11-27-2013, 15:43 | #1 (permalink) |
Junior Member Join Date: Nov 2013 Location: Belém/PA - Brazil
Member: 2064859 Status: Offline Thanks Meter: 0 | LG E615 No Light Led I have a LG E615 L5 that does not light the LED LCD. already applied a re-solder on the board and have not had success. Does anyone know how I can resolve the situation? Have changed the lcd 2 times and did not work. Note: Ignore my english, I'm out. |
11-28-2013, 06:53 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
LG e615 display light ways first try to re hot ic its backlight if you still like the original jumpers according to the picture below dont forget to press thank | |
07-23-2016, 10:59 | #11 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2583532 Status: Offline Sonork: 256 Thanks Meter: 0 | Go to the screen, check where there are legs labelled A, k1,k2,k3,k4,k5,k6........... A-positive and k1,k2,k3,k4,k5,k6... are negatives. connect a looping wire from A and join it to the positive of any light diode on the pcb. Note: k1,k2,k3,k4,k5,k6.........are all negatives, so you need to join them all to form one negative. then loop it also to the negative of the negative side of the diode on the pcb. i believe if you follow the above instruction................everything shall be fine dont forget to click on the thanks button |
