03-09-2012, 17:12 | #61 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | User: 146396 Password: 86xx26 Plese, do not cancel job ... this will point me that free service is not needed - so will stop it Quote:
03-09-2012, 17:14 | #62 (permalink) |
Crazy Poster Join Date: Aug 2008 Location: paraguay
Member: 835574 Status: Offline Sonork: 100.1609867 Thanks Meter: 5 | Open file...Done. Checking file...Done. File: 355232038200929.log Checking data...Done. Checking server list...Done. Selected server: Welcome to my Website! Submit to server...Success. Server Version: 0.21 Server Responce: Request Submited Credits Left: 0 |
03-09-2012, 17:36 | #64 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: SL3;HTC DesireHD DIRECT UNLOCk Age: 44
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | Connecting...Error2, 6 servers problem? Quote:
03-09-2012, 17:50 | #66 (permalink) | |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
This move kill with 1 bullet 2 rabits - everyone that get free account will POST screenshots, and NO MORE deleted jobs .. | |
The Following 2 Users Say Thank You to debeliamark For This Useful Post: |
03-09-2012, 21:45 | #70 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Yuty-Paraguay
Member: 911421 Status: Offline Thanks Meter: 27 | ---------------------------------------------------------------------- Checking selection...Supported(USB) interface selected. Init connection...Done. Check backup...Done. Reading sp lock details...Done. Simlock IMEI: 354827042568707 Checking simlock server...Done. Response: SIMLOCK SERVER Checking simlock validity...Done. Test Result: Passed. Reading sl table...Done. Parsing simlock data...Done. Code Count: 0.0 Blocks detected: 6 --------------------------------------------- - Block 1, Sublocks 1 Lock 1: Closed - Block 2, Sublocks 1 Lock 1: Closed - Block 3, Sublocks 1 Lock 1: Closed - Block 4, Sublocks 1 Lock 1: Closed - Block 5, Sublocks 1 Lock 1: Closed - Block 6, Sublocks 2 Lock 1: Closed(744-02) Lock 2: Invalid --------------------------------------------- Checking unlock code type...Done. Simlock Type: SL3 Unlock Code: 15 digits Downloading servers list...Success. ---------------------------------------------------------------------- Checking selection...Supported(USB) interface selected. Init connection...Done. Check backup...Done. Read SW version...Done. SW Version: V ICPR72_10w21.3.1 08-09-10 RM-594 (c) Nokia Read imei...Done. IMEI number: 354827042568707 Read Permanent memory: section 120, key 0...Done. Data: 00000000000000007223100000000000... Read Permanent memory: section 120, key 1...Done. Data: 23B021E9B4A05141A1B3B0B01D4DCB78... Read Permanent memory: section 120, key 2...Done. Data: 4233173B1D4AA34A553DD59AD6A60748... Read Permanent memory: section 120, key 3...Done. Data: 00000000000000000000000000000000... Detecting simlock type from data... This phone has old SL3 type of simlock server running. Auto restart to flash mode...Done. Init connection...Done. Requesting ROM info...Done. RAP3 ID: 115000155DAF0052ECC105647EA15283A983BB21 RootKey Hash: 479C6DDE3942E12C429C1D6ADED80371 RAP3 CPU ID: 400C192101051103 PubRom CRC: 4B9B7510 PrvRom CRC: 3E691FF8 Searching for suitable loader, based on CPU ID... Loaders directory: C:\Documents and Settings\Mara\Escritorio\NssPro_0.36\loaders\speci al\usb\ Trying bcm21351_usb2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying hwdbt_rap3gv40_2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying hwdbt_rapidov11_2nd.fg Trying to open file...Done. Checking supported IDs...Found. Checking supported root hashes...Found. Will use hwdbt_rapidov11_2nd.fg Detecting CPU type from loader name: RAPIDO CPU assumed. Will try to extract and prepare the loader... Open loader file...Done. Extracting raw block...Done, Patching correct signatures... Look for KEYS...Found,inserting into loader...Done. Look for SILO...Found,inserting into loader...Done. Look for PRIMAPP...Found,inserting into loader...Done. Setting boot mode to USB...Done. Replacing SILO with ULO...Done. Sending loader...Done. Check loader execution and init...Error write! |
03-09-2012, 23:21 | #71 (permalink) | |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Quote:
Just switch to manual restart mode(Simlocks->Settings) and try again pls. BR | |
03-10-2012, 02:35 | #72 (permalink) |
Insane Poster Join Date: Feb 2007 Location: Good old U.K. Age: 44
Member: 451364 Status: Offline Thanks Meter: 1 | I'd assume it's supposed to look like this: Downloading servers list...Success. ---------------------------------------------------------------------- Checking selection...Supported(USB) interface selected. Init connection...Done. Check backup...Done. Read SW version...Done. SW Version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia Read imei...Done. IMEI number: 358247031840023 Read Permanent memory: section 120, key 0...Done. Data: 80000000000000002343000000000000... Read Permanent memory: section 120, key 1...Done. Data: 9CED69BEE000402DF4722640D8835C38... Read Permanent memory: section 120, key 2...Done. Data: 8BAE529F70C3D0E49A2A90BB462A57CF... Read Permanent memory: section 120, key 3...Done. Data: 00000000000000000000000000000000... Detecting simlock type from data... This phone has old SL3 type of simlock server running. ---------------------------------------------------------------------- Please disconnect the USB cable... Now power off the phone... Reconnect the USB cable... Now quickly press the Power On button... ---------------------------------------------------------------------- Init connection...Done. Requesting ROM info...Done. RAP3 ID: 19100217E3558B52B9B91BB3D50D79829C11A7AE RootKey Hash: CAEEBB65D3C48E6DC73B49DC5063A2EE RAP3 CPU ID: 400C192101031103 PubRom CRC: 4B9B7510 PrvRom CRC: 3E691FF8 Searching for suitable loader, based on CPU ID... Loaders directory: C:\Users\Da' Boss\Downloads\NssPro_0.36\loaders\special\usb\ Trying bcm21351_usb2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying hwdbt_rap3gv40_2nd.fg Trying to open file...Done. Checking supported IDs...No compatible ID found in this file. Trying hwdbt_rapidov11_2nd.fg Trying to open file...Done. Checking supported IDs...Found. Checking supported root hashes...Found. Will use hwdbt_rapidov11_2nd.fg Detecting CPU type from loader name: RAPIDO CPU assumed. Will try to extract and prepare the loader... Open loader file...Done. Extracting raw block...Done, Patching correct signatures... Look for KEYS...Found,inserting into loader...Done. Look for SILO...Found,inserting into loader...Done. Look for PRIMAPP...Found,inserting into loader...Done. Setting boot mode to USB...Done. Replacing SILO with ULO...Done. Sending loader...Done. Check loader execution and init...Done. Loader Mode Responce: 0xC300FF Prepare custom RAPIDO loader...Done. Code will be loaded in memory at: 0x08005000 Sending loader...Done. Attempting to take over execution...Done. Check loader execution...Done. -- NssPro Custom Usb loader v.0.21 © 2012 GenieProjects -- Establishing secure connection...Done. Testing loader connection...Done. Prepare custom RAPIDO payload...Done. Sending payload...Done. Checking if payload is alive...Done. Reading data...Done. Prepare RAPIDO final...Done. Sending final...Done. Testing if final is alive...Done. Reading data...Done. Decode on server...Missing certificate. == Sorry, this function requires annual subscription == winits. |
03-10-2012, 17:56 | #75 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | 10 march 2012 Enjoy next free username / password. he6LeOJn / 5W8xxxHZ You must post screenshot with uploaded job, to avoid deleting WBR, DebeliaMark, BG |
sp lock 1,2,3,4 removed | spterminator | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 08-09-2010 10:20 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
unlocking nokia 1,2,3,4 | tazmania121 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-02-1999 01:20 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
