Job Opportunities / Vacancies Looking for Job ?! setting your new Project and need to hire people ?! |
12-04-2011, 18:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Dublin
Member: 16771 Status: Offline Thanks Meter: 153 | We need your help - New website launch. WE NEED YOUR HELP.. We are in the process of launching a new website - www.TechPort.ie The website will be free, no login required and will simply be a reference guide for the mobile phone industry to have all info in one place. Its an easy to use, intuitive knowledge base software that encourages customers to help themselves. It gives the customer the opportunity to solve issues easily! You can expect to find all the electronic related help you could ever need including, Documents, Downloads, Drivers, Software, iPhone Help Guides, Phone Unlocking Procedures, Secret Codes, Tips/Tricks and much more for the complete range of consumer electronics. There will be many sections, the first section we will need help on will be the 'Mobile Phones Secret Codes' We are going to put all the codes in one simple place organized for quick reference. So, we need YOUR help. Please post below with any codes you have for mobile phones new or old. Many Thanks Alan Donohoe The AllCom Group - www.AllCom.ie |
12-07-2011, 09:19 | #3 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Manama / BAHRAIN
Member: 100592 Status: Offline Sonork: 1578498 Thanks Meter: 245 | Codes VOXTEL 0124 - master code 0718#(*)- hold - menu (ST11, SC10, V100 without SIM) 4268#(*)- hold - show code (ST11, SC10 without SIM) *789(#)- hold - menu (V50, V300, RX100 without SIM) VK MOBILE *#79# - SW version *#85*364# (*) - hold menu 855855# without SIM (VG107) 85558555#(*)-hold 4268#(*)-hold (VG207) SHARP for 2G sharp phones(some of them works on 3G also) *01763*278257# Assert Fail Log clear *01763*2783771# *01763*2783772# *01763*2783773# *01763*2783774# *01763*2783775# *01763*3640# disable Engineering Mode *01763*3641# enable Engineering Mode *01763*4634# IMEI *01763*5640# disable LOG *01763*5641# enable LOG *01763*6365641# *01763*6370# disable MEP menue (unlock menue) *01763*6371# enable MEP menue (unlock menue) *01763*63866330# disable NetMode *01763*63866331# enable NetMode *01763*753371# Sleep Check *01763*8371# Firmware Version *01763*8781# Test #1 *01763*8782# Test #2 *01763*8783# Test #3 *01763*8784# Test #4 *01763*8785# Test #5 *01763*8786# Test #6 *01763*8787# Test #7 *01763*87870# Test #70 *01763*87871# Test #71 *01763*87872# Test #72 *01763*87873# Test #73 *01763*87874# Test #74 *01763*8788# Test #8 *01763*87891# *01763*87892# SANDO 1X FORMAT CODE 5 + power on SAMSUNG *2767*3855# - FULL E2P RESET *2767*2878# - CUSTOM E2P RESET #*7337# - UNLOCK *2767*688# - UNLOCK *#0523# - CONTRAST *#9998*523# - CONTRAST *#8999*8378# - Service Menu (X100 PHILLIPS #20021208# ok - 630 without SIM (erase flash) *#7728*# - RSAV DONE *#3849*# - ??? reboot *#3851*# - ??? reboot Philips 568 *01763*737381# - reset Pantech HX-550C (cdma) Full reset (phone code reset)- ##03*934#9367*192#397#7412569746 PWR, after reset - ##27732726 PWR and select "with uim" PANTECH *01763*737381# - master reset (user data, user code) without SIM *01763*8371# - SW version *01763*6371# - UNLOCK *01763*3641# - Menu PANASONIC *01763*737381# - master reset (user data, user code) A100, A101, A102,G50, G51, G70, GD55.. *369#(*) - MENU 7, 4, 6, menu, menu - lock menu *#9999# - 5 sec after power on - SW version (GD75, GD67, GD87..) MOTOROLA (T190, T191, T205) master code - 19980722 - 20010903 ********** P2K test menu: *#06#, menu, menu, 048263* Test comands: 32*116*1*0*0 - read phone code 32*118*1*0*0 - read security code 18*0 - factory reset, phone code off 18*1 - master reset 54*18*1 - full phone reset 10*0*6 - select 900/1800 32*279*1*0*8 - model 32*383*1*0*0 - flex version Hard reset MPX200, MPX220 - blue button + power on \ MITSUBISHI *65512890 (*-hold) format FFS (Eclipse) * 3926 - (*-hold) test mode * 5806 - (*-hold) SW version *(hold) 787090 - trium 320 unlock menu MAXON *#9922# - menu, reset (without SIM) *#9900# - Software Version *#9901# - Software Version (PBatch) LG 2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...) 2945#(*)- hold (LG 500,600) B1200 *+pwr, 6,6,8 Service Menu B1300 *+pwr, 1,5,9 Service Menu Security Removing Code For Lg 8110,8120. 47328545454# Or 277634#*# HUAWAI MASTER SECURITY CODE -309296 -3092 -9296 FLY BIRD S688 - #*301#02# send - with SIM menu: 7 - 10 - ok, #*8000#, #*3676# (reboot repair) V09, S1180 - *, 3 times down, 3 times up - service menu ENOL *#987*00# - Service menu *#987*99# - Full reset *#900# - SW version ALCATEL Master Codes - 25228352 - 25228353 - 83227423 (***/4,BH4,BF5,BG3,BF3/4..) ###337*07# - master reset (with SIM) ###847# - factory reset (with SIM) Alcatel 835 formating - **0102# |
12-07-2011, 09:22 | #4 (permalink) |
Member: 100592 Status: Offline Sonork: 1578498 Thanks Meter: 245 | NEC *#CODE# CODES : 06 IMEI 7468658 SIM INFO 746255 SIM INFO 7464674 IMSI 2820 SW WERSION 79837 SW + DSP WERSION 49837 **************** 79786 Checksum 28453 Build Levev 737425 SERIAL NUMBER !!!! 73738 - 737247 Reapir History 7463424 SIMM Diagnostics 284538 Build Date 84769 Power ON 497837 Hysteresis 3643278746 Enhanced speed 3648658746 3 Volt Sim 347722 Clear Cause 627538 Market 7320 Network Lock 4960 USIM Card Lock 3210 SP Lock 8140 Coorporate Lock 5830 Unlocking Code !!! 6210 MSISDN - Current Phone Number NEC 525 When you connect the phone to USB cable... you will see the wizzard for searching drivers... then just show the path to the extracted files... and you it will found I think 3 new hardware... and install them. Then I used NEC software from furious... readed codes and inserted them How to enter codes to NEC phone to unlock it? I found it on this forum somewhere and I can't find this post now... but I think it was this code #7320* nck code # (you must read NCK code with some software) TRIUM *5806 - view fw. * # 06 # View IMEI * # 0044 # English * # 0049 # Deutsch hold * 4329 Net Monitor1 hold * 621342 Net Monitor2 hold * 5472 M4 Testmode hold * 5806 SW version hold * 5807 HW version hold * 936505 SW and HW version hold * 476989 NS Lock Menu hold * 482896 CP Lock Menu hold * 574243 NS Lock Menu hold * 967678 SP Lock Menu hold * 362628 IMSI Lock Menu hold * 787090 Lock net.level hold * 787292 Lock net.level hold * 3926 Shut Down... |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
