Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Hardware Repair
Old 11-10-2016, 10:44   #16 (permalink)
Member: 1278793
Thanks Meter: 68
pls where can i get d850 tot file to download and mine is showing QHSUSB_BUKLK
how do i drive this
The Following User Says Thank You to melotech For This Useful Post:
Old 11-24-2016, 11:39   #17 (permalink)
Member: 1425324
Sonork: 1626534
Thanks Meter: 13
heres the tot firmware link for D850
The Following 2 Users Say Thank You to anilwits For This Useful Post:
Old 12-01-2016, 10:01   #18 (permalink)
Member: 2649982
Thanks Meter: 2
hi
i'm in qload 9008 mode but still have error , device not found , test abroted
can someone help pls
The Following User Says Thank You to fdalabit For This Useful Post:
Old 12-10-2016, 13:07   #19 (permalink)
Member: 2418156
Sonork: 1677163
Thanks Meter: 16
Help me sir i have lg d851 but in pcd print vs985 after write flash file file at octopus d850 no set totel dad only show qualcomm driver show no download mode please help me sir
The Following User Says Thank You to ROOPKRB2015 For This Useful Post:
Old 01-26-2017, 22:21   #20 (permalink)
Member: 2116556
Thanks Meter: 6
help me work whit lg d722p ?
The Following User Says Thank You to deio53 For This Useful Post:
Old 03-09-2017, 17:38   #21 (permalink)
Member: 2693686
Not working with me :(
Originally Posted by kingaamir1 View Post
Asslam O Alaikom.....
Superb Work....
My LG d855 is Alive...
Thanks Alot....100000000000000% Woking Method
I also have D855 after short ping my computer say usb device not recognize. Required little guidance here.
The Following User Says Thank You to bbiillaallhh For This Useful Post:
Old 09-20-2017, 23:50   #22 (permalink)
Member: 2759791
Hi,
I took the battery, then I connected it to the PC and I see the battery symbol with the yellow triangle on the display.
But it does not appear in COM. I only see it in USB flagged driver error.
If I put the battery I see it in COM as Qualcomm 9008.
Can I perform the procedure with the battery?
Thank you
The Following User Says Thank You to pextre For This Useful Post:
Old 10-07-2017, 13:20   #23 (permalink)
Member: 2765496
Hello friends I ask you to request help to revive my lg g3s d722 the motherboard model is different from the one shown here so I do not know which pins to join to achieve the qdload mode since every time I connect it to the pc it is in mode androidnet this happened install a twrp and then do not start or give video nothing I could not upload an image of the plate I'm still placing a camera to take a photo of emmc grateful for all the support they can provide
The Following User Says Thank You to greomer2018 For This Useful Post:
Old 12-30-2017, 10:34   #24 (permalink)
Member: 2205820
Thanks Meter: 5
hi i try this metod but error device was not found in dload try flash programmer
The Following User Says Thank You to kamranpipo For This Useful Post:
Old 01-18-2018, 23:33   #25 (permalink)
Member: 2801362
mmmm
thaaaank fooor youuuu
The Following User Says Thank You to mtwsed For This Useful Post:
Old 01-23-2018, 17:21   #26 (permalink)
Member: 2661538
Sonork: SAHU
I am also same problum
Sent from my SM-J710GN using Tapatalk
The Following User Says Thank You to sahumobile786 For This Useful Post:
Old 02-12-2018, 01:03   #27 (permalink)
Member: 1989336
Sonork: 100.1652933
Thanks Meter: 13
pls help i have erorr
The Following User Says Thank You to kasunnevinda For This Useful Post:
Old 02-18-2018, 15:01   #28 (permalink)
Member: 2812715
Thanks Meter: 2
Thanks a lot . i hope This method work
The Following User Says Thank You to mrmoas For This Useful Post:
Old 03-08-2018, 18:02   #29 (permalink)
Member: 2819149
Failed during the loading flash programmer
Hi friends,
I attached the device with board diag but while restoring boot img I mistakenly selected the sbl1 at the very first stage before restoring others as mentioned in sequence above. Now my phone turns on without battery but not working.
Please help me what to do now?????
Thanks in advance
The Following User Says Thank You to musmanzulfiqar For This Useful Post:
Old 03-24-2018, 06:50   #30 (permalink)
Member: 2047969
Thanks Meter: 9
hello... can someone help me to find the link of D855 tot files.... i cant access in storagecow Directory Listing of //Xda/LG G3/Stock/ when i click that links, it shows nothing... pls help....
thanks bro....
The Following User Says Thank You to mhike777 For This Useful Post:
Page generated in 0.21916 seconds with 9 queries
