06-19-2010, 11:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Sheffield
Member: 26187 Status: Offline Sonork: 100:77458 Thanks Meter: 290 | Genie Update Step By Step Walkthrough admin, please stick this thread so it may help other users. Genie User says: hi mark i have geine infront of me, how do i update it? Mark - FoneFunShop says: install genie suite from Genie Universal tell me when done Genie User says: ok ok done Mark - FoneFunShop says: press mode/usb disk on clip open my computer c: program files/genie suite open genie client Genie User says: ok Mark - FoneFunShop says: i need you to run genie client, but also at same time be able to view the genie client folder on pc...understand? Genie User says: ok Mark - FoneFunShop says: ok on genie client press get drive Genie User says: ok Mark - FoneFunShop says: now this is the important bit press update on genie client a file will begin to download into genie client folder once finished genie client progress bar will begin at this point copy the downloaded file from genie client folder to your desktop copy it, dont move it Genie User says: ok Mark - FoneFunShop says: tell me when done Genie User says: ok done its a zipped folder Mark - FoneFunShop says: so you have a backup file on desktop yes? Genie User says: yes Mark - FoneFunShop says: ok you have winrar installed? Genie User says: yes Mark - FoneFunShop says: ok close genie client go to my computer and format the genie disk, make sure it is FAT32 and do not change name of drive, it should be called somthing like GENIE1002XX do quick format Genie User says: ok done Mark - FoneFunShop says: ok open genie drive rightclick and drag backup to grive and extract here extract backup to genie disk (understand) Genie User says: yes done i am a computer tecnician, if i can not do this :P Mark - FoneFunShop says: ok now, disconnect clip reconnect select programs/script/log.smx install drivers from crogram files/genie client/drivers folder Genie User says: ok done Mark - FoneFunShop says: disconnect cable reconnect press mode / update os run remote tools from within genie suite folder Genie User says: it is stuck in remote tools script Mark - FoneFunShop says: disconnect cable reconnect Genie User says: usb os update ? Mark - FoneFunShop says: yes on clip then run remote tools software on pc Genie User says: Nokia SL_X Remote Tools V 1.0.0.34 Waiting Device...Found. Reading data...Error1! Closing Device...Done. Mark - FoneFunShop says: why have you pressed a button on software? Genie User says: no Mark - FoneFunShop says: take cable out and put back Genie User says: ok Mark - FoneFunShop says: mode update os drivers should ping in Genie User says: nothing happens Mark - FoneFunShop says: wait check device manager see if genie device is present under usb Genie User says: yes is present Mark - FoneFunShop says: ok run remote tools on pc tell me which version it is Genie User says: 1.0.0.34 Mark - FoneFunShop says: ok wait press about tab at bottom press update os button Genie User says: waiting device ----------------- And genie is stuck Mark - FoneFunShop says: ok youve nearly finished all you need to to do is mode/update os then update os button on remote tools reboot pc, it sounds like you having driver issues possibly and try again Genie User says: ok ill reboot, be right back Waiting Device...Found. Checking Device...Done. Driver: Remote Firmware Update v 0.0.0.167 Connecting to server...Done. Updating OS...Done. ------------------------------------------------- Mark - FoneFunShop says: :-) all done Genie User says: good lets hope it works now Mark - FoneFunShop says: it will :-) |
The Following 5 Users Say Thank You to fonefun For This Useful Post: |
5.28 working solution by eeprom 24x16 | SLO/EU | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-22-2000 15:55 |
nokia nse-spv8 by zulea | rothmanns | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-12-2000 07:52 |
have nokia lock 2 solution by cable | oskarcore | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:49 |
