01-26-2010, 23:04 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Los Angeles
Member: 231189 Status: Offline Thanks Meter: 1 | CU920 Charging Problem I have a cu920 here which I'd assumed there's nothing wrong with the connector port BECAUSE the computer will always detect and charge the phone everytime it's plugged in. I've also look at the PCB just to make sure there's no broken pins from inside or any water damage signs. However, atlhough I've tested 4 different wall chargers (both OEM and aftermarket) the phone just can never once be charged or respond when a wall charger is plugged in. Did anyone else have the same experience before? Any suggestions on how to repair the charging circuit? Thanks in advance for any response. |
lg cu920 charging problems | timmanem68 | LG Hardware Repair | 0 | 01-10-2010 22:54 |
CU920 unlock problem | tigran80 | VygisToolbox | 3 | 08-18-2009 18:38 |
sidekick 3 charging problem after charged with wrong voltage | ltrains | Hardware Repair by brands | 0 | 07-27-2006 05:16 |
EROKR unable to charge CHARGING PROBLEM | P1C1 | Motorola Hardware Repair | 4 | 07-20-2006 16:16 |
