05-15-2014, 13:20 | #1 (permalink) |
Major Poster Join Date: Oct 2008
Member: 885710 Status: Offline Thanks Meter: 1 | LG D802 knock code I need an advice regarding LG G2 D802. After the exchange of LCD module everything works fine. Only problem is unlocking(Knock code) the device by tapping on the display. Locking up the device with double tap works just fine, but the device won't unlock. Besides this, the LCD module works just fine. Hard reset and updating the SW through LG suite won't help. |
05-24-2014, 20:48 | #4 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Hi You guys forgot the proximity light guide from broken screen The black gum part Take care of the flexes and all the stickers to put back from old one. So many iphone screen changers break the bottom lcd flex trying to change it. BR Max_B |
The Following User Says Thank You to Max_B For This Useful Post: |
08-22-2014, 17:09 | #5 (permalink) |
Freak Poster Join Date: May 2009 Location: Vendas Novas, Portugal
Member: 1023337 Status: Offline Sonork: 100.1617970 Thanks Meter: 16 | hi, i have the same problem, i dont forget the small black rubber, i check it again and not working the double tap, work for lock display but not work for unlock. any solution? |
09-14-2014, 21:12 | #6 (permalink) |
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Tell more détails, is you using original replacement display ? Or chinese rubbish screen ? Have you took all adhesives and insulation tapes from old one ? BR Max_B |
01-11-2015, 13:48 | #7 (permalink) |
Freak Poster Join Date: Nov 2011 Location: County Durham, UK
Member: 1696994 Status: Offline Thanks Meter: 24 | Just make sure the rubber is pressing against the glass, put the proximity sensor back in and place a small bit of card over it, secure with the black upper plastic circuit board shield, all done |
