Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > LG > LG Hardware Repair Section
Old 01-20-2011, 18:43   #31 (permalink)
shahgee111's Avatar
Member: 204642
Sonork: 1618667
lg kg 195 key pad 1000% solutation
resold all 3 green ristor near key pad conector if work then ok 2nd if no 1 key is working then remove the camra and booth volum keys
Old 08-22-2011, 09:02   #32 (permalink)
Member: 1625194
ho thanks bro it was really helpfull to me .. my several days problm has been solved thank u so much
Old 08-22-2011, 09:05   #33 (permalink)
Member: 1625194
hey thaks bro it was relly helpfull to me and its worked thanks a lot ..... thank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank uthank u
thank u
Old 09-07-2011, 12:00   #34 (permalink)
Member: 655236
it is work brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr 2000000000000000000000000000000000000000%
Old 09-30-2011, 12:24   #35 (permalink)
Member: 1529906
Sonork: 151082
Lg t300 keypad problem
Originally Posted by shahabuddin View Post
remove components of side keys. Or change side keys 100% tested by me.
Try and post result for also help to other with using in search button.
Best regards
shahab mobile zone
sir, pls help me for lg t3000 touch is ok but keys are not working . Pls urgent
Old 10-03-2011, 04:16   #36 (permalink)
saman kumara's Avatar
Member: 1077541
clean charg pin 1000000000% ok
Old 10-07-2011, 16:57   #37 (permalink)
Member: 986919
componen side where the key was his position? send a picture!!! newbe
Old 11-01-2011, 04:32   #38 (permalink)
Member: 518055
lg gu285 some main key and some upper key dont work any help pls
Old 11-23-2011, 05:43   #39 (permalink)
Member: 1694211
remove components of side keys. or change side keys 100% tested by me.
try and post result for also help to other with using in search button.
best regards
shahab mobile zone
Thanx sahab bhai it was most helpful for me. it work 100%
thanx
thanx
thanx
Old 02-18-2012, 13:57   #40 (permalink)
Registered User
Member: 882117
Sonork: sajumobile
good thinkng...thank you ..
Old 08-06-2012, 16:23   #41 (permalink)
Member: 307235
Originally Posted by sgs_41 View Post
chk the volume keys and the components behind volume switch .so many time rusting is there i solved 1 mobile with same problem only after cleaning the components
thanks this solution. success 100000000000000000%
Old 09-21-2012, 15:13   #42 (permalink)
Member: 146708
Sonork: 100.108221
hi..
anyone has kg195 volume keys way..? all ways broken.. vol up and down...
KG 195 keypad not work ??? Rizwan ch08 LG Hardware Repair Section 8 08-29-2010 18:23
LG u950 Keypad not working ranjit2003 LG 0 03-09-2009 23:35
LG kg800 keypad not working ! jawad8305 LG Hardware Repair Section 6 11-16-2008 15:53
lg 2030 keypad not working rajiv007 Various CDMA/TDMA Cell Phones 9 12-21-2005 14:25
Lg 2030 keypad not working yandbass LG 0 03-18-2005 03:58
Page generated in 0.43566 seconds with 11 queries
