06-17-2009, 05:19 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: tampin malaysia Age: 61
Member: 117956 Status: Offline Thanks Meter: 115 | Yes , i face the same problem ! Device blue screen after updated ........... why ? http://forum.gsmhosting.com/vbb/show...=764291&page=3 |
06-17-2009, 06:53 | #4 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 47
Member: 85658 Status: Offline Thanks Meter: 5 | After update device with genie client then update firmware , it show " Updating firmware " and gone to blue screen . Now the device just blue screen only , Please any solution , thank you ! Urgent !!! |
06-17-2009, 07:05 | #6 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, Found the reason for the problem. There was some changes to LCD support in version 0.158, so Genie can support some new LCD types. Unfortunately it seems the new version was not tested at all by the factory and support for some older LCD used was broken. Anyway, here the fix, you will need to update to version 0.161. Please find it attached here. The tricky part, update without seeing the LCD. 1. Download attachment, unzip 2. Put osimg.sef on your card (in System) using PC SD card reader 3. Remove battery, insert charger 4. Press right button 5. Press down button 6. Press left button Device should be updated. All thanks goes to toma2 for beta testing and help. Regards, Alex Last edited by Bph&co; 06-17-2009 at 07:54. |
The Following User Says Thank You to Bph&co For This Useful Post: |
06-17-2009, 10:52 | #9 (permalink) |
Member: 117956 Status: Offline Thanks Meter: 115 | Thanks , after copy osimg 161 to mmc follow the steps , device blue screen problem solved !! |
The Following User Says Thank You to tgcommss For This Useful Post: |
08-24-2009, 16:15 | #12 (permalink) |
Freak Poster Join Date: Feb 2003 Location: England,Birmingham Age: 36
Member: 23511 Status: Offline Thanks Meter: 10 | the thing is my device didnt go blue from an update i was using it unlocked 2/3 phones and then left it then i turned it on and it was blue screeen. and now it stays like tht |
Genie lcd blank after updating | JINDALGSM | Genie Universal | 1 | 01-19-2010 10:07 |
device open failed after update | keskinm55 | Universalbox | 6 | 10-23-2008 15:54 |
device open failed after update | deecee | Universalbox | 3 | 09-19-2008 13:38 |
N91 blank after firmware update | critical_limit | Nokia Base Band 5 ( BB-5 ) | 0 | 07-23-2006 22:41 |
