Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Genie Universal
Old 12-21-2008, 06:23   #1 (permalink)
Member: 515413
Thanks Meter: 146
error flashing n70 when APE varian flash step
error occured when flash programing memory..after falsh MCU,PPM..
what problem?..
Old 12-21-2008, 09:05   #2 (permalink)
g-gabber's Avatar
Member: 192652
Sonork: No
Thanks Meter: 121
Hi,
Check your cable connection, clean flashing pin on board.
ps. Normally I use rubber band to fix cable.
The Following User Says Thank You to g-gabber For This Useful Post:
Old 12-21-2008, 15:37   #3 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Can be hardware also.
To be sure try flash with usb dead mode.
If same error you have hardware problem.
Old 12-22-2008, 04:41   #4 (permalink)
Member: 515413
Thanks Meter: 146
I think Hw no problem..with mtbox full working,I'm just a n70 got trouble....probability maybe cable problem,maybe next I'm check..anyway thx..
ERROR (02.04) when tryng to flash Sgold ! kimo59 SIEM Service Tools 7 04-01-2014 00:04
ape error with N70 & cmt flash devise are not supported mohammed-anis Nokia Hardware & Hardware Repair 4 01-07-2009 05:54
universal box bb5 flashing n70 50% ape erasing error ozturkcep Universalbox 9 12-30-2008 16:58
HELP!! Flash N70 using RM-36 Flash file! Can't reflash! silence360 Nokia Base Band 5 ( BB-5 ) 7 03-25-2007 13:31
Page generated in 0.15430 seconds with 9 queries
