Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > LG > LG Hardware Repair Section
Old 02-18-2010, 00:22   #1 (permalink)
alexlaboratory's Avatar
Member: 771230
Cool KU990 Insert battery, not charging
For all you nerds, ku990 and u990 when put on charge shows "insert battery"
Not a soft problem its a hard problem. I have 6 already same ****ty problem.
If you are a real tech. give and aswer if you are curry muncher or some bu..s..it country like that dont waste yor time.
Old 02-18-2010, 09:27   #2 (permalink)
Member: 1041731
the changing port is bad
chance the port
it wil be okay
The Following User Says Thank You to toy4u For This Useful Post:
Old 02-18-2010, 23:16   #3 (permalink)
Member: 771230
nop not the port but close, thanks
Old 02-26-2010, 04:56   #4 (permalink)
Member: 771230
Here hope it helps
http://www.imageurlhost.com/images/1...fkhb_ku990.jpg
The Following User Says Thank You to alexlaboratory For This Useful Post:
Old 07-12-2010, 08:40   #5 (permalink)
MUTUAL's Avatar
Member: 160928
Originally Posted by alexlaboratory View Post
for all you nerds, ku990 and u990 when put on charge shows "insert battery"
not a soft problem its a hard problem. I have 6 already same ****ty problem.
If you are a real tech. Give and aswer if you are curry muncher or some bu..s..it country like that dont waste yor time.
who the fu..... U think u r u tellimg epeople like this do u know how to fix phone u stupid
Old 08-12-2010, 00:46   #6 (permalink)
Member: 1365411
In my case it was the battery connector witch not touched the board - check it, put the screws in right order and tighten them and hope it will be ok
Old 09-24-2010, 07:50   #7 (permalink)
Member: 82236
good work.thanks a lot
The Following User Says Thank You to telecomindia For This Useful Post:
Old 05-06-2011, 23:55   #8 (permalink)
Member: 92453
plz upload photo now
Old 08-07-2011, 11:59   #9 (permalink)
Member: 316893
look the pictuer
https://rs701l36.rapidshare.com/#!do...B9F9BE25A78784
and this
Old 11-04-2011, 09:34   #10 (permalink)
Member: 1682896
Any another sollutions for KU990 "insert battery"?
Hi Guys! Once again KU990!
In my case it’s:
0. "please insert battery" appears.
1. The phone charges with trickle current 80mA instead of 700mA (full charging takes two days or more).
2. Battery and charger are 100% genuine, from LG. Battery is brand new.
3. That’s not the main connector (has been replaced).
4. That’s not the battery (I’ve already tried with different one).
5. That’s not the battery connector (touches the board and is assembled correctly).
6. That’s not any firmware issue (I’ve uploaded v10g-open yesterday).
I don’t have any other motherboard as organ donor. But I’m able to analyze the board and fix the problem (after finding it).
I believe it’s something around VBAT_TEMP pin (measures battery temperature). It goes directly to analog input of U200 (MSM6280_A). Maybe can I cheat the uC by providing some fixed voltage to the VBAT_TEMP analog input?
I don’t know what’s the BSI line and how to check it’s voltage (hint needed).
Any experience which can help?
If it’s unfixable by hardware side: How to increase “The Trickle Charging Current” in firmware parameters? (I've noticed they wrote that trickle current is programmable").
Thanks in advance!
Michal
Old 01-19-2012, 19:21   #11 (permalink)
llcoolr's Avatar
Member: 53408
Sonork: 100.1593951
facing same problem here
Old 02-23-2012, 12:21   #12 (permalink)
Member: 750758
thanks bro very good
Old 03-23-2012, 16:41   #13 (permalink)
Member: 757679
try this http://s18.postimage.org/kpygc9je1/K...er_baterry.png
n73 its showing charging ok,but battery not charge shabeermobile Nokia Hardware & Hardware-Repair Area 5 01-09-2010 19:14
zt8899 charging show,but battery not charge,help me shivam4you Chinese Models & Cloned Phones 0 02-23-2009 07:05
6280 charge ok batterie not charging adelgsm Nokia Base Band 5 ( BB-5 ) 4 10-06-2008 15:57
6280 charge ok batterie not charging adelgsm Nokia Hardware & Hardware-Repair Area 3 09-23-2008 15:09
u8330 charging show but battery not charged parveen kumar LG 6 01-12-2006 06:29
Page generated in 0.34381 seconds with 12 queries
