02-01-2010, 10:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | Formatted sd card ? |
The Following User Says Thank You to aminnovelty For This Useful Post: |
02-01-2010, 11:05 | #2 (permalink) | |
No Life Poster Join Date: Aug 2000 Location: anywhere
Member: 1879 Status: Offline Sonork: 100.28016 Thanks Meter: 941 | Quote:
http://www.genieuniversal.com/downlo...ew_SD-Card.pdf regards, | |
The Following User Says Thank You to John_Doe For This Useful Post: |
02-01-2010, 14:40 | #3 (permalink) | |
Member: 566122 Status: Offline Thanks Meter: 322 | Quote:
02-01-2010, 14:43 | #4 (permalink) | |
do you have another fat32 sd card to try? no need to format it, just insert it and go into usb-mode. if it will be ok, then you are sure that your sdcard has a problem. regards, | |
02-01-2010, 15:10 | #7 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Georgetown
Member: 455304 Status: Offline Thanks Meter: 417 | i have a question also.... i have 2009 model genie.. with 1gig memory card.. working ok... if i want to upgrade to a 2gig is that a problem...but again is 2gig really needed ? |
02-01-2010, 15:17 | #8 (permalink) |
Registered User Join Date: Jan 2004 Location: PAKISTAN Age: 52
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | I also facing same problem ,when i insert sd card and try to change mode to usb,it gives driver error:4. i check with empty card,it gives driver error:1 i also send mail to [email protected] for sd card contents. 1 more thing,when i run log.smx,box connect with computer and with remotetool also. Br Xtreme |
02-01-2010, 17:52 | #10 (permalink) | |
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | Quote:
Thanx Sasha. Br Xtreme | |
sd card format [ANSWERED] | SABRINA80 | Genie Universal | 2 | 03-23-2010 13:00 |
help iam format my sd card!!!! | jiwanfeng | Genie Universal | 2 | 02-10-2010 14:47 |
my sd card is virus or format | ch_rathore | Genie Universal | 1 | 01-19-2010 09:37 |
How should the SD card be formated? | SubTen | Genie Universal | 2 | 03-09-2009 18:49 |
Where to find Bluetooth SD Card, SD TV Tuner Card in INDIA? | sujithsidhardhan | HTC & PDA WM( With Touchscreen) | 0 | 10-29-2006 09:40 |
