04-23-2009, 17:27 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: uruguay
Member: 387267 Status: Offline Thanks Meter: 10 | 2760 not supported need solution !`please supported Genie Universal Serial Number: 100 Genie Universal Hardware version: 01.06 Genie Universal Device Build: 00.00.00.153 Device credits: 298 Searching DCT4 Loaders... ->DCT4 Loaders Dir('Flash')......Found. -->11 file(s) found. -->Loaders version: v. 8.51.20.36794 for ---------------------------------------------- Reading Phone Info....Done. Phone Version: V 05.20 06-12-07 RM-259 (c) Nokia Phone IMEI sent to network: 011598/ Getting Phone mode...Done. Reading Sim lock status...Done. Configuration Key: 7223100000000000 MCC+MNC: 72231 ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Error! WD2/WD3/TIKU unsupported processor detected! |
04-24-2009, 02:06 | #3 (permalink) | |
Member: 387267 Status: Offline Thanks Meter: 10 | Ok same problem Quote:
i have this problem to many phones in special 2760 ever say mcu no support to many version please genie team update genieplus aplication!! To support all dct4 mobile phones | |
04-24-2009, 03:47 | #4 (permalink) |
No Life Poster Join Date: Nov 2001 Location: China GuangDong
Member: 7220 Status: Offline Thanks Meter: 1,592 | Hi, Genie support this phone. Your error is the cause of wrong resistor used. For 2760 it should be 10k/5.1k resistor on the BSI and 68k resistor on BSI to GND. Some tips on fixing this. Step 1 - Remove the BSI resistor on the service battery Step 2 - Select 10k to read info Step 3 - Select 5.1k to Unlock. if it doesn't work, try to switch over step 2 and step 3 Best Regards Alan Tan |
The Following User Says Thank You to xpmobile For This Useful Post: |
04-24-2009, 21:34 | #5 (permalink) |
Member: 387267 Status: Offline Thanks Meter: 10 | otheers 2760 eading Genie Universal device...Done. Genie Universal Serial Number: 100 Genie Universal Hardware version: 01.06 Genie Universal Device Build: 00.00.00.153 Device credits: 298 Searching DCT4 Loaders... ->DCT4 Loaders Dir('Flash')......Found. -->11 file(s) found. -->Loaders version: v. 8.51.20.36794 for ---------------------------------------------- Reading Phone Info....Error! ---------------------------------------------- Reading Phone Info....Done. Phone Version: V 05.20 06-12-07 RM-258 (c) Nokia Phone IMEI sent to network: 352069/02/241 Getting Phone mode...Done. Reading Sim lock status...Done. Configuration Key: 2140700000000000 MCC+MNC: 21407 ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Error! WD2/WD3/TIKU unsupported processor detected! ---------------------------------------------- DCT4 - Boot in Flash Mode. Done. Set speed. Error! WD2/WD3/TIKU unsupported processor detected! ---------------------------------------------- Uploading SP Locks...Error2! |
04-29-2009, 18:19 | #6 (permalink) |
Member: 387267 Status: Offline Thanks Meter: 10 | all is ok with 2630 and 2760 unlocked!! all modell i tried to unlock this model with universal fbus and not work , buy new fbus cable and all work ok!!! please dont use universal fbus for unlock dct4 mobile phones !! use original fbus cable jaf |
Problem KS20 and Solution, please support see this .::: BIG THANKS :::. | jalbi69 | PolarBox 3 | 13 | 07-09-2009 19:07 |
1 more year support - need help please | techie786 | FuriousGold | 6 | 03-08-2008 18:01 |
X640 Keys Freeze with MIC ..Need Solution please | mike67 | Samsung Hardware Repair | 0 | 12-02-2006 01:43 |
Samsung E300 recharge battery need solution Please | LORD_SHAH | Samsung Hardware Repair | 0 | 07-15-2006 15:09 |
