06-15-2017, 10:19 | #1 (permalink) |
Insane Poster Join Date: Apr 2013 Location: London
Member: 1911098 Status: Offline Thanks Meter: 16 | LG G5 H850 backlight solution want to share my experience with a LG G5 with backlight issue. The coil on the PCB I was fixing was ****n, so I just replaced it. Hit the Thanks button if that helped You |
07-04-2017, 22:18 | #2 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2733361 Status: Offline Thanks Meter: 0 | Good afternoon, I have the same problem. Not yet probe with the change of that coil. A query, how much is the value of the coil? And in case the coil is not the problem, what is the IC of the backlight? Thanks for your help, and sorry for my very bad english |
08-07-2017, 07:48 | #3 (permalink) |
Member: 1911098 Status: Offline Thanks Meter: 16 | Sorry but I do not have the phone with me anymore, so I am not able to tell you the value of the coil. I just took it from a dead phone and it worked just fine ... |
08-09-2017, 15:47 | #4 (permalink) |
Member: 2733361 Status: Offline Thanks Meter: 0 | Thanks also Now I have another problem. The cellphone only charges usb mode and never ac mode. It is not the charger or the cable, nor the USB connector, nor the battery. The problem is somewhere on the motherboard |
