[TUTORIAL] Flash BIN rom, Unbrick, Update - Optimus 3d P920 (Service Flash software) Complete turorial Read the update at the bottom (18 SEPTEMBER 2011) NOTE !!!!! Before installation, uninstall all LG's programs and drivers from your computer. Tested on Windows XP. Download all these files. http://csmg.lgmobile.com:9002/data/S...shTool_1.1.zip https://rapidshare.com/files/2393374474/file.zip http://csmg.lgmobile.com:9002/swdata...er-4.10(2).zip http://csmg.lgmobile.com:9002/data/L...in7_LGEAll.zip Thread with Optimus 3d Roms in *.bin format. [Firmware] LG Optimus 3D P920 Original ROM's [DOWNLOAD] - xda-developersThanks to nasirahmed 1.Extract "Setup_LGFlashTool_1.1.zip" and Install. 2.Extract "file.zip" and put "LGFlashTool.exe" to location where you installed "Setup_LGFlashTool_1.1.zip" (default: C:\LG\LGFlashTool\) 3.Extract and Install "OMAPFlashInstaller-4.10(2).zip" 4.Exract "LGUnitedModemDriver_WHQL_ML_Ver_4.9.7_All_Win7_LG EAll.zip" and Install "LGUnitedMobileDriver_S497CA20_WHQL_ML_Ver_1.0 .exe " and "LGUnitedMobileDriver_S497MA20_WHQL_ML_Ver_1.0 .exe " 5.Turn Off phone, Remove your phone's SIM and SD cards. 6.Press and hold voll up button in phone. 7.When u holding "voll up button" connect the USB cable. 8.When computer detects the new hardware (Omap4430) release "voll up button". 9.Driver Installation: a.ImageShack® - Online Photo and Video Hosting b.ImageShack® - Online Photo and Video Hosting c.ImageShack® - Online Photo and Video Hosting d.ImageShack® - Online Photo and Video Hosting e.ImageShack® - Online Photo and Video Hosting f.ImageShack® - Online Photo and Video Hosting g.ImageShack® - Online Photo and Video Hosting 10.After Driver installation, go to device manager and change the port "LGE CDMA USB SERIAL PORT" to "com41". a.http://img828.imageshack.us/img828/2...shtoola.th.jpg b.As I wrote above, you must change the port for "LGE CDMA USB SERIAL PORT" not for "LGE Mobile USB serial port" as pictured. http://img801.imageshack.us/img801/4...shtoolb.th.jpg c.http://img11.imageshack.us/img11/836...shtoolc.th.jpg d.http://img600.imageshack.us/img600/7...shtoold.th.jpg 11.Run LGFlashTool. ImageShack® - Online Photo and Video Hosting 12.In DLL select file for p920 or p920h ( from here [Firmware] LG Optimus 3D P920 Original ROM's [DOWNLOAD] - xda-developers" 13.In S/W select only *.bin file from downloaded rom. 14. Choice (Check) "USB" and click OK. 15. Click on Port COM settings(COM plug icon) 16.Check as on photos. a.ImageShack® - Online Photo and Video Hosting b.ImageShack® - Online Photo and Video Hosting 17. Click start(The Port 1 window should appear READY). http://img64.imageshack.us/img64/938...htool13.th.jpg 18. Disconnects USB cable and wait 5 seconds. 19. Press and hold voll up button in phone and connect USB cable. 20. The update process will begin automatically after that release the "vol up". 21.When the progress bar reaches 100%, Power ON the phone. WARNING!!! If the update process has stopped for a longer time (about 5 minutes) not disconnect the phone from USB, , press and hold Vol Up + Power and wait when update process resume. You do this on your own risk! Thanx to "marti701". UPDATE 18 SEPTEMBER 2011 To flashing rom with LGFLASHTOOL without errors you need right USB cable. Between 4 and 5 pin you have to solder resistor 910 Kohm. http://img801.imageshack.us/img801/9...bmicrob.th.png http://img190.imageshack.us/img190/1605/img0868f.th.jpg The update process is the same ,but u don't need press any button when connect USB cable to phone. Phone screen during update http://img11.imageshack.us/img11/3874/img0863si.th.jpg This fix update screen isue :) http://img834.imageshack.us/img834/4...g0865xl.th.jpg After flashing the phone will restart. Update screen appears again(don't disconnect usb cable from phone and don't close LGDLASHTOOL) Please wait until you see the info about error of OTA update. After that the phone rebots and power On automaticaly. Font BR Gabiunlock |
help!! after flashing optimus 3d p920 phone does not take charge battery stays at 0 percent! |
whAT IS THE ROLE OF CABLE WITH RESISTANCE? |
thanks well said... successfully revive LG P920 with this procedure.. |
Good and informative, but a copy paste from xda.. Nice for the noobs.. |
only xda is forum with members here not have LG for solved? |
Bricked LG Optimus 3D (P920) Hy. I need a little help fixing my phone pls. I follow all the steps from first post, but my phone still bricked. I can start in download mode only with omap4boot flasher help. Used flashtool in 1 phase until 28% and after that phone turn off and cant start in download mode by himself to complete 2 phase with flashtool. With fastboot i can start download mode but after 4-5 min it turn off. I managed to flash "Boot21e_AP.bin" and "Boot21e_CP.fls" with Smartflash until download was complete, but no change. It seems that the power button does not work and the phone is dead. I tried using "fastboot" to flash x-loader, u-boot and boot.img to the phone but I get the error "Failed (remote: partition does not exist)" What i'm doing wrong or how can i fix my phone? PLS help ...PM or forum |
Saved my brand new Thrill I just want to express my most sincere thanx for this tutorial my phone was a paper weight till i figured this out with your incredible guidance...im new to this stuff but since i figured it out im shooting for ICS.. |
https://rapidshare.com/files/2393374474/file.zip |
Brother Some Link invalid , Please Reload Again. I Am Waiting For Fixed Link |
for invalid links try this it worked for me Download these files: Setup_LGFlashTool_1.3.zip http://dl.xda-developers.com/attachd...shTool_1.3.zip MegaLock.zip http://dl.xda-developers.com/attachd.../1/MegaLock.7z Extract "MegaLock.zip" and put to location where you installed "Setup_LGFlashTool_1.3.zip" (default: C:\LG\LGFlashTool\) good luck |
guys i have 3 lg p920 omap bricked device tried this method and succesfully done flashing my phones even tried octobus box and successfuly done flashing but my phones not unbricked..One of them restart in logo start screen other 2 device dsnt power up nothing changes..is there any diffrent solutions or advice ? |
nice work................................... |
