05-21-2016, 05:46 | #3 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2276113 Status: Offline Thanks Meter: 3 | No flash, the customer said she was taking it out of her pocket and it fell to the ground. After that no power and no activity when charging cable is inserted. I am assuming that a power IC may be loose but I don't know where on the mainboard to start testing. |
05-30-2016, 17:22 | #9 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | LG G3 Blue screen Dear Efrcom, do you see this effect - LG G3 Blue screen few seconds after power on - even can be flashed and no blue screen until flash process going on. Checked with new LCD - same, restored FW - it's without errors: Example: Code: Welcome to Octoplus/Octopus Box LG Software version 2.2.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: D855 Reading info... Could not detect mode! Performed by 2.2.7 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM273 Selected model: D855 Reading info... Model ID: LG-D855 IMEI: 354153-06-202069-7 Android version: 5.0 Battery level: 69% Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V20h-EUR-XX-JAN-19-2015-16G+0 LAF Version: 1.0 Product ID: BS02S140612000188 IMEI: 354153-06-202069-7 Target operator: GLOBAL Hardware: rev_10 Opening "D85520i_00_16GB.oct"...OK Setting options...OK Reading partition...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Reading partition...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.2.7 software version. Consumption on external power source seem is OK. Charging goind well on powered off unit ( just battery with percentage on screen when short press pwr button ). Any advice is welcome. WBR, DebeliaMark, BG |
05-30-2016, 19:22 | #10 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Turkey Bursa Age: 63
Member: 128481 Status: Offline Thanks Meter: 376 | A.software 1.missing files 2.wrong (incompatible) version B.hardware 1.LCD 2.lcd connect 3.lcd parts and ic(power ic,cpu,...........) |
The Following 2 Users Say Thank You to efrcom For This Useful Post: |
05-31-2016, 04:48 | #11 (permalink) | |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
By the way - i was checked LCD itself with brand new and original one - same situation - blue screen after logo. No any visual damages over PCB ( under scope ), but ... I think there is something no working due to phone systems initialise - in fact in download mode just the AP part is working ( together with PMIC and LCD ), but no Wi-Fi, BT, ect ... Taking a first look over summary is: working - Charging ( phone off, just charge - all is like on working G3, exactly ), AP ( can be rewrited, phone important data is inside ( IMEI, SW version, ect ... ) - i see flashing process come from begining to end like usual from emergency download mode, sw version can be changed up / down ( i was checked V20i and V20h, due to earliler versions 10 are eMMC size depended ) - there latest are V30b and V30c, but i just want to not go away from initial SW release, that was inside before strange behavior. And finaly - LCD ... it work like new one, nothing in this case is from LCD, even on first look damage is on LCD. OK - will continue to investigate, so - will keep comunity informed. P.S. There a indicates that this "Blue screen" problem is only for phones from 2014. Something like https://www.youtube.com/watch?v=QTP6kOuBrEU | |
06-16-2016, 20:54 | #12 (permalink) | |
Junior Member Join Date: Nov 2014
Member: 2292442 Status: Offline Thanks Meter: 12 | Quote:
The Following User Says Thank You to harhar01 For This Useful Post: |
