09-02-2007, 13:47 | #21 (permalink) | |
Freak Poster Join Date: May 2004 Age: 44
Member: 64311 Status: Offline Thanks Meter: 110 | Quote:
REGARDS | |
09-02-2007, 17:21 | #23 (permalink) | |
If your sure about your cable is all perfact then your procedure must be wrong.... 1. keep handset switch off 2. attach cable to phone through comport 3. then press connnect in devin tool 4. only after pressing connect button keep pressing on/off button till it show handset connected 5.after handset connected brows for reset file 6. select reset file 7. after reset file initialize successfully reset every thing | |
09-04-2007, 19:09 | #25 (permalink) | |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | Quote:
THANKS let me try it once more, let u know the result. br, s1emens | |
09-08-2007, 06:05 | #28 (permalink) | |
Junior Member Join Date: Jul 2007
Member: 545566 Status: Offline Thanks Meter: 1 | Quote:
for kg 300 using deven tool thanks i am waiting for your reply .............. wazir | |
09-08-2007, 06:30 | #29 (permalink) |
Member: 64311 Status: Offline Thanks Meter: 110 | @wazir and everyone who dont know how to make it Dear Friends still few forum members and others not undersand how to make self made cable.......i have been making cable by my self and posted manytimes in forums too...again posting the detail how one can make their desirable cable using RS232(Serial cable,9pin). First rerer to the pic attached and carefuly read the description. Pin No. Name Dir Notes/Description 1 DCD IN Data Carrier Detect. Raised by DCE when modem synchronized. 2 RD IN Receive Data (a.k.a RxD, Rx). Arriving data from DCE. 3 TD OUT Transmit Data (a.k.a TxD, Tx). Sending data from DTE. 4 DTR OUT Data Terminal Ready. Raised by DTE when powered on. In auto-answer mode raised only when RI arrives from DCE. 5 SGND - Ground 6 DSR IN Data Set Ready. Raised by DCE to indicate ready. 7 RTS OUT Request To Send. Raised by DTE when it wishes to send. Expects CTS from DCE. 8 CTS OUT Clear To Send. Raised by DCE in response to RTS from DTE. 9 RI IN Ring Indicator. Set when incoming ring detected - used for auto-answer application. DTE raised DTR to answer. So ultimately in simple term pin 2 is (Rx),pin 3 (Tx),pin 5(GND) in rs232 cable. Having rx,tx and gnd is enough for cellphones. |
09-08-2007, 11:39 | #30 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | will this work for KG200 as well??????/ kindly post reply as soon as possible i have 3 Kg200 that shuts down automatically br |
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post: |
Kg300 auto off. Solution need........... | KUMARANSUGUMAR | Infinity-Box | 3 | 09-02-2009 10:40 |
LG KG300 Auto Off Problem | zeerik | Infinity-Box | 3 | 08-02-2008 16:18 |
LG KG300 auto off | gsm_enggine | Infinity-Box | 2 | 01-26-2008 22:25 |
kg300 auto off | ruvanw1979 | Infinity-Box | 4 | 08-30-2007 14:09 |
kg300 auto off need solution | ruvanw1979 | Infinity-Box | 1 | 08-19-2007 09:02 |
