03-19-2009, 20:40 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: kl Age: 40
Member: 151678 Status: Offline Thanks Meter: 22 | failed to flash 5800 in fbus so i try flash with genie to revive it but.... Flashing started Creating product data items list Product data items list created Backup not required Flashing phone FLS-X OK Connected FLS device type: FLS-5 in USB port Error: Boot code is invalid All operations completed Product flashing failed. any idea for this? need ur all help..thanks in advance |
03-19-2009, 22:30 | #2 (permalink) |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | SOry this is Phoenix limitation for FLS-5 this is not Genie clip foult but nokia and need wait for new phoenix version from nokia that will fix this. bye |
03-21-2009, 04:52 | #4 (permalink) |
No Life Poster Join Date: May 2007 Location: Alien Nation
Member: 515413 Status: Offline Thanks Meter: 146 | http://rapidshare.de/files/46196686/...37849.rar.html MULTI-PROTOCOL PHOENIX SERVICE SOFTWARE V 2009.04.11.37849 1. CHANGE HISTORY 2. INTRODUCTION New version of Phoenix service software is available. This multi-protocol service software supports Nokia CDMA, GSM, TDMA, and WCDMA products. Service SW installation packages and Technical Bulletins are available in NOL. Main component versions in the release: · DK2 Driver Version 07.14.0.25 · Nokia Connectivity Cable USB Driver Version 7.1.8.0 (For Win2000 driver version 6.85.15.0) · Flash Update Package 09_11_04 · FLS-x Drivers Version 2.09.26 · FPS-11Version 5.10.0 3. CHANGES & ERROR CORRECTIONS FROM PREVIOUS VERSION 2008.44.5.36625 New products supported: · RM-455, RM-516, RM-561, RM-509, RM-510, RM-511, RM-514, RM-515, RM-470, RM-503, RM-544, RM-518 · Complete list of supported models is available fom Phoenix menu “File” –> “Open Product” New features · Automatic device log file collection enabled, this function has no impact to field services · Nokia Connectivity Cable USB Driver updated · Flash Update Package - > Please make sure you update your prommer from “Prommer Maintenance” · FLS-x Drivers updated Error Corrections & changes · Improvements to auto tuning · Stability improvements to USB flashing · Changes to image download configuration 4. KNOWN ERRORS & LIMITATIONS · Software dongrade with Tucson system is only possible for BB 5.0 products supporting the Data Package 2 concept. · Flashing with FLS-5, SS-46 and product specific adapter is not reliable for all BB 5.0 products · USB flashing for N96 is not stable Version 1 16.03.2009 Initial version Nokia APAC NOL 3 (2) CONFIDENTIAL APAC TECHNICAL SUPPORT Create Date Wilchua 17 March 2009 ASB<MPP>046 x Level 1 x Level 2 x Level 3 Version 1 Copyright © Nokia Corporation 2009 · Tucson add on package will be released soon to improve Tucson stability · Flash Update Package File installation path may be wrong. If you experience problems when updating FPS-x prommers, please check that Phoenix “Prommer maintenance” is looking for the files from the correct location which is “C:\Program Files\Common Files\Nokia\Tss\Flash”. If not, Phoenix will show error “Update via ini – file failed”. In this case, select “Update” from that Phoenix “Prommer maintenance” – UI, browse to correct directory and select “fpsxupd.ini” for all other prommers except the FPS-8. · Multi Flash has limited capabilities, launch Multiflash UI first and then connect phones one by one, do not attempt to service more than 5 phones at the time 5. INSTALLATION If you have Phoenix External 2007.4.6.170 or older you must uninstall it before installing this release. 1. Download Phoenix_Service_Software_2009_4_11_37849.exe application file to your computer (e.g. C:\TEMP). 2. Close all other programs. 3. Phoenix_Service_Software_2009_4_11_37849.exe and follow instructions on the screen to install Phoenix Service Software 4. Connect a dongle (PK-1, PKD-1, FLS-4S, FLS-5) when message appears on the screen 5. If you are prompted to update any existing driver or file versions, select “yes”. 6. Depending on the operating system, the PC may require rebooting. 7. Allow Windows to register the Phoenix components. 8. Open Phoenix and update your prommer with the latest software included in this installation package. 9. Use the latest available product specific data packages or flash bundles with new multi-protocol Phoenix. Supported operating systems and user rights · Windows 2000 Service Pack 4 or higher · Windows XP Service Pack 1 or higher · When installing Phoenix into Win 2000 or XP you must have local admin rights. · When using in Win 2000 or XP, user must have power user rights. For HW & Tool requirements please refer to Service Repair Processes ASB_Repair_007.pdf For information on product specific data packages, tools and instructions please refer to service manuals and technical bulletins. If you want to use FPS-11, please download separate FPS-11 driver package If you are installing this version of Phoenix on a new Imaged PC, and you are using an FLS-4S or FLS-5 during the install, then install the FLS-X drivers first. Nokia APAC NOL 3 (3) CONFIDENTIAL APAC TECHNICAL SUPPORT Create Date Wilchua 17 March 2009 ASB<MPP>046 x Level 1 x Level 2 x Level 3 Version 1 Copyright © Nokia Corporation 2009 6. NOTES This product includes software developed by the OpenSSL Project for use in the OpenSSL Toolkit (http://www.openssl.org/). Copyright (c) 1998-2005 The OpenSSL Project. All rights reserved. Copyright (c) 1995-1998 Eric Young ([email protected]). All rights reserved. OpenSSL license text can be found from http://www.openssl.org/source/license.html. |
The Following 2 Users Say Thank You to titan_wonder For This Useful Post: |
what is the method to flash 5800 by usb which options need to select | observer123 | Universalbox | 2 | 07-27-2009 02:25 |
Can I use usb to Flash phones not fbus!? | SangReal | MT-BOX | 2 | 04-24-2006 05:01 |
is it posible to flash 6310 with fbus? | nitzanzb | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 10-23-2003 03:13 |
