Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Genie Universal
Old 04-22-2010, 14:33   #1 (permalink)
Member: 1019991
Exclamation after update OS genie dead!! pl help [ANSWERED]
i update my genie today, but when uodating my os with remote tools 1.00.33, all was ok but when show updating error x01 or something, after my genie dead!! how can i do now??!! pl help!!
Old 04-22-2010, 14:36   #2 (permalink)
John_Doe's Avatar
Member: 1879
Sonork: 100.28016
How to restore "Dead" Genie-Universal after OS UPDATE with Remote-Tools
The Following User Says Thank You to John_Doe For This Useful Post:
Old 04-22-2010, 14:52   #3 (permalink)
Member: 163099
Its me the same problems
Hi
Its me Genie Clip for update its death
Its procedure restore me info..
Waiting Device...Found.
Checking Device...Done.
--> Genie in Recovery Mode:
Reading Data...Done.
HW Version: 1.8, Device Serial: 10xxx
ID: Genie Device Bootloader
Restoring Device...Error1, 0x6
-->You need to contact us first to use this feature!
Old 04-22-2010, 14:55   #4 (permalink)
John_Doe's Avatar
Member: 1879
Sonork: 100.28016
Originally Posted by ar-tel View Post
Hi
have a look at the above posted link, there you will find also answer whom to contact for enabling this feature.
regards,
Old 04-22-2010, 14:59   #5 (permalink)
Product Supporter and selective member Nsspro
Bph&co's Avatar
Member: 1024
Hi guys,
Please check this. Not joking !!!
BR, Alex
Old 04-22-2010, 15:01   #6 (permalink)
nafg's Avatar
Member: 196727
hi same problme now my genie is dead ,now repair and error1, 0x6 please activation my Genie for repair is 100248
B.R.
nafg
Old 04-22-2010, 15:04   #7 (permalink)
djlicks's Avatar
Member: 158242
Sonork: 100.1591384
me too my génie is dead after updat i send message to support and waiting solution
Old 04-22-2010, 15:11   #8 (permalink)
nafg's Avatar
Member: 196727
Originally Posted by Bph&co View Post
Hi guys,
BR, Alex
regarding your manual is all very clear now, but regretted for some like me has a little English and is difficult to search the forums for accurate information
Today we have released our new update for DCT4. I see already some people
have the so called 'dead' devices.
After so much postings, explanations, pdfs, all the debugging done by me and
Davor, people come here and scream: 'Please help, my device is dead'.
So to make it clear:
1. Follow very carefully the instructions in the Remote Tools readme file
2. To be sure check the system folder of your sd card, the latest update
driver is called gUpdU.sys, drag it to notepad, you should see this:
Remote Firmware Update Build: 0.0.0.165
(if different - you have older version)
3. If you get error during update, you can unplug and plug the device and
should be able to press Update again
So basically no need for recovery. Not going to even go back to formatting
the SD card and stuff - things already said million times, here.
So basically anyone who fail to follow those tips, i take is as a big disrespect
to our efforts to make the whole process stable and error free.
Later on i will disable the recovery option in the server and will be back maybe
in 1-2 months if on at all. So if you plan to kill your device because you are
lazy to read/search, do it in the next 2-3 hours as this is your only chance
B.R.
nafg
Old 04-22-2010, 15:16   #9 (permalink)
Member: 1019991
can you activation my Genie for repair
My genie sn is 101787
Old 04-22-2010, 15:28   #10 (permalink)
nafg's Avatar
Member: 196727
hi sheck this
After you have read and understood this, please contact one of the Product Managers(Zero23, John_Doe) or write an email to support@genieuniversal.com with Subject "Genie Recovery Request" to enable your Genie-Universal Serial Number for the Restore-Process.
(Due to security reasons this is NOT enabled on default!)
Do no forget to include your Genie-Universal Serial number in the message
Old 04-22-2010, 15:47   #11 (permalink)
John_Doe's Avatar
Member: 1879
Sonork: 100.28016
ok guys, once again:
if your Genie was version 186r or later(v191) then you DO NOT need the recovery feature at all!!!
If the firmware update fails (whatever the reasons may be) Genie will stay in "Recovery-Mode", you can see that the Genie LCD will turn BLUE(Blue Screen=RecoveryMode)
So since your clip is in RecoveryMode(Blue Screen) you can ALWAYS run "UPDATE OS" in Remote-Tools -again and again, as many times as needed to finish the upgrade process.
In case the upgrade-process fails all the time, the only reason is bad SD-Card Content/Format.
In this case Format the SD-Card on WinXP PC to FAT32 and copy LATEST SD-Card content to the SD-Card.
Then simply do the "UPDATE OS" in Remote-Tools again and your clip will be fine!
This above is valid for Devices with Firmware v186 or later.
The Following 2 Users Say Thank You to John_Doe For This Useful Post:
Old 04-22-2010, 17:28   #12 (permalink)
nafg's Avatar
Member: 196727
thanks for the reply, i formated the memory with fat 32 i add it the last back up that i have to the memory and i updated with the lat remote tool v33 and i still have the same error
HW Version: 1.6, Device Serial: 100248
my genie enter to boot mode but i dont get the blue screen
B.R.
nafg
Old 04-22-2010, 20:49   #13 (permalink)
Member: 88609
HW Version: 1.8, Device Serial: 102427
Old 04-22-2010, 20:53   #14 (permalink)
Member: 88609
This topic should be a problem and a solution to it
Old 04-22-2010, 21:32   #15 (permalink)
..::Mobile Smoker::..'s Avatar
Member: 170380
Sonork: 100.1577994
Alex Disabled Upgrade In Recovery Mode Feature
So You Have to Wait Untill Morning
The Following User Says Thank You to ..::Mobile Smoker::.. For This Useful Post:
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 06-25-1999 08:21
Page generated in 0.57447 seconds with 11 queries
