03-09-2013, 19:05 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: nigeria kano
Member: 599669 Status: Offline Thanks Meter: 115 | lg x330 handsfree icon |
03-10-2013, 02:36 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
Tips way or workmanship when the exit profile headset: 1. Mobile opened the chassis and is powered using batteries 2. Set the voltage at the 2.8 Volt Power Suply 3. Attach the ground wire to ground PS PCB 4. Give the PS voltage 2.8 V to the legs with a plug-in handsfree note lcd screen at the point where the voltage had been able to change the handsfree profile 5. If there are changes, voltage 2.8 V jumper to the point of other working voltage 6. Just sharing the experience may be useful Tested on all hp comes out due to the headset profile 2.8 V working voltage is lost. Before jumper voltage, it could also throw component (capacitor / resistor nge-ground) on the path Do not forget to click "THANKS" | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
