01-07-2015, 08:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 587 | LG p990 touchscreen problem I changed the touchscreen for one LG p990 and every thing went fine, but when i turn on the phone the touchscreen works for a few minuts than stop working till i restart the handset. Any suggestion and help will be welcome. Punto-Movil |
04-07-2015, 15:04 | #2 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2087444 Status: Offline Thanks Meter: 0 | Im having exact same problem. Change the digitalizer and now after a few minutes of use, the touchscreen stop responding, the power and volume buttons work, but the touch screen doesnt, only after i reboot the phone it work again for a few minutes, then stop working... im assuming its a defective Digitalizer panel |
04-08-2015, 02:21 | #3 (permalink) |
Member: 2087444 Status: Offline Thanks Meter: 0 | i find out that when the battery overheat it start to overheat also the digitalizer & screen... causing darkness on some parts of the screen and also stop responding at touch... im 80% sure its caused by the heat of the battery when overheat which cause the flex & ribbons cables from the screen and digitalizer to overheat also... solution.... I need to buy an original LG digitalizer and not the chinnese digitalizer without ribbon cable cover from heat |
