How To Enter Unlock Code .......... How to enter Unlock Code......... Model : AlcatelModel : 531 - 535 Without sim card : holding the "*" and compose 787292 menu "unlock network" activated select YES and enter recived code Other model - Switch on your phone with a not accepted SIM Card, - When the message "Enter Network Key" appear enter the Code recived Model : Method Generic 1 - Switch ON your phone without SIM Card, 2 - Then compose : *#0000*CODE#, 3 - To finish compose : *#0001*CODE#. BlackBerry (All) 1 - Using the menu go to Settings Menu -> SIM card pressselect. 2 - While holding the SHIFT key, type mepd 3 - You should now see the five locking categories listed. 4 - While holding the SHIFT KEY, type mep2. 5 - Release the shift key. 6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left) if left is 0 http://rapidshare.com/files/136838822/BLACK_BERRY.rar.htmlgo 7 - Enter the code 8 - Enter Return/Enter 9 - The device should then be unlocked or 1 Insert SIM card into the device 2 Power on the phone and turn Wireless Off 3 Go to "Settings" then "Options" menu and select "Advanced options" 4 Go to "SIM card" then press the jogdial to select it 5 Type MEPPD. Please note that you will not see what you type on the screen. 6 Type MEPP2. You will not see text appear on screen while typing Press ALT and 2 simultaneously to get number 2. 7 Enter unlock code 8 After entering the code press the trackball once 9 Your phone is unlocked Nokia 1 Power on phone without a SIM card 2 Compose #PW+CODE+1# where "CODE" is the unlock code you received To get letter P quickly press 3 times the star button ( * ) To get letter W quickly press 4 times the star button ( * ) To get sign + quickly press 2 times the star button ( * ) 3 You will see a message "SIM Restriction Off" 4 Your cell phone is now unlocked Htc 1 Power on phone with a non-original SIM card inserted 2 Enter unlock code when prompted Attention! Use the onscreen keyboard and make sure that wireless mode is OFF. 3 Your cell phone is now unlocked More.......... |
................... Sony Ericsson Unlock Code Instructions Model : All SonyEricsson
2 - Press 1 time the left arrow, 3 - Press 2 times the button * , 4 - Press 1 time the left arrow, 5 - The message "Personalize with MNC2" will appear, 6 - You can now enter the Unlock Code. Sidekick / Hiptop 1 Insert a non accepted SIM card and turn on the Sidekick 2 A dialogue screen will prompt you to enter the code: Title: Special Code Required 3 On you having entered the code a dialogue box will come up saying Authenticating code Dialog: Enter code to enable SIM Box for Code: 1-8 digits Options: Enable or Cancel In case you see the “Waiting for Activation Screen”, hit the Menu key and the letter L key at the same time. The menu key is the top left key. By doing this, the waiting screen will go away and you will be able to make calls. For best results, hold down Menu and the L key until the Waiting for Activation screen disappears. Samsung How to remove Phone freeze A frequent reason for Freeze Code to be enabled is when user enters several erroneous NCK codes. If your cell phone shows a "Phone Freeze" message use the first code to unfreeze it. Enter the 8-digit code with SIM card in the phone when the "Phone Freeze" message is displayed, then press OK button (middle buttom, depending on phone branding can be called differently). You can now proceede to entering Network Unlock Code. More..... |
................... Sagem All 1 - Switch ON your phone with a not Allowed SIM Card, 2 - Phone will show "SIM VERROU" 3 - You can now enter the Unlock Code. Note: if your mobile show "CODE POSTE" it's because you have a Security Code, can be 0000 or 1234 but we can't calculate this code with your IMEI because it's not code from Phone but code from the User of the Phone ! Sagem My-S7 1 - Switch ON your phone without SIM Card, 2 - Compose : *#*#CODE# and press "Call" button. Samsung Z105 & Z107 1 - Switch ON your phone with a not Accepted SIM Card, 2 - Compose : #7465625*638*CODE# All others Samsung 1 - Switch ON your phone with a not Accepted SIM Card, 2 - Phone will ask for "Password", 3 - You can now enter the Unlock Code. OR (if phone show "Insert Correct SIM Card") 1 - Switch ON your phone with a not Accepted SIM Card, 2 - Compose : #0111*CODE# U900 #7465625*638*CODE# LG 1. Insert the network SIM in the handset which has given u the LG U400. 2. Enter 2945#*88110#. 3. The phone will then prompt 'Unlock sim'. Press OK. 4. The phone will then prompt 'Network Unlock'. Press OK. 5. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. 6. It should give you the message Success. 7. Come back to the main screen and Enter 2945#*88110#. 8. The phone will then prompt unlock sim. Press OK. 9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code. 10. Then press OK SPV Model : All SPV 1 - Switch ON mobile with a not Allowed SIM Card, 2 - Enter Unlock Code we send to you. Model : SPV C500 1 - Switch ON mobile with a not Allowed SIM Card, 2 - The message "PUK2" appear, 3 - Enter the Unlock Code we send to you. 4 - Phone ASK for New Code PIN enter : 0000 5 - Confirm and compose : 0000** 6 - Click "Finish" and phone will show "Network is locked..." 7 - Enter the Unlock Code and click "Finish" 8 - Restart the Mobile and it will be Unlocked More.......... |
................... Vodafone ZTE 125 125FM 225 225 FM 226 226 FM 527 526 1 - Switch ON mobile with a not Allowed SIM Card, 2 - Enter Unlock Code we send to you. 810 716 1 - Switch ON mobile with a not Allowed SIM Card, 2 - GO TO NCK BY OPTION KEY 3 - Enter Unlock Code we send to you MORE.......... |
hi do u have the unlock code for vodafone 810 thanks |
.................................. NEC...... Model : Nec N342i 1 - Switch ON your phone without SIM Card, 2 - Compose : **00012*CODE#. Model : All others NEC 1 - Switch ON your phone without SIM Card, 2 - Compose : #7320*CODE#. Model : old NEC 1 - Switch ON your phone without SIM Card, 2 - Compose : #3210*CODE# and press Call Button. MORE.......... |
Unlock Code Instructions for any CELLULAR ******************** LINKS REMNOVED MR Next Time be careful |
bro need nck code for vodafone uk imei 359009011584172 advance thankxx |
FOR UNLOCK CODE YOU MUST NEED ACOUNT FOR A1 - SERVICE UNLOCK CODE POSSIBLE BY LOG AT FAST SERVICE CONTEST RESELLERS AT http:///vbb/showthread.php?t=555088 |
FOR UNLOCK CODE YOU MUST NEED ACOUNT FOR A1 - SERVICE UNLOCK CODE POSSIBLE BY LOG AT FAST SERVICE CONTEST RESELLERS AT http:///vbb/showthread.php?t=555088 BR.DYNET |
i have vodafone 716 imei:35900901045355-1-23 i need its NCK code any one help me thanks in advance |
my brother like DYNET told you its not free you must pay for this service . |
how about for motorola?? how to enter codes like v3xxr??? i cant enter my calculated codes for this phone |
................... How to Enter Unlock codes in Motorola Phones How to enter my Unlock Code on Motorola ? Model : All Motorola's - Except MPX and CDMA/TDMA handsets 1 - Switch ON your phone with a not allowed SIM Card, 2 - Phone should show "Enter Special or Subsidy Code", 3 - You can now enter the Unlock Code we send to you. 4 - Your Phone will now be unlocked WARNING : if any of these messages appear : - "Contact Service Provider" - or "Tamper Alter" - or "Wait before enter special Code" - or "Contact Service' It's because you or somebody else has already enter too many wrong codes, you just have to leave the phone ON on the error message and after 1hr - 8hrs the message "Enter Code Special" will appear again! Note: If your phone is on 3G network enter **057* then another window will appear to enter the Unlock code. Motorola CDMA / TDMA Unlocking Instructions. 1. Press 74663 # [Menu] [Menu] and you will be asked for subsidy code. 2. Enter the code. 3. Your phone will be unlocked instantly. Motorola MPX Unlocking Instructions. When ordering you should get 2 unlock codes one will be the NETWORK PIN and the other the SERVICE PROVIDER PIN. 1. Switch ON your phone with a not allowed SIM Card, 2. If phone is asking for NETWORK PIN enter the NETWORK PIN 3. If phone is asking for SERVICE PROVIDER PIN. Enter the SERVICE PROVIDER PIN 4. Your Phone should now be unlocked. MPX FAQ's: Question: Phone is asking for NETWORK PUK and a new password twice. I entered the code but phone is saying "Operation not supported by this SIM card".What should I do? Answer: If you still have the original card Please power on the phone with the original card in and when phone fully powered on (You have access to the menu), then TYPE: * # * * 3 6 4 # and press green button you'll get a error message and after it your will see:Engineering menu Click "Options" Click "GSM Test" Select "Send AT command" Now you will see a new window with : Send AT Command type AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN] " and press send. If you get Response "0 []" phone is unlocked If you get 1 error, then make sure you have typed the code correct and try the other code If you don't have the original card Please switch your phone off, take battery out. Put battery back in, power on the phone. Now the phone it will ask to enter NETWORK PUK. Now please DON'T TOUCH the phone for 2 hours. After 2 hours it will change screen! Now please enter the code received from us and 00000000 (eight zero's) as a new password. Now the phone will be unlocked. Question: Phone is asking for SERVICE PROVIDER PUK and a new password twice. I entered the code but phone is saying "Operation not supported by this SIM card".What should I do? Answer: YOU NEED to have the original card Please power on the phone with the original card in and when phone fully powered on (you have access to the menu), then TYPE: * # * * 3 6 4 # and press green button you'll get a error message and after it your see:Engineering menu Click "Options" Click "GSM Test" Select "Send AT command" Now you will see a new window with : Send AT Command type AT+CLCK="PP",0,"[SERVICE PROVIDER PIN or NETWORK PIN]" and press send. If you get Response "0 []" phone is unlocked If you get 1 error, then make sure you have typed the code correct and try the other code If you don't have the original card or if the original card is not accepted because you flashed the phone with other firmware, then sorry but we can't help you. Question: Why do I have to wait 2 hours before I can enter the code when phone asking for NETWORK PUK? Answer: This is because Motorola have added an anti brute force protection and if you enter to many codes, the phone will ask for NETWORK PUK and then it will refuse to accept the code even if is the right one. Question: After I restart my phone, the phone is asking again for SERVICE PROVIDER PIN. What shall I do to make it stop? Answer: Follow the instructions from SERVICE PROVIDER PUK and after that it will never ask for the code again. L 6i mode To Enter Submenu you have to press and hold asterisk (*)-> enter special code (list of codes can be found in the unlock manual for THANKS nnaeem11 BR.DYNET |
................... lg cu920 how can enter unlock code put at&t or cinguler sim in phone enter *#865625# masseg displayed : Sim unlock process select ' ok ' select unlock sim select network unlock enter 16 digit unlock code select ' ok ' re-enter ther 16 digit unlock code again select ' ok ' divice should be say network locke diactivated br.dynet |
