Lg gx200 mic problem Hi to all bro , pls tell how to repair lg gx200 mic problem. It has 4 legs mic .i cant find this mic in marcet .pls tell me any sol........... Thx in advance |
you can use a800 mic or any other as same type. Only remove original mic LG GX200 from pcb and make as same from pic. http://img163.imageshack.us/img163/6...miclggx200.jpg I search solution and cant find nothing, so i try it in this moment and this solution works 1000%, so i m share it. |
pour le resistor 47 k utilise 3310 ou les nap z500 ou nap e730 merci |
English please! If you said about using resistor 47k in LG GX200 i think it not working good, because this topic is only about mic on LG GX200 |
i used 1k resistor and it's perfect. thank's for solution |
i solved that handset problam with 1k registance (get from nokia 1100 near falsh ic left side 1 regectence from up. |
done i well try this working 10000000000000000000000000% |
lg gx200 Quote:
