 2430597
Thanks Meter: 68
Meizu m3s strip on the display and does not come out of the standby mode when the phone is locked...
Old 03-20-2017, 09:01   #24 (permalink)
Member: 2697456
NEED HELP!
Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
Get Mobile Port is: COM192
>>> Device driver identification:
MediaTek USB Port
>>> Mobile Has Connect...
CPU_NAME: MT6755
>>> Reading Mobile Hardware Info...Success
HW_Inf: 8A00 SW_Inf: CB00
>>> Initialization Mobile ...
>>> Sending Auth File To Mobile...Success
Fail
After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!!
Old 03-20-2017, 15:54   #25 (permalink)
Member: 1205328
Thanks Meter: 232
Originally Posted by mmDens View Post
NEED HELP!
MediaTek USB Port
CPU_NAME: MT6755
Fail
screenshot from software please
Old 04-05-2017, 18:06   #26 (permalink)
Member: 1911593
Sonork: 100.1645151
Thanks Meter: 130
My phone L681H flash rom 20160422222402_prd_stable_5.1.3.1 OK, after phone dead.
Pls help me !
Get Mobile Port is: COM16
MediaTek USB Port
CPU_NAME: MT6755
>>>>Trying Connect to Service verification data...
Success
>>> Downloading Boot1 To Mobile Phone...Success
Mobile phone status:SYNC...
Mobile phone status swtich to :brom...Success
Success
Make sure Mobile status has in :brom...
Init Mobile BOOT2 ...
=====================Flash Type(eMMC)==============
Flash Size: 0x0000000747C00000 -> 29820M
Flash ID: 0x90014A4842473461
Flash Name: Hynix_Unknow
Flash symbol: HBG4a2
>>> Swich Mobile to Hight Speed Re\Wr Port...
Get Mobile Port is: COM18
MediaTek DA USB VCOM (Android)
>>>>Flashing preloader Block data to Moblile Phone...
Start: 0x0000000000 Size: 0x000002E3D0
>>>>Flashing recovery Block data to Moblile Phone...
Start: 0x0000008000 Size: 0x0000C86E50
>>>>Flashing custom Block data to Moblile Phone...
Start: 0x0001088000 Size: 0x000D4212D4
>>>>Flashing md1img Block data to Moblile Phone...
Start: 0x0029800000 Size: 0x0000E86710
>>>>Flashing md1dsp Block data to Moblile Phone...
Start: 0x002B000000 Size: 0x00000E4730
>>>>Flashing md1arm7 Block data to Moblile Phone...
Start: 0x002B400000 Size: 0x0000031100
>>>>Flashing md3img Block data to Moblile Phone...
Start: 0x002B700000 Size: 0x00003CBC50
>>>>Flashing lk Block data to Moblile Phone...
Start: 0x002C100000 Size: 0x000004F510
>>>>Flashing lk2 Block data to Moblile Phone...
Start: 0x002C200000 Size: 0x000004F510
>>>>Flashing boot Block data to Moblile Phone...
Start: 0x002C300000 Size: 0x00008E1E50
>>>>Flashing logo Block data to Moblile Phone...
Start: 0x002D300000 Size: 0x00000845D0
>>>>Flashing tee1 Block data to Moblile Phone...
Start: 0x002DB00000 Size: 0x000006C4A0
>>>>Flashing tee2 Block data to Moblile Phone...
Start: 0x002E000000 Size: 0x000006C4A0
>>>>Flashing secro Block data to Moblile Phone...
Start: 0x002E500000 Size: 0x0000021000
>>>>Flashing devinfo Block data to Moblile Phone...
Start: 0x002F800000 Size: 0x0000100000
>>>>Flashing system Block data to Moblile Phone...
Start: 0x0030000000 Size: 0x0053CF6FE4
>>>>Flashing cache Block data to Moblile Phone...
Start: 0x00D0000000 Size: 0x00008A0130
>>>>Flashing userdata Block data to Moblile Phone...
Start: 0x00EB000000 Size: 0x000FCD0490
Corresponding operation completed!!!
Old 04-05-2017, 18:31   #27 (permalink)
Member: 2543456
Thanks Meter: 37
Pls help me !
Old 04-05-2017, 18:50   #28 (permalink)
Member: 1911593
Sonork: 100.1645151
Thanks Meter: 130
Thank you ! I tried but the phone still dead
( Fastboot L91HVCP622RW )
MediaTek USB Port
CPU_NAME: MT6755
Success
Success
Start: 0x0000008000 Size: 0x0001000000
Start: 0x0001088000 Size: 0x0020000000
Start: 0x002B000000 Size: 0x0000400000
Start: 0x002B400000 Size: 0x0000300000
Start: 0x002C100000 Size: 0x0000100000
Start: 0x002C200000 Size: 0x0000100000
Start: 0x002C300000 Size: 0x0001000000
Start: 0x002D300000 Size: 0x0000800000
Start: 0x002E500000 Size: 0x0000600000
Start: 0x0030000000 Size: 0x00A0000000
Start: 0x00D0000000 Size: 0x001B000000
Old 04-06-2017, 04:00   #29 (permalink)
Member: 2543456
Thanks Meter: 37
I sent you a private message with a link to download my firmware for L691H.
Old 04-06-2017, 04:11   #30 (permalink)
Member: 1911593
Sonork: 100.1645151
Thanks Meter: 130
Thank you so much, I will and post result.
Page generated in 0.41042 seconds with 8 queries
