08-09-2014, 19:17 | #1 (permalink) |
Insane Poster Join Date: Apr 2013
Member: 1927115 Status: Offline Thanks Meter: 5 | LG G2 LOCA Leaks on Backlight when replacing glass Is there a way to overcome this problem? Thanks |
08-14-2014, 23:23 | #5 (permalink) |
Freak Poster Join Date: May 2004 Location: spain Age: 35
Member: 65061 Status: Online Thanks Meter: 30 | Try to desolder the 2 wires of the backlight and then remove it clean LCD and attach it again for full refurbishing on this lg lcds you must change the backlight to new one . |
08-15-2014, 03:22 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | its not a backlight problem , its because of the glue ,which he used to attached glass with lcd, so i think u repeat this process again but this time with more care, this is my opinion ,u must wait for the experts replies |
08-17-2014, 02:03 | #7 (permalink) | |
Member: 1927115 Status: Offline Thanks Meter: 5 | Quote:
I'm not sure how I can be more careful, It's not like I made a mistake. There is some method I am not aware of to block the LOCA Glue from leaking between the backlight and the screen-front | |
08-30-2014, 17:25 | #8 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2227125 Status: Offline Thanks Meter: 1 | You need to use Backlight Sealant glue. Another way to do this to remove backlight from LCD, you need to be very careful not to demage LCD or backlight then when you cure LOCA put back backlight on LCD. But since LOCA stuck alredy in backlight you need to buy new one and replaced it. |
The Following User Says Thank You to nsantek For This Useful Post: |
09-10-2014, 03:49 | #10 (permalink) | |
Also, which method do you prefer? to remove the backlight? I had to learn this the hard way | |
05-15-2015, 12:20 | #11 (permalink) |
Insane Poster Join Date: Aug 2014
Member: 2246456 Status: Offline Thanks Meter: 2 | i had the same problem lg g2 is a screen with backlight just like iphone so you should take off the backlight before putting new glass on it and after you done clean it well and put the back light on it again in your case your backlight is ruind so get a broken lg g2 screen take the backlight and put it on yours hope this can help |
05-15-2015, 12:30 | #12 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 254271 Status: Offline Thanks Meter: 17 | Here u go You must remove the backlight watch this video this is correct I even use a old phone as a mold and have a old backlight I use .. https://*********/wPlvsb5sbdg |
